[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
der 90 grad adapter kommt ja. kabel brauchste dafür aber nochmal dazu
extension für 8pin
fertige direkt für "alte" nts
für bq übern configurator
Ja eben. Wenn die gwinkelte kabel haben braucht man keinen adapert. Es heisst doch jede steckverbindung ist ein risiko und leistungsverlust?
Die ersten beiden links sind doch nicht für bequiet oder?
extension für 8pin
Da wird aber nur der Anschluss der 3000er angegeben (im Konfigurator)
tatsache... wasn crap. ist dieser sensepin überhuapt bei den nicht atx3.0 nts nötig?
hmm die is echt leise
was sagt die Waküfraktion? Wakü ja/nein?
ich mein, Block is bestellt, aber die is echt silencio bruno
Läuft top unter Luft aktuell aber zum Sommer hin. Not sure. WaKü-Kram wird auf jeden Fall nicht verkauft.
Er muss auf jeden Fall so gebrückt sein das die Karte denkt sie darf 600 ziehen.
Hallo liebe Community, ich verfolge seit Tagen sehr genau diesen Thread. Ich bin verzweifelt auf der Suche nach einer Gigabyte OC und stets erfolglos. Kann mir hier vielleicht jemand helfen? Habt vielen Dank vorab!
10sekunden war sie da gerade :d
du musst die in den merkzettel packen und von dort drauf gehen
Was genau ist den der Unterschied zwischen ModFlex und ModMesh, also ohne Marketingsprech?
Langsam überlege ich auch dort zu bestellen, weiß der Geier wann Seasonic tatsächlich sein schönes Kabel raushaut…
flex soll etwas flexibler sein. kann gut sein dass dem auch so ist. ich hab ein modmesh full kit für mein nt und das ist schon recht störrig :d
Bei durchschnittlich nur 10% hinter der 4090 würde sich die RX 7900 XT defintiv viel mehr lohnen, wenns um reine Gamingleistung geht und wenn es dann tatsächlich so sein sollte.
Ja, kann es kaum abwarten echte Zahlen zu sehen und vor allem was AMD noch mit einer möglichen RX 7950 X3D so abliefern wird.
Wenn sie tatsächlich nur 10% oder on paar wäre...dann würde diese auch ähnlich kosten. AMD sind doch auch keine Samariter. Es sei denn es gehe eiskalt um Marktanteile.
habe meine TUF gerade mal freilauf gegeben
PT 100%. default clocks, Stray aufn desktop getappt. gpu war bei 100% load. fps cap ist glaube durchs raustabben nicht aktiv gewesen und die karte hast du im raum defintiv gehört weil High Load + High FPS :)
bei 70% wirds etwas dumpfer
bei meinen 118 fps cap ist es fast weg
Meine TUF finde ich ziemlich ruhig, aber etwas Fiepen kann ich beim 3Dmark im Sampler Test mit 1200fps provozieren. Im Vergleich dann noch mal mit Praxis gerechtem 118fps. Videos hier: https://www.hardwareluxx.de/communi...ep-rassel-thread.1324904/page-8#post-29529016
Und selbst wenn. Die Händler sind es nicht. Insofern mal schauen was preislich passiert.
Mit meiner 4090 (Phantom GS) habe ich ein merkwürdiges Problem: immer wenn ich im Afterburner das OSD mit Rivatuner einschalte, taktet die Karte nicht mehr runter, wenn die 3D Anwendung geschlossen wird, der Takt ist wie festgetackert und dementsprechend ist auch die Leistungsaufnahme im idle auf dem Desktop (>60W). Ohne Rivatuner funktioniert alles wie es soll.
EVGA Precision X1 habe ich auch schon ausprobiert, da taktet die Karte zwar runter, aber ich habe in manchen Games (zB. GTA5) links am Rand, da wo das OSD erscheint, einen flackernden bunten Streifen. Echt nervig.
Wenn ich Rivatuner benutzt habe, muss ich den Treiber neu installieren, PC neu booten oder abschalten hilft nicht.
Kann jemand das Problem bestätigen und hat evtl. eine Lösung dafür?
Ein Kollege von mir hatte ein ähnliches Problem. Er musste Windows neu aufsetzen da sich irgendwas im Untergrumd verfangen hat.
Cablemod hat mir grade eben die Versandmitteilung meines 4x8 Pin Kabels geschickt, das ich am 29.10 im EU Store geordert habe
Ach, jetzt hab ich die Retrodiskussion verpasst. Bei mir hat das "Wow-Erlebnis" die Matrox m3D mit PowerVR Chip Gen 1 Rev 2 ausgelöst. Das war zu Voodoo 1 Zeiten, nur konnte die PVR 1024x768 32 Bit. 4 MB Speicher auf dem winzigen Kärtchen für die Texturen, gerendert wurde in den 2MB Buffer der S3 Trio. Das warn noch Zeiten. Die Trio ließ sich um fast 100% übertakten - brachte halt nichts 😂
Von c9 - c2 sind alle geil. Nur der c9 hat noch dts und 48gb. Der c2 hat auch wieder 48gb aber kein dts.
Keinen b nehmen. Gibt zukünftig weniger updates.
Und aus dem Grund , wollte ich kein Gespräch führen.
JEtzt haben wir hier einen der bei LG Arbeitet und es zu 100% Weiß das der B keine oder Weniger Updates erhält :) Du bist mir echt ein Held. Und NEIN ich werde nicht mehr drauf eingehen.
Lass es gut sein. Und Ende mit der hoffentlich NICHT anfangenden Diskution. Darfst mir gerne noch einen reindrüpcken, das du dein StandPunkt klar gemacht hast. Für mich ist jetzt hier bei dem Thema Ende.
Hehe, die Frage hab ich mir auch gestellt...
€dit: Springt zu 4:44 - geht leider nicht übern Link...
Mädels... es ist immernoch ein 4090 Thread. Kein LG OLED Thread.
Müsste man eigentlich mal nen Fred für aufmachen, ich liebe Retrodiskussion :) ( leigt vlt an meinem alter oder so )
