[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann ich jetzt nicht behaupteten, für mich gibt es derzeit eigentlich kein Spiel das geiler aussieht als Cyberpunk bei Nacht mit Raytracing maxed out. Jedes Setting unterhalb von RT Psycho sieht massiv schlechter aus imho. Da nehme ich dann lieber DLSS in Kauf.
Das RT Argument suckt für mich hart. Ich weiß nicht was mit so manchen Augen los ist aber RT war für mich in all deinen besagten Titel nicht der Rede wert. Wenn ich da nicht irgendwo in einer Ecke stehen bleibe um Details zu betrachten, kann ich darauf zu gunsten von FPS jederzeit gerne verzichten...erst recht wenn ich dann noch unschärfe Müll wie DLSS dazu schalten muss.
RT ist für mich auf dem jetzigen Level der Implementierung hauptsächlich ein Marketing Erfolg aber kein Visual Erfolg.
Auf was für einem Monitor/TV und mit welcher GPU hast Du die RT Titel gezockt? Und auf welche Distanz hast Du gesessen? Es gibt einen gewaltigen Unterschied in Immersion zwischen Couch-TV Distanz und Stuhl-Schreibtisch.
Habe bisher einige Kumpels RT Titel auf meinem LG OLED und ner 3090 (damals) zocken lassen, und jeder war absolut begeistert. Habe da nicht eine Stimme gehört nach dem Motto "ist unnötig". VRR und DLSS Quali an, RT max, butterweiches Gameplay genießen und tolle optische Features bekommen.
Mal ganz abgesehen, dass - mMn - man schon fast blind sein muss, um die RT Effekte in Gebäuden/Spiegelungen/Böden nicht zu erkennen/ sich nicht daran zu erfreuen (soweit das Spiel das vernünftig umsetzt, die meisten RT Titel verdiene den Namen nicht).
Grade bei Watchdogs könnte man schon fast sagen, dass die Effekte übertrieben d.h. schon zu häufig/ zu krass eingesetzt werden, d.h. wenn ganze Hochhäuserfronten brutalst spiegeln, als wären die vor 2 Sekunden auf Hochglanz geputzt worden (was geil aussieht, aber nicht realistisch ist), fühlt man sich eher wie in einer schlechten Simulation.
Mal ganz abgesehen davon, dass DLSS 2.3 (aufwärts) bewiesenermaßen in vielen Titeln bessere Qualität abliefert als nativ. Warum Du hier "unscharf" sagst, wundert mich schon etwas. DLSS 3.0 hat downsides, ja. Das betrifft allerdings nur Frame Generation, nicht den DLSS unterbau als solchen. Das Marketing ist hier sowieso Schwachsinn, Frame Generation ist eine separate Technologie und hätte niemals DLSS 3.0 genannt werden sollen.
die rt reflections in cyberpunk sind ziemlich schlecht im vergleich zu anderen games, aber mit dem neuen modus wirds richtig gut aussehen.
amd karten will ich net wirklich wegen vr/triple moni. dazu gibts häufiger treiber probleme
Ich habe auch die Vermutung, dass hier viele Cyberpunk nur in niedrigeren RT Stufen gezockt haben (die davon nicht überzeugt sind), denn selbst eine 3090 hatte mit DLSS Probleme mit den FPS bei maximierten Raytracing (gurkte irgendwo zwischen 40-45 FPS rum, wenn überhaupt). Mit VRR auf einem OLED aber ohne Probleme genießbar (~ subjektiv wie 60-70 FPS bei einem nicht VRR/OLED).
Hä??? Wann das denn? Jedes Game ist nativ besser. Kein Ghosting, keine Artefakte und Messerscharfe Texturen
Das ist generell so nicht richtig, denn Games mit (nativ) schlechten anti-aliasing profitieren massiv von gutem DLSS, da gibt es genug Tests zu, wo (kurioserweise) DLSS 2.3/2.4 besser ausschaut als nativ, schlichtweg weil die Textur-Kanten besser aussehen. Kein Ghosting bringt einem garnichts, wenn die Texturen In-Game allesamt in die Tonne gehören.
Habe grade eine interessante Anekdote zu AMDs "AI cores" gelesen:
"The AI cores are not exposed through software, software developers cannot use them directly (unlike NVIDIA's Tensor Cores), they are used exclusively by the GPU internal engines."
Das ist merkwürdig. Ob AMD hier in Wahrheit wohl überhaupt keine AI Cores hat, sondern nur Marketing betreiben will und hier über die normalen Cores Berechnungen durchführen lässt?
So ein Feature nicht in Software zu öffnen macht für mich wenig Sinn. Groß in der Präsentation mit "AI acceleration components " werben, und diese dann überhaut nicht einsetzen lassen. Sinnlos.
AMD haut meiner Meinung nach das bessere Gesamtpaket raus. Am Ende werden die Tests es aber zeigen. Hier hat mal jemand auf Basis der bekannten Informationen hochgerechnet:
"up to". Das relati4t sich wieder(y)
DLSS can man nachschärfen, vorallem mit CAS@reshade.
DLSS 3.0 kenne ich bisher nur vom 3dmark, schaut aber top aus. Da muss man gar nix mehr nachschärfen.
DLSS 3.0 games habe ich bisher noch nicht gesehen. Die spiderman Shice interessiert mich sowas von überhaupt ned, dafür wirds aber wohl dann A Plague Tale werden. Wobei bei der dicken Leistung der 4090 wäre nicht mal das notwendig. (y)
Nicht wenige Spiele haben schlechte Kantenglättung implementiert, sodass DLSS Quality insgesamt betrachtet teilweise besser aussieht als Nativ.
Ja finde auch DLSS sieht besser als viele Games die TAA nutzen was auch zu ghosting führt .
Gibt kaum noch MSAA
Ich habe es in jedem Spiel auf einem 77er Oled verglichen. Nativ sieht immer besser aus. Und bei 4k ist Highend Kantenglättung nicht mehr so wichtig.
Nope, agree to disagree. Für mich sind flimmernde Kanten schlimmer als leichte DLSS Unschärfe (der man mit dem Schärferegler zudem problemlos entgegenwirken kann), vor allem bei Spielen mit viel Vegetation.
Dass es auf nen paar Meter Abstand am Fernseher anders wirken mag, mag sein. Ich beziehe mich auf eine Armlänge am Schreibtisch.
4090 kaufen, DLSS + DLDSR 2,25x rein und gut ist. Liefert knackiges Bild und da muss man auch nix nachschärfen. (y)
Naja bei 77 Zoll ist die PPI auch deutlich geringer . Also in CP2077 sehe ich auf einen 32 Zoll UHD Bildschirm kaum bis kein Unterschied zwischen nativ , dlss Qualität und Performance.
Mit 2 Flaschen Wein drin muss ich auch nix mehr nachschärfen.
Spiel mal Dying Light 2 in regenszenen mit DLSS. Da haste teilweise verschwommene Flecken im Bild. Bei Nativ nicht.
Das sind keine RT-Charts von TPU. Ich hab Metro erst vor zwei Wochen mit der 4090 durchgezockt, ich hing da mehrfach bei <60fps in UHD und max. RT. 182fps, lol. DOOM dasselbe, das ist auch nicht RT. Und genau da liegt das Problem, da wird AMD selbst hinter Ampere und eine 3090 zurückfallen, wenn RT stark genutzt wird. Der Abstand hat sich mit Ada+RDNA3 im Vergleich zu Ampere+RDNA2 sogar vergrößert, wenn man AMDs eigenen Benchmarks trauen darf. Das ist traurig.
Daher auch ein derart niedriger Preis, sie können bei dieser Performance schlicht nicht mehr verlangen. Hätten sie sonst getan, denn Raster wird die 7900XTX auch vor einer 4080 liegen, sogar mit +50% Speicher. Kriegst du trotzdem nicht verkauft für den Preis, wenn du RT in diesem Performance- und Preissegment derart hinterherhängst. ;)
Wer eine 4090 gekauft hat, hat alles richtig gemacht. Ich glaube sogar, die Preise könnten jetzt demnächst noch mal ordentlich anziehen. Alle, die als Alternative auf AMD gewartet haben, werden/wurden jetzt enttäuscht.
Das Spiel habe ich auch ned.
Lass mich in meiner Blase leben. :o
Werde später mal yt Videos suchen die das zeigen sollen.
Verschwommene Flecken im Regen in Dying Light 2 sind doch einfach ein Postpass Effekt, der mit oder ohne DLSS im Bild sein sollte. Ich hatte eine Mod installiert, die die übertriebenen Postpass Effekte (Lensflares etc.) reduzierte. Ist aber schon ein Weilchen her.
Stimmt, die Mod hatte ich auch installiert. Techland hatte es wirklich übertrieben mit diesen Effekten.
Nur das bei dlss die postprocesseffekte in die hose gingen. ich dachte teilweise meine brille wäre voller fingerabdrücke. auf nativ war es verschwunden.
Da steht doch ganz klar im Balken FSR, wie kann man das denn übersehen? :d
Soll doch jeder Nutzen was er will. Was interessiert mich, ob einer DLSS mag oder nicht?
Auf 4K find ich DLSS ok, mit 1440p oder gar drunter nicht.
Gibt es keinen "DLSS vs whatever" Thread?
DLSS ist so stark Auflösungsabhängig und am Ende auch eine persönliche Präferenz.
Da hast du recht jeder muss das selber entscheiden wie er seine Einstellungen fährt. Die 4090 ist die schnellste Karte Punkt .
das sind meines erachtens die gleichen WLPads wie bei dem Vector der 30gen, den W/mK Wert hab ich jetzt aber nicht mehr im Kopf...
Es sind jedoch 0.8mm, 1mm, 1.5mm, 2mm Pads zu verbauen nicht nur 1mm wie bei der letzten Vector FE Version.
Ausserdem wurde der ursprünglichen geplante Version abgeändert,
das Manual https://www.ekwb.com/shop/EK-IM/EK-IM-3831109900703.pdf sieht 1mm, 1.5mm, 2mm WLPads vor.
Es lag aber ein zusätzlicher Ausdruck bei welcher wie zu sehen ist andere WLPads aufführt.
hab mir die gelid extremes bestellt weil die EK stock nur 3.5 wmk haben.
Ähnliche Themen
Antworten
7K
Aufrufe
583K
