[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ASIC mach 1-2 Steps a 15mhz aus, aber nicht ob sie 3000 packt oder nicht
also bisher kein Spulenfiepen bei 4090 Zotac?
Meine nicht. Alles recht ruhig. Genau wie der Vorgänger die Palit Gamerock.
Meine Gaming OC hat einen default Boost von 2730Mhz. Mit 3Ghz ist sie in Games "stable"... für 30-45 Minuten.
Ich hab's jetzt eine Woche getestet, jeden Tag mehrere Stunden gezockt (Cyberpunk 4k Ultra/Psycho).
Stable ist sie mit 2925Mhz bei 1,05V. Der VRAM macht bei +1000 Schluss.
Ist also eher eine mittelmäßige Karte, schätze ich.
Ps.: Bisher hat noch nichts gequalmt bei mir. :wink:
Dann mach mal Port Royal bei 3 GHz 60 Loops durch. Dann halt ich meine :fresse:
mach Dir mal keine Sorge. Bei zu viel Gegenwind landet die Karte eh ruckzuck auf ebay kleinanzeigen. :d
Trotz der Kabel Geschichte bitte ich den magic drive der Karte hier im thread weiter zu pflegen. :)
Um das ganze auch mal zu relativieren: Meine Gaming OC, TUF und KFA2 die ich aktuell noch da habe, laufen alle drei bei 3015Mhz und 1,05V ne Stunde durch Speedway.
Die machen alle drei auch >3120Mhz bei 1,1V und waren meine besten Karten bisher.
Von den 9 Karten die ich insgesamt da hatte, hab ich leider nicht mehr alle Zahlen im Kopf. 4 von 9 Karten haben die 3Ghz aber definitiv nicht bei 1,05V gemacht.
3Ghz bei 1,05V sind zwar gut aber nichts was man ewig suchen geht oder man als "rare" bezeichnen könnte. Dafür ist die Quote mit 3 von 9 Karten bei meiner Sample Size statistisch schon zu gut.
Da zieh selbst ich, cHio First of his Name, Großmeister des bottings, mein Hut. Windforce für 1950 gekauft, 1h nichtssagende Tests gefahren und für 350€ mehr weiter verkaufen. :ROFLMAO: Stundenlohn kann sich sehen lassen. (y)
Und nebenbei noch der Versuch hier Aufmerksamkeit und Anerkennung einzuheimsen.
Da sollte man lieber weiter im Automoblie Fred sein Fahrzeug selbstbeweihräuchern.
Da mag es vielleicht einen Fanclub dafür geben.
Nachdem wir die letzten beiden Tage fast nur noch über Kabel und Stecker gefaselt haben, dachte ich mir, ich mach mal drei Benchmarks im CP2077:
UV 2610MHz @ 0.9V um die 280W
Stock: 1715 MHz um die 370W
OC 3030MHz @ 1.1V um die 470W
der verbrauch wäre jetzt wichtig. denn die min fps bei uv sind doch etwas niedriger prozentual
Wird Zeit UE5 Spiele!
Welchen Default Boost haben die Karten?
Auch Krücken-Boost, die 3000 MHz in Port Royal 60 Loops schaffen bei nahezu +300 MHz offset?
Die Gigabyte OC hat 2775MHz at Stock Boost, die beiden anderen 2790Mhz.
Ich lass das ganze mal Spaßeshalber den ganzen Abend im Speedway Loop laufen. :giggle:
Um mal die Stats in die realistische Richtung zu drücken: 1,1V für 2880MHz, knapp darüber crasht es bereits. (y)
VRAM macht +2000 und 21 loops port royal. Am Desktop freezt es dafür nach 1-30min. (y)
und jetzt bastelt man sich nochmal ordentlich settings in CP77 und hat genug fps bei deutlich geringerem verbrauch :)
war das max @ 4k ? oder reduziertes RT ?
Das ist aber schon ziemlich crappy für 1.1V, sorry :fresse:
Naja dafür Glück beim VRAM gehabt, bei +2000 sehe ich instant bunte Kästchen.
Ja ist crappy, überrascht mich aber auch nicht. (y)
Ich weiß noch nicht, wie ich diese Freezes vom Desktop (Bild wird schwarz, Festplatte tut dann nichts mehr) bei +2000 am VRAM einordnen soll.
der thread macht keinen spaß.. ist ja eher ein turbochat.. *gg*
@TUF
3GHz sind überhaupt kein problem. es gehen sogar 3090MHz im mittel.. gepusht durch spannung, eingebremst durch temperatur und mit einem offset von irgendwas zwischen 285 u. 300MHz.
habe so in den letzten zwei wochen etliche games gezockt und in den ersten tagen sogar strom und zeit für benchmarks verplempert.
tobi
@HisN
das downsampling gedönz funktioniert aber auch eher selten oder?
in cities skylines kann ich die DL auflösungen auswählen. die gpu load erhöht sich etwas aber das bild verändert sich null :d
Hat das TUF OC Bios die Karte nicht um +45Mhz höher geboostet? :unsure:
Nein. ***** hat schon recht damit. Beispiel:
Die TUF non OC die ich aktuell da habe, hat ein Stock Boost wie oben bereits geschrieben von 2775Mhz.
Wohingegen ich eine TUF OC da hatte, die bei mittleren 2600Mhz blieb.
Die Chipgüte entscheidet. OC Karten sind Verarschung pur, solange der Hersteller die Chips dafür nicht selektieren würde (was sie nicht machen).
Die Gainward hatte hier auch einfach eingebaut und laufen lassen 2775mhz, die aktuelle Gaming OC 2730mhz, wenn ich keinen Afterburner an hätte würde ich keinen Unterschied merken. Etwas weniger Strom, ca 20 Watt braucht die Gaming OC fürs gleiche weniger. Bis jetzt sehr zufrieden, noch nicht gebrannt 🔥. Ich hoffe es bleibt so.
DLSS Quality 4587x1920 Rest am Anschlag und DLSS Balanced, als Vergleich. 0.91V 2610MHz +1000 VRAM ~280W
Ähnliche Themen
