[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Doofe Frage aber evtl. hab ichs verpasst: Wird es von CM ein custom Kabel mit direktem 90° Anschluss geben oder "nur" einen Adapter? Danke
Mal ne Frage überlege von 5950x auf den 5800X3D zu wechseln, Mupitz oder Lohnt es sich ?
Genau das mache ich nächste Woche (5800X3D ist bestellt).
Mit ein wenig Glück verkaufe ich meinen gebrauchten 5950X für 450-500€ auf Ebay. Das Geld wandert dann in die 4090 >_<...
Ich selber zocke und surfe nur mit dem PC und ich kann die 16 Kerne nicht ausreizen. Er war damals ein Fehlkauf für mich... das war noch vor dem Release von Intel 12th Gen und dem 5800X3D...
Da ich den 5950X mit UV auf 4,2Ghz laufen lasse, werde ich vermutlich >20% mehr FPS haben...
So eine Ansprache von Dir vor dem Hintergrund, wie Du die letzten 2 Jahre im Marktplatz agiert hast.
Das ist imho die blanke Ironie :d
Und auch a bisserl traurig, so wegen alter Hase und so.;)
Der Scalper nennt den anderen Troll, fragt sich wer von beiden das größere Übel ist 🤣. Ein Troll labert nur scheisse, ein Scalper zieht andere ab 🤷‍♂️. Das eine mag Nerven, das andere ist aber schädlicher.
Super Kommentar @Dampfkanes 🤟
nur den adapter. kabel gibts doch schon. musst dann beides kaufen
ein kabel von microfit auf microfit wirds sicher geben wenn atx 3.0 netzteile mit diesem anschluss verfügbar werden
Ich habe durch @WilliWonka 's Post dieses weiße Adapterkabel gekauft und heute erhalten:
Immer wieder gerne :)
Widerspreche allerdings @WilliWonka beim Adapter, der User ist selbst verantwortlich für Schäden - der Adapter ist eine Fehlkonstruktion und dadurch gefährlich!
Hast du wohl missverstanden. Ich habe nie gesagt das die User selbst für die Schäden verantwortlich sind. Ich sagte man müsse darauf achten wie man den Adapter nutzt und das man jetzt mit dem Wissen noch vorsichtiger sein muss wenn man die Karte trotzdem benutzt.
Das mit den 3000ern ist halt auch bedingt tunende gedacht glaube ich. Warum sollten sie die 4000 announcen wenn sie doch noch 3000er verkaufen wollen? Hätten sie einfach noch 6 Monate mit den 4000ern warten können, zumindest so lange wie AMD noch nichts Neues hat. 4000er Ankündigen und dann nur gefühlt 10 FEs anbieten können, macht null Sinn, wenn man 3000er verkaufen will. Das macht die Leute doch nur noch heißer auf das Ding bzw hält sie sogar von alten 3000er ab, wenn’s schon Neue gibt.
Die 4090 wird aber schon seit dem August produziert und deshalb gibt es laufende Kosten die gedeckt werden wollen.
Außerdem machen auch Aktionäre irgendwann Druck...
So ganz schlüssig ist diese Verknappungstheorie halt nicht, wie man sieht. Warum sollte man etwas produzieren (Kosten) und es dann nicht verkaufen wollen. Hat so ein bisschen was von der Habeckschen Wirtschaftslehre.
Passt hinten und vorne nicht.
So ganz schlüssig ist diese Verknappungstheorie halt nicht, wie man sieht. Warum sollte man etwas produzieren (Kosten) und es dann nicht verkaufen wollen etc.
Najaaaa. Es wurden 2 Dinge gesagt. Erstens man wollte mehr Verfügbarkeit zum Release haben als RTX 3000 und zweitens man wollte die 4090 danach nur langsam auf dem Markt bringen, das ist dann die Verknappung.
Problem nur das gefühlt genauso wenig 4090 auf dem Markt sind wie 3000er...warscheinlich eher weniger.
Warum weniger? Weil 2000€ hat nicht jeder und trotzdem ist die ausverkauft.
Allerdings beim Start der 3000er gab es die 3080 zuerst und die war so ein guter Deal nach der "schlechten" 2000er das die wirklich jeder haben wollte. Und es war halt eine Karte unter 1000€... da gab es noch mehr Nachfrage.
Es gab auch bisher nur 2 wirkliche FE drops... am 12.10 und 18.10, das ist schon fast 2 Wochen her...
Wieviele FEs wurden in DE verkauft? 200-300?....jaja große Verfügbarkeit..und mind 25% davon landeten auf Ebay und co...
Eine Verknappung verärgert meiner Meinung nach nur die Leute.
KEINER der eine 4090 kaufen will, würde jetzt eine RTX 3000 kaufen bzw hat sie schon. Gegebenenfalls wären noch ein paar GPUs mehr auf dem Gebrauchtmarkt...hmmm
Im Grunde sollte Nvidia JETZT alles raushauen was sie haben, damit die Leute vor dem Release der RX7900XT bereits mit 4090er gesättigt sind. Das würde z.t. verhindern das AMD mehr Marketshare bekommt...
Aber ihr wisst ja ein Ingenieur ist noch lange kein Marketingexperte...
Hat hier jemand zufällig auch das Problem, dass die 4090 nach dem Zocken (CODMW2) nicht mehr in den Zero Fan Modus geht? (bei mir aktuell die Gainward 4090 PhantomGS). (-> durchgehend 30% Lüftergeschwindigkeit, egal welche Temps) Erst nach dem Neustart schalten die Lüfter wieder ab.
Ist die Battle App noch am laufen? Die verbraucht schon etwas GPU-Leistung. Hab es bei meiner 3080 auch, dass die Lüfter weiter drehen. Die App beenden oder minimieren, dann hören die Lüfter auf zu drehen, bei mir.
Das ist der Peak-Takt. Der Durchschnittstakt unter Last sieht ganz anders aus.
Der hängt auch von der Kühlung und so ab...ich meine ab 80°C geht der Takt langsam runter beim 5800X3D.
Testen geht erst, wenn ich den nächste Woche habe. :d
Da mein 5950X STOCK 85°C-95°C warm wurde mit einem Kern auf 5Ghz@1,5V, erwarte ich aber deutlich geringere Temperaturen. Da der 5800X3D nicht so eine hohe Spannung hat. Habe eine gute 280mm AIO.
Das Lüfterproblem/Idleproblem kann was mit Nvidia Reflex und low latency zu tun haben. Es wurde so beim Treiber als Bug reported.
Sobald man beides nutzt und das Spiel dann zu macht, geht die GPU nicht mehr richtig in den Idle.
So sehe ich das auch. Damit verdienen die ihr Geld, mit dem Verkauf, nicht mit dem Nicht-Verkauf.
Ich streite nicht ab, das Knappheit durchaus was am Oreis des Artikels bewirkt, sieht man ja jetzt auf EKA/eBay. Aber davon hat Nvidia nichts. Die haben einen Preis gesetzt und die Leute würden denen die Karte für aberwitzige 2000€ aus der Hand reißen, wenn sie verfügbar wäre.
Macht wirtschaftlich keinen Sinn nur 10 FEs auf den Markt zu werfen, wenn man mich fragt.
Okay...
Jedes Produkt hat einen sog. "Lebenszyklus". Im Idealfall hast du am Anfang einen Hype, weil das Produkt richtig neu und aufregend ist. Das verleitet dann zum Kauf (wie Blöde). Wenn du geschickt bist, kannst du diesen Hype aufrecht halten. Wie? Du machst das Produkt exklusiv. Exklusiv im Preis, exklusiv auch durch Verknappung. Es muss schwer sein das Ding zu bekommen. Dann bleiben die Leute dran. Sie "wollen" es. Sie dürfen niemals das Gefühl haben, dass sie es morgen auch noch mitnehmen können. Man muss regelrecht dran bleiben. Dann fühlt es sich auch wertiger an, wenn man es geschafft hat das Ding zu besitzen (man "darf" Geld ausgeben - das Geld muss komplett in den Hintergrund rücken).
Warum will man das so haben und warum will man das noch im letzten Quartal des Jahres haben? Aktionäre und Aktienkurs. NVidia hat fallende Kurse hinnehmen müssen. Das macht Aktionäre und Investoren skeptisch. Dein Unternehmenswert droht noch schneller noch tiefer zu fallen. Du MUSST als CEO gegensteuern. Und die Lederjacke hat das kommen sehen. Der wusste was mit seinem Kurs passiert wenn der Mininghype einbricht. Also hat er bereits die Weichen für einen neuen Hype gestellt. Diesmal müssens die Gamer wieder richten. Er steuert regelrecht die Marktnachfrage. Alles was er dafür brauchte war ein Brett wie die 4090. Der Plan dürfte ziemlich schnell entstanden sein als klar war, dass man bei TSMC in einem besseren, kleineren Ferigungsverfahren einsteigen kann. Deshalb laufen die Dinger auch außerhalb des Verbrauchsoptimums. Er brauchte den Vorschlaghammer für den nächsten Hype.
Und was machen all die, die sich das nicht leisten können? Die bekommen großzügig die Vorgeneration. WENN ich jetzt dann irgendwas von AMD kontern muss, dann überschwemme ich den Markt mit Billo 30xx Karten. Dafür müssen die restlichen 40xx Karten dann aber auch nimmer so weit von den 30ern weg sein. Das kann ich steuern. Die lasse ich einfach weiter im verbrauchstechnischen Optimum laufen. Das ist auch ein suuuuuper Verkaufsargument und ich kanibalisiere meinen alten Bestand nicht so. Wenn ich nachlegen muss (TI Modelle), dann bewege ich mich einfach noch ein bissl weiter vom Verbrauchsoptimum weg. Beim Vorschlaghammer halte ich weiter die besten Chips zurück, dann kann ich auch da nachlegen wenn ich muss. Muss dann aber super teuer und super exklusiv sein - die nächste Hypewelle sozusagen.
Kapiert warum das so läuft? Den Markt am "Haben wollen" halten. Immer auf Zehenspitzen halten. Ich brauche dafür zwar immer das Bisschen mehr. Aber wenn ich das habe, kann ich dafür verlangen was ich will. Und ich brauche auch nicht unmengen zu produzieren (wird eh immer schwieriger), so dass am Ende mein Reingewinn nur noch höher wird. Das kannst du wirklich so machen. Dafür musst du aber die Führungsrolle im Duopol haben. Wenn der Zweitbeste nicht mithalten kann, wird er deiner Strategie trotzdem folgen - er will ja auch Gewinn. Wir werden also ganz sicher sehr teuere AMD Karten sehen. Genauso wie bei den Prozessoren.
Es geht nich um die schnelle Nummer. Du musst etwas langfristiger denken, dann kannst du langfristiger den Reingewinn oben halten und damit deine Aktien wieder pushen. Wichtig ist wie das Unternehmen dasteht und wichtig ist wie gut und unverzichtbar man als CEO ist. Ich glaube viele unterschätzen Jensen. Der Mann ist ein sehr guter CEO. Ob man ihn als Person mag oder nicht, aber das kann man nicht abstreiten.
Ich hab Jensen eine E-Mail geschrieben - mit dem Verweis auf deine Wirtschaftskenntnisse. Er meinte, du kannst ab 01.10. seinen Job haben. Brauchst nur mit einem Waschbecken in der Hand in die Lobby vom Headquarter laufen. Die Pförtner wissen Bescheid.
Kleiner Spaß, wir wissen alle nicht, was die tatsächlich im Vorlauf (3000er) haben. Deswegen ergibt die Spekulation wenig Sinn.
Produkte ohne Konkurrenz sind immer Sonderlinge im Markt. Die 4090 ist so ein Sonderling
Noch mal, hab deine wall of Text nur überflogen, aber Nvidia verdient kein Geld wenn sie keine Karten verkaufen und so wenige wie sie da auf den Markt gewirfen haben, kann man sich nur schwer mit „auf den Zehenspitzen halten“, erklären.
Die würden richtig Schotter verdienen, wenn sie genug Karten hätten. Alleine was hier im Thread bereits FEs storniert wurden. Alles GEWINN der nicht erwirtschaftet werden kann. Das man das freiwillig so handhabt, weil es wirtschaftlich Sinn macht, kann man nur schwer nachvollziehen.
@Über mir, der Elon Verweis hat mir echt ein Gruß Grinsen ins Gesicht gezaubert. Hab heut morgen beim Gucken der Nachrichten schön blöd geschaut.
Die Diskussion und Spekulationen macht null Sinn, klar, aber noch weniger Sinn macht es für mich die Situation mit „absichtliche Verknappung“ zu erklären.
Das Kabel macht einen soliden Eindruck... allemal besser als der Olle Adapter, der dabei war.
-1 Zykle = 28 verbleibend :fresse:
Keine Ahnung ob das stimmt:
@webmi: gut, dann bleib bei deiner Meinung. Unternehmensstrategie und Märkte sind dann nicht so deins, denke ich.
Langfristig denken, alle hier Wirtschaft studiert?
Der Markt an potenziellen 4090 Käufer wird nicht mehr. Es gibt in dieser Nische eine bestimmte Gruppe an Bekloppten, die bereit sind 2000€ für so ein Teil zu bezahlen.
Oder glaubst du, jetzt wo das Ding knapp ist, stehen Leute auf, die sich deshalb dazu entscheiden eine zu kaufen? Was ist das für eine Logik? Da muss man von Wirtschaft noch nicht mal Ahnung haben, um zu merken dass das nicht so ganz einleuchtet.
Der Bedarf an diesen Teilen ist fest definiert. Es gibt nur eine bestimmte Anzahl an festen Käufe(r)n.
Stelle ich die zur Verfügung, decke ich den Bedarf, erledigt. Geld verdient und recht viel mehr werd ich von den Dingern auch nicht verkaufen.
Wo siehst du hier den Vorteil das über Wochen hin zu strecken, ggf sogar potentielle Käufer zu verlieren, denen das zu dumm wird anstatt solange alle heiß drauf sind, abzugreifen was geht?
Du scheinst von Unternehmensstrategien und Märkten viel Ahnung zu haben, Evtl kannst mir da noch kurz beim Verständnis helfen.
Okay...
Streite ich nichts von ab...außer das mit dem Miningkursfall.
Wenn Jensen gewusst hätte das der fällt, dann hätten sie nicht soviel überproduziert und würden jetzt nicht auf einen Haufen RTX 3000 sitzen.
toll nu ist mein riser anscheinend abgeraucht. vga led leutet, karte geht noch auf nem anderen board.
Verstehe ich net obwohl der 5900 Höher Taktet ?
5800x3D 4551Mhz
5900x 4849Mhz
weil es spiele (engines) gibt, die besser auf den großen cache des 5800x3D ansprechen als auf den takt bzw. wo der cache mehr bringt als der takt.
Ähnliche Themen
Antworten
7K
Aufrufe
585K
