[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Joa... 300 EUR über UVP. Zu dem Preis ist jederzeit eine Karte zu bekommen.
Ich meinte die schon fertigen Kabel die man direkt ordern kann.
Könnte am Preis liegen, ist ja wenn man es richtig liest die Non OC.
kurze Frage zu UV
meine Karte lässt mich nicht unter 875mv gehen?
sobald ich 850 oder 800 einstell crasht alles
/gibts eig schon nen 4090 UV Thread?
@Holzmann du hast deine Suprim X doch stark übertaktet und durch diverse Benchmarks gejagt. Benutzt du auch den Adapter und falls ja, hast du irgendwelche Probleme?
Liegt halt satte 300€ über den Asus Webshop Preis, ist schon extrem frech. Aber dachte eigentlich auch, dass selbst die Teile weggehen wie warme Semmeln...
Hat die Asus TUF (Non OC) eigentlich einen Drei oder Viezack im Gepäck?
Ja nutze den, bisher noch keine Probleme, aber ich hab das Kabel auch noch nicht ab gezogen und es überprüft, mach ich auch erst wenn das BQ Tauschkabel hier ist.
Falls es mich auch erwischt hat mach ich hier eine Meldung. ;)
Kannst doch eben checken. Hast doch noch 29 Zyklen :d
Gab es hier überhaupt schon Fälle von diesen verschmorten Kabeln? Wir haben hier ja auch Leute die mit 10 bis 12 Karten prahlen und alle bis zum maximum ausgelastet haben. Keine Probleme damit entstanden?
Oida, die auslastung ist immer noch nicht die ursache oder der Auslöser. Wäre dem so wären deutlich mehr Leute betroffen 😅
Wenn der Adapter intakt ist, passiert such nix
Ich hatte den nvidia Adapter nur 2 Tage benutzt. Seitdem nutze ich den Be Quiet Adapter und der ist bei mir einwandfrei verarbeitet.
@owned139
Hab vorhin bei meiner Suprim geschaut, alles i.O. bisher. Also jetzt nur noch 27 Zyklen ^^""
Beim wieder reinstecken auch mal explizit drauf geachtet: Ja, es muss "Klick" machen ;)
Bin mal gespannt, ob und wann sich Nvidia noch offiziell zur Schmorbraten-Affäre äußert...
Da wird es einen Link geben, wo dann jeder seinen Adapter einsenden kann und dafür einen neuen bekommt. Natürlich musst Du erst deinen hinsenden :shot::stupid:
Haha und je nachdem wie oft er schon aus und eingesteckt wurde muss eine kleine Gebühr zahlen ^^
Bezüglich Gainward Karten...
meine Phantom läuft derzeit mit 2580@875mv im 10. exodus loop ohne probleme
coil vine in games bisher nicht vorhanden, identisch zu meiner alten EVGA die auch unhörbar war
der Lüfter macht leider irgend ein leichtes eigengeräusch, das hab ich bisher noch nie gehört, werd am Abend nochmal genauer hin hören (wenn ruhe einkehrt), aber es ist nicht nur das luft Geräusch
denke aber das ist auszuhalten... hatte da schon wesentlich schlimmeres hier von asus und konsorten
Zudem schade, dass der lüfter erst bei 1150rpm anfängt, die EVGA konnte man schon bei 750rpm starten
mit gut UV bräuchte es die 1150 nicht
und ärgerlich, dass man nicht unter 870/875mv kommt beim UV aber das scheint ja bei allen 4090 der Fall zu sein -.-
die 2580 sind übrigens nur quick n dirty mal zum anlaufen.. da sollt noch n stück mehr gehen bei feintuning
