[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dein Kommentar klingt leider so als ob wir nicht mehr ganz bei Trost wären...sorry dafür.
Soll nicht so gemeint sein. Gemeint ist am Ende nur das man mit einer SItuation eben vernünftig umgeht.
Es kann halt random jeden treffen, das ist der Stand. Natürlich hat die Mehrheit Glück aber es ist echt bescheiden für den Einzelnen.
Richtig, aber trotzdem muss man wie gesagt auch überlegen ob man es eventuell hätte abwenden können. Ich meine, es gibt ja viele Bilder hier wo man sieht das es nicht gut ist mit dem Kabel. Da sind Probleme vorprogrammiert.
Du kannst das doch aus dem Alltag sogar anwenden für alles andere. Stell dir vor du hast ein Auto (sorry für den Autovergleich, passt aber) und es kommt die Info "Bitte nicht über Sand fahren, weil die Federung bricht" ... dann machst du das doch auch nicht. Du wartest bis der Rückruf kommt und die Federung ausgetauscht ist. Und genau so ist es hier eben auch.
Ich verharmlose das Problem mit dem Adapter an sich nicht. Das ist eine sehr dumme Sache. Aber trotzdem kann jeder für sich entscheiden wie er damit umgeht. Und wenn man das Kabel ordentlich nutzt und vielleicht sogar noch UV betreibt, ist die Wahrscheinlichkeit das etwas passiert einfach geringer. Als Beispiel kannst du hier sogar die 3090 Ti nehmen. Gleiches Kabel aber keine Probleme. Warum? Weil einfach weniger Strom benötigt wurde.
Es denkt ja komischerweise auch keiner darüber nach wieso alle die bisher ein Foto eines verschmorten Kabels auf irgendwelchen Kanälsen geteilt haben, nie ein weiteres Wort darüber erwähnen was Sie mit der GPU gemacht haben und in welchem Gehäuse die GPU war und wie die GPU verbaut war. Es gibt keinerlei Fotos vom einer verbauten GPU. Es wird einfach nur gesagt: "ja, der Adapter schmort vor sich hin" und fertig.
@WilliWonka hast du nicht das Video von Igor gesehen?
Nochmal, ich verharmlose das Problem mit dem Adapter nicht. Ich sage nur das jeder selbst beeinflussen kann wie schnell und was passiert. Wir wissen jetzt was das für Kabel sind und was passieren kann. Jetzt können wir das beste daraus machen bis es eine Lösung gibt. Igor selbst, sagte im Video das der User vor dem PC in der Hand hat wie schnell und ob das Kabel zum Problem wird.
Um das ganze auch mal zu relativieren: Meine Gaming OC, TUF und KFA2 die ich aktuell noch da habe, laufen alle drei bei 3015Mhz und 1,05V ne Stunde durch Speedway.
Die machen alle drei auch >3120Mhz bei 1,1V und waren meine besten Karten bisher.
Von den 9 Karten die ich insgesamt da hatte, hab ich leider nicht mehr alle Zahlen im Kopf. 4 von 9 Karten haben die 3Ghz aber definitiv nicht bei 1,05V gemacht.
3Ghz bei 1,05V sind zwar gut aber nichts was man ewig suchen geht oder man als "rare" bezeichnen könnte. Dafür ist die Quote mit 3 von 9 Karten bei meiner Sample Size statistisch schon zu gut.
Und welche davon findest du am leisesten, bzgl. Fiepen/Rasseln/Lüfter? ^^
Am 24.10. bei Alternate bestellt und am 26.10. wurde sie schon geliefert. Und das zur UVP. Zum Glück auch kein Rückläufer. Alles frisch versiegelt und eingeschweißt.
Aber alleine die Größe im Vergleich zu einer Kreditkarte ist schon beachtlich.
In 3 Wochen kann ich sie dann endlich testen. 😂
Du wirst deine dann aber nicht mehr zurückschicken können^^
Meine Gainward behalte ich nicht, geht demnächst zurück. Das jaulen der Lüfter ist nicht schön für so ein Produkt.
Hier sein Thread dazu, gerne mal durchlesen. Es war von Außen noch gar nicht sichtbar!!!
Mittlerweile werden es immer mehr, weil viele jetzt schon auf Verdacht nachschauen bevor es überhaupt anfängt zu kokeln. Und das ist gut so, besser es rechtzeitig und früh erkennen bevor größerer Schaden entsteht.
Es bleibt spannend was nvidia mit den Board Partnern sich jetzt für Maßnahmen entscheiden.
Ich bin ja mal gespannt wie ein Flitzebogen wie sich der 5800X3D im Vergleich zum 5900X schlägt. Bei 5120x1440 hänge ich bei so vielen Spielen im CPU Limit, hätte ich nicht gedacht. Freitag soll das Teil kommen.
Bitte dann gerne mal berichten, wenn DHL ausm Knick gekommen ist ;)
Ich hab auch zugeschlagen:)
Welche CPU hast du aktuell im Einsatz? Überlege ja auch mit meiner 5700x Möhre...
Gibts auch ne FE mit verschmortem Stecker? Scheint ja primär die TUF betroffen zu sein.
Mein 580x3d ist schon da 🙈 heute gekommen von MF, gestern erst bestellt, morgen kommt das Gehäuse. Fehlt nur noch die GraKa...wenn denn mal eine kfa dropped
BTT, bin auch am überlegen den 13700k anzuschaffen um das CPU Limit etwas zu erhöhen. Schon heftig wie schnell die 4090 dem 12700k die Grenzen aufzeigt (z.B. in Assetto Corsa Competitione mit Triplescreen).
musst du ja nur machen wenn die fps nicht für dich passen :) die neue graka hat ja keine fps abgezogen ;)
Der Adapter ist doch überall der gleiche. Aber vielleicht spielt es bei der Biegung eine Rolle, dass bei Asus als einzigem Hersteller der Connector "falsch herum" verbaut ist.
Habe heute bei einer 4090 FE quasi im Affekt zugeschlagen. Eigentlich wollte ich eine Asus TUF oder Strix haben. Meint ihr, dass die Custom Karten besser sind und sich es lohnen würde erstmal noch zu warten die FE auszupacken? Theoretisch kann man die ja noch 2 Wochen lang zurückschicken, falls man noch eine andere Karte ergattern kann.
passt das Kabel auch an ein be quiet straight power 11 850watt platinum ?
Nein soweit ich weiß hat beQuiet einen 12 Pin Stecker für PCI-E. Cablemod bietet keine solche an für 12VHPWR.
die FE ist gut. die customs sind nen ticken besser. chip ist bei allen random
Ach du hast meine mir die FE auf Ebay weggeschnappt für 2600€. Mein Limit ist 2300€, mehr geht nicht...und bisher gehen die FEs leider für 2500-3000€ weg...NBB verkauft derzeit keine und invites von GE bekomme ich sowieso nicht :(
cm hat für bequiet keine fertigen. musst du üpber den konfigurator machen. ca 50€ als Pro version. +15€ shipping
jay hat schonmal reagiert
GN und LTT werden sicher folgen. hoffentlich schlägt das so große wellen das die grüne bumsbude im sillicon valley mal schneller reagiert
Link von NVidia? Manuell checken? Kommt da öfter was rein? Dachte nur alle paar Tage und dann nach 5 Sekunden weg ;)
Nein, du kannst direkt den Link von der NBB Seite nehmen. Dann bist du noch vor der Nvidia Seite dran :)
Gründe Bumsbude :LOL: Aktuell gehe ich davon aus, dass die Adapter getauscht werden (müssen), wie auch immer das erfolgen wird. Ich frage mich, ob sie das flächendeckend dann auch für 3090Ti machen werden. :unsure:
Visions of botli...
Um die Sache selbst beeinflussen zu können, müsste man als unbedarfter Kunde überhaupt mal die Info haben, das Ding wie ein rohes Ei zu behandeln. Nicht jeder trollt 24/7 im Luxx rum.
Gerade deswegen ist die Sache auch so gefährlich. Viele Stecker schmoren wahrscheinlich unbemerkt vor sich hin.
Wo hast Du denn heute zugeschlagen??? Es gab doch nichts bei NBB? Wie kommt ihr da dran?
