[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Brandgefährlich. Hoffentlich hast du einen ordentlichen Adapter. Manche würden da schon Atemnot bekommen.
Widerrufsrecht :banana:
Wo ist der Unterschied zu Ö oder D?
"For all online purchases made by individuals, you have a 14 days period to change your mind (right of withdrawal).
This period is extended to 28 days if you select a Comfort Pack.
A return number is required to ensure return traceability: you can find it in the hereby section (on products sold by LDLC). The item(s) must be returned in their original condition and packaging. The withdrawal period applies to our entire catalogue with the exception of the exclusions mentioned in our terms and conditions of sale (e.g. custom-made computers assembled by us, unsealed software and consumables).
In order to ensure better traceability of the return, it is recommended to use the return authorization that will be communicated to you by our customer service. Otherwise, the product must come with all useful information, i.e., your contact details and your order details. You have a period of 14 days to return the product from the date of your notification of withdrawal."
Warum nicht?
Hast du Angst das die Spulen dann auf Französisch zu dir fiepen? :fresse2:
Wir lassen mal den Sarkasmus weg. Ich sags mal so: ich würde mein hier verdientes Geld gerne wieder an hiesige Händler geben, die hier Arbeitsplätze bereitstellen.
Nenn mich blöd oder sowas. Aber mein Haus wurde auch von einheimischen Handwerkern gebaut. Bin da halt so.
Und ja, im deutschen Rechtssystem zu bleiben hat natürlich auch was.
Nein, das hat damit nichts zu tun gehabt.
Man muss da einige Kerne deaktivieren. Google mal. Vollschrott das remake
Nein, das hat damit nichts zu tun. Es lag daran, dass ich den Ultra Low Latency Mode (automatischer FPS Cap unterhalb der maximalen Bildrate/V-Sync) nicht im Treiber aktiviert hatte. Das muss man bei den Crysis Games anscheinend machen.
Bei mir läuft es butterweich. Hatte in der berühmten Sonnenaufgangsszene und am Strand mal Drops auf 75-80 FPS, aber ansonsten ist es sehr gut spielbar bei mir.
Kann es sein, dass die 4090er Platinen (nur die nackte Platine) kürzer sind, wie die der 3090er Serie?
@Holzmann ich hab mich jetzt doch schon entschieden das neue bequiet zu verwende nach Igors Video.
~58 grad
Damit +- 1 grad Unterschied. Der kommt mit sicherheit aber vom Anpressdruck der Temperatursensoren. Der hält am Bequiet etwas besser.
450W
Geschlossenes Gehäuse
Du wirst schon noch deine Karte bekommen und bald sogar mit dem Adapter 2.0 :)
Biste dir da sicher ?
Bin mir sehr sicher mit den Handwerkern an meinem Haus. Hab alle Gewerke selbst vergeben und war immer dabei. Viele der Handwerker kannte ich vorher schon, zum Teil aus der Schule
Und zwecks der 4090: wird schon
Kurzes Update zu meiner Inno3D iCHill - mehr wird schwieriger bei 450 Watt:
+ 210 GPU / +1660 Speicher
Morgen / Samstag kommt der Wasserkühler und dann geht es an den Umbau. Ich muss dann mal sehen, wie ich das Siegel auf der Rückseite "entfernen" kann, ohne es kaputt zu machen. Habt Ihr nen Tipp?
Meistens kleben die eh nicht besonders fest, vielleicht mit einer kleinen Pinzette versuchen zu entfernen
Ist Plague of Requiem zur Zeit das einzige Spiel mit bereits lauffähigen DLSS 3? Oder gibt‘s bereits noch mehr?
