[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was meint ihr, lieber ein neues Netzteil holen mit 12vhpwr, also dann ATX 3.0 (Habe gerade BeQuiet Straight power 11 850W). Oder kaufen der Cablemod Adapter + BeQuiet 12vhpwr Adapter?
Beides geht! Würde aber an deiner Stelle das Netzteil behalten und den 12VHPWR beim Hersteller beantragen! Erst wenn die sich weigern zu Cablemod oder BeQuiet greifen.
Ich zweifle Buildzoids Erfahrungen nicht an. Aber...
Seh nix
Kann mir aber vorstellen, worauf das hinausläuft. Sicherlich, irgendwann siehst du auch Kabel und Stecker glühen. Der Schaden wird aber als aller erstes direkt im Stecker stattfinden. Auf den Schadensbildern habe nie geschmolzene Kabel gesehen. Es war bislang immer der Stecker (der Abschnitt, der in der Buchse steckt) und oftmals die äußeren Pins.
hm, habe die FE. Also NVIDIA nach einen neuen Adapter fragen? Die haben doch noch nicht mal Stellung dazu genommen oder?
Gebrochene Adapter? Ich sehe nur Verschmorte
Achte darauf was da auch steht "[1] - The adapter cracked but not yet melted. I put it on the list for overabundance of caution"
Hier is der gebrochene der auch in der Liste im Megathread mitgeführt wird ( is der letzte in der liste und extra markiert worden )
Die Dunkel Ziffer der Fälle wird auch garantiert höher sein als das was bisher öffentlich bekannt ist da ja nich jeder sein Kabel begutachtet auf dauer
Ja direkt beim Hersteller anfragen, von wo du die Karte her hast oder eben Händler je nachdem, wo du es gekauft hast. Da ist es bei jedem etwas anders in solchen Fällen. Die einen kümmern sich als Händler andere verweisen immer auf den Hersteller.
Würde mich auf jeden Fall bei allen zusammen erkundigen und mal schauen, ob was kommt.
Kannst aber vorab ja einen Adapter besorgen und wenn du dann Glück hast und einen kostenlosen Ersatz bekommen solltest, den behalten und den, den du selbst gekauft hast entweder noch zurück schicken oder verkaufen. Viel Erfolg!! :)
Seh nix
Sollte jetzt gehen...
Ich kann nur aus eigener Erfahrung sprechen, dass ich zu heiße Stecker gefunden hab, bevor man sie nicht mehr anfassen konnte
Bei vielen WB-Cams kann man ja den Emissionsgrad einstellen. Oder ganz simpel - man beklebt die zu messende Stelle, mit einem Material, mit der die Cam besser klar kommt (macht man zb bei Glas oder poliertem Metall)
Guten Abend zusammen.
Für Corsair und co scheint es ja Kabel zu geben aber wie sieht es mit Asus Seasonic aus...weiß da jemand was zufällig?
Dank im voraus.
Viele Grüße
Ich bin aktuell gut versorgt. Nutze aber "nur" ein 750W Platinum Bequiet E11. Das läuft locker mit der 4090 bei mir. Ich werde mir aber trotzdem wenn verfügbar das BeQuiet Kabel holen. Oder vielleicht sogar noch da Amazon Kabel bestellen und begutachten.
Alles klar, danke!
Dank im voraus.
Viele Grüße
Seasonic bietet im Zuge des Kaufes eines 1000/1300 Watt Netzteils seit dem letzten Jahr auch einen hauseigenen 12VHPWR Adapter Kabel an! Soll nur limitiert sein also wird man Glück brauchen. Ich hab heute angefragt.
Dank im voraus.
Viele Grüße
stand jetzt nur drittanbieter wie cablemod
seasonic will eventuell ein 90 grad kabel bringen
Benutzt du aktuell das Standard Nvidia kabel? Ich weiß auch nicht so recht, habe ein 12900k und AIO 360mm. Reichen dort noch die 850W?
Danke Euch.
Hab die erste Revision vom ASUS ROG Thor 1200P Netzteil 1200 Watt.
oder im configurator
ja ich nutze das original Kabel. Schon eine Woche jetzt. 850W reichen locker. Ich nutze 750W für 13700k und 4090 :)
Nichts neues und eine völlig normale Reaktion die kommen musste. Weil man das schlichtweg erwartet. Sagt am Ende noch nichts aus was passiert.
der laden wird aber gerade überrant....
hab vorhin ne nachricht gelesen wo die mit über 400% nachfrage bombadiert werden
Mal ne blöde frage. Ist es nicht besser bei meinem NT den oc Knopf nicht zu drücken? Dark Power 12 pro 1500W 😄😄😄
Nun kurz meine Erfahrungen.
Ich nenne es Glück und Zufall eine Suprim X bei Alternate bekommen zu haben.
Spulenfiepen kann ich überhaupt nicht feststellen.
Die Karte wird selbst bei über 500 Watt keine 67 Grad warm bei ca 50 Prozent Lüftergeschwindigkeit.
Erste Versuche bringen über 3 GHz.
Wasserblock ist bei ek bestellt.
Ehrlich gesagt schon fast zu schade die schöne Karte dann zu zerlegen.
Der Kühler funktioniert einwandfrei.
Nur dieser Adapter ist ... ja mein eigentlich tolles Netzteil da bleibt wohl nur warten oder CableMod übrig.
Werd bei Asus aber mal anrufen...vielleicht gibt's ja ne Lösung das man das Kabel was bei der neuen Revision vom Thor beiliegt zu bekommen.
PS. Les hier schon seit ein paar Tagen mit...scheint ja noch mehr auszuarten als bei der 3090 damals.
Ich habe meins bei ModDIY bestellt, da ich nur ein 2x8-Pin auf 16-pin (Nativ) wollte und Cablemod nur 3x8 und 4x8 pin anbietet...
Quasi das Kabel von Corsair, aber anderer Anbieter :P
Nee über Kleinanzeige bei einem persönlich heute. Lief alles perfekt zum Glück.
Ja meinte ich doch mit EK. Hatte sie dort auch gesehen. Hätte schon fast mal eine gekauft. Aber ohne Garantie sind mir über 2000 Euro doch zu heikel. Die TUF ist auch gut. Vielleicht bekomme ich ja auch mal eine FE ab und nicht nur jene welche sie gar nicht zu schätzen wissen und bei EK reinsetzen.
Ich bin auch am überlegen, ob ich die nicht einfach einbaue, aber keine Lust, dass mir der Adapter da weg schmorrt. Doch nicht die schöne FE xd.
