[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mal ein kleiner Helfer.
was unter umständen 1 regler ausmachen kann :)
192fps oder 124fps 4090 am anschlag.
Ich bin echt krass happy, dass ich gestern eine bekommen habe. Aber ich hoffe das ist kein Rückläufer und die Lüfter sind top. Dann werde ich das Kapitel 4090 farming schließen. Wenn nicht geht's mit der Suche weiter...
Leider hat Hermes es nicht geschafft die Karte heute zu liefern und morgen bin ich unterwegs :(
Meine scheint neu zu sein. Zumindest war nichts aufgerissen. Ich überleg aber immer noch, ob ich nicht noch versuche eine Strix oder TUF zu bekommen und die FE dann zurückzuschicken.
@Stagefire Man könnte natürlich auch die TUF-OC und die STrix Non-OC vergleichen. Aber drauf will ich nicht hinaus.
Mir geht es um die Frage die günstigste 4090 (TUF non-oc) weniger Performance hat als die teuerste 4090 (Strix oc).
Is sicher für die meisten vernachlässigbar der unterschied ... denke mal die Strix wird besser gebinnt sein als die TUF
vielleicht schafft man da auch mehr mhz bei weniger Watt .. kein plan.
Das gute is doch das da für jeden ne Karte dabei is ... nur leider sorgt das mehr an Vielfallt leider nicht für ein mehr an Verfügbarkeit
erste geh versuche mit der FE
+330 und +1600
da geht noch was ;-)
@Youngtimer
Wenn man nicht auf Punktejagd gehen will, wäre der Aufpreis zur Strix herausgeworfenes Geld
Dafür gibts nen richtig schicken Block aus USA :d
Oh, die liefern den sogar mit den sauteuren "Fujipoly´s" :oops:(y)
Wenigstens haben wir Spaß dabei wenn uns schon die Hütte abbrennt durch ein verschmortes Kabel.
Beeil dich 1.950€ ist ein klasse Preis. Und das Ding ist verdammt wertig :) (sorry, Suprim)
Nope .. erstmal warte ich nun den 3.11 ab was AMD so gezaubert hat ( dadurch das ich in den über 2 Wochen nun keine abbekommen habe erleichtert es mir nun das Warten auf AMD )
.. wenn von AMD aber nix besseres kommt dann warte ich erstmal ab was noch so beim Adapter Fall so rauskommt und bis die Verfügbarkeit besser wird sodass dann eben auch ein
Menschliches Wesen genug Zeit hat in ruhe zu bestellen... weil diesen Mumpitz der grad da läuft mach ich erstmal nich mehr mit das alles sofort weg is und man nur 1 min max zeit hat zum bestellen.
Wurde nicht bereits im Netz die Info verteilt das AMD nichts besseres als die 4090 auf den Markt bringen wird ?
kleines update hab die TUF mal auslaufen lassen
bei meinen anvisierten 118fps bei 100% load ist das coil whine absolut ok. man hört es wenn der spielsound ausgeschaltet ist.
sobald man ein bisschen sound vom spiel hat, isses nicht mehr wahrzunehmen.
karte bleibt :)
ob 70% oder 85% PT. Coilwhine verändert sich nur sehr sehr gerinfügig.
das ist 3440x1440 & 200% auflösungskalierung :d
Mit welcher Begründung? Die Asus Karten sumsen wie die Bienen und die FE steht denen von der Wertigkeit in nichts nach. Okay evtl. n ticken kühler aber sonst?
Im Netz werden täglich sehr viele "infos" verteilt .. aber ich warte erstmal den 3.11 ab bis dann AMD selbst die Infos Verteilt :d
Ich glaub zwar auch nich das sie an die 4090 rankommen und bei Ray müssen sie auch derbe zulegen was ich ihnen auch noch nich zutraue
aber da es nun nur noch weniger als 1 Woche dauert bis AMD Offiziell die Karte vorstellt warte ich nun diese Tage auch erstmal ab ... ich hab nun zeit
da ich mir diesen Mumpitz mit der Nicht Verfügbarkeit der 4090 erstmal nich mehr antuhe das hat mir die letzten 2 Wochen erstmal gereicht.
Eine Minute? Wo hat man denn so viel Zeit bei normalen Preisen???
weniger punkte mit besserer cpu? :d
achso das andere war der 12kerner
So heute die Gigabyte Gaming OC Version abgeholt. Man war das ätzend per Zug und mit der Karte unterm Arm, auch wenn die nur ganz wenig aus der Tüte geschaut hat, war das vor allem bei Duisburg ein sehr komisches Gefühl, damit umherzulaufen...
Endlich zu Hause! Online registriert und 4 Jahre erst mal Garantie gesafed! Direkt auch mal bei Seasonic und Gigabyte nach einem vernünftigen 12VHPWR Adapter angefragt, weil dem mitgelieferten Billigteil ist ja nicht zu trauen und bei mir müsste das gar fast 180 Grad geknickt werden, da sie vertikal steht und nach 2-Finger Breite schon Glasdach kommt. Also kann ich knicken mit dem Knicken 🤣🤣🤣🤞
Mal sehen wie lange das lange Warten dauern wird... Aber mir eins extra zu kaufen sehe ich ganz und gar nicht ein! 😤
Da geht noch was beim Takt vom X3D, oder?
Schau mal bitte während dem CPU-Bench, was da angezeigt wird (ich meine "ms")
Denn ich hatte mit starkem CPU-OC (5950X @5,1Ghz allcore) angeblich ein schlechteres fps-Ergebnis, gleichzeitig aber einen viel höheren Score
Ersetzt man die fps gegen ms, kommt das gut hin. Bei dir scheint es zu stimmen. Ich hatte letztens ein seltsames Ergebnis
Hier bei ihm sah das komisch aus...
Wenn er alles im Blick hat, ok
Hat man keine WB-Cam (oder IR-Cam),
Laut Buildzoids neustem Video zu dem Stecker, sind WB-Kameras für diesen Zweck absolut ungeeignet. Auch die Gründe, die er dafür nennt, machen Sinn und decken sich mit dem Fehlerbild. Zum einen ist Plastik ein sehr schlechter Wärmeleiter und zum anderen, zeigen nahezu alle Fehlerbilder einen Schmorschaden innerhalb des Steckers. Den Schaden würdest du demnach mit der WB-Kamera erst gar nicht sehen/ nicht wirklich feststellen können, weil die Außentemperatur deutlich geringer sein wird. Guck mal am besten sein Video.
Mann das nervt echt, da will man den Grünen ~2 Riesen in den Rachen werfen und was ist, kaum welche verfügbar. Das kann ja nur sein entweder sind die so beliebt und die kommen mit dem liefern/produzieren nicht nach oder einmal wieder eine künstliche Verknappung. :wall:
Ich zweifle Buildzoids Erfahrungen nicht an. Aber...
Das hier stammt von mir mit "schlecht wärmeleitenden Steckern"... ;)
Selbst der Stecker schlecht "wärmeleitend" wäre. Die Luft unmittelbar um den Stecker herum bleibt ja nicht kalt (heißer Qualm), wenn das Ding anfängt zu schmoren :d
Ähnliche Themen
Antworten
7K
Aufrufe
587K
