[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibt es irgendeinen Trick das das Gigabyte Controller Center läuft. Funktionierte nur nachdem ich die Aorus Engine und RGB Fusion installiert hatte (wollte nur das Geblinke der Gaming OC auf statisch stellen), danach wieder Aorus Engine runtergeworfen und schon geht nichts mehr. Man kann bei der Installation auch nichts falsch machen. Draufklicken und das wars...aber das Controller Center zeigt nichts an...wenigstens passt die statische Farbe jetzt.
Du hast recht?! Woher kam dann das Geräusch? Hab ihn zweimal drangesteckt um auf Nummer sicher zugehen 🤨
Von der gebrochenen "Klemme"? Keine Ahnung ich erinnere mich nicht ob es ein Geräusch gab, aber eine Lücke hab ich auch nicht... ist bündig drin.
Haha, eventuell ist in dem Augenblick endlich mal die PCIe Verrieglung eingerastet, die vorher nicht drinnen war oder du hast phantasiert :stupid::stupid::stupid:
Habs nochmal gecheckt und du liegst falsch. Der Haken hat eine Einkerbung die einrastet. Siehe Screens:
Ist übrigens auch die TUF und die Nummer hat mich jetzt 5 Zyklen gekostet, weil ich das Einrasten nun nicht mehr höre.
Port von einer Asus RTX 4090 TUF. Man sieht diese kleine winzige Nase, richtig?
und jetzt schau dir mal den mitgelieferten Stecker dazu an:
Was fällt auf? Richtig, das Gegenstück ist flach, d.h. er rastet nicht ein, er klemmt nur, ergo kein Geräusch beim Einstecken...
Doch er rastet sehr wohl ein, sieht man nur von der Seite nicht. Hat bei mir immer hörbar geklickt. Schau dir den Pin mal zwischen Stecker und Pinunterseite an da ist er ausgespaart und der Nippl an der Grafikkarte rastet dann da ein. Hab mal versucht ein Bild zu machen man sollte es erkennen können.
Oha da im Verborgenen
Anhang anzeigen 808315Anhang anzeigen 808316
Oha, die Einkerbung habe ich tatsächlich nicht gesehen, die ist mal richtig verborgen. :oops:
Und warum macht er dann jetzt keine Geräusche mehr? Ist er schon nach einem Zyklus ausgenuddelt? Meiner macht auch keine Geräusche :ROFLMAO:
Auch gerade nochmal angeschaut beim NV-Adapter. Die Einkerbung ist aber ultra winzig. Kein Wunder warum ich da praktisch nichts vom einrasten mitbekommen habe.
Dude keine Lust den jetzt wieder rauszuziehen aber wenn die Einkerbung nur ein bis zwei zehntel Millimeter tief ist, dann ist vermutlich schon schwer überhaupt ein Geräusch zu bekommen. 😅
Wer hat sich so ein Schmutz überhaupt ausgedacht? 🤭
Wer war das mit dem Geräusch? Epic Fail 🙋🏻‍♂️
Das kleine Ding ist viel zu winzig um ein Geräusch zu machen.
Ach? Erst war keine Einkerbung da und nun kein Geräusch, obwohl es von mehreren bestätigt wurde?
Das getrolle nimmt hier heute wieder züge an...
Mittlerweile der NVIDIA GeForce RTX 4090 + FAQ Adapterfred hier… :d
Also ich bin überzeugt, auch ein Klick-Geräusch vernommen zu haben, beim installieren des Kabels.
Sehe schon auf EK 4090 insgesamt 6x an und ab gesteckt Rest 24 Zyklen. Eig nur 2 x (Einmal Normal - Einmal Vertical) aber wollte 4x Hören ob er eingerastet ist und ob er danach schon abgenudelt ist oder nochmal einrastet.
Also Effektiv Genutzt 2x aber Theoretisch doch 6x Egal komme euch da nen Fuffi Entgegen das muss aber reichen.
Ich bin ja mal gespannt wie ein Flitzebogen wie sich der 5800X3D im Vergleich zum 5900X schlägt. Bei 5120x1440 hänge ich bei so vielen Spielen im CPU Limit, hätte ich nicht gedacht. Freitag soll das Teil kommen.
Berichte dann bitte.
Also ich habe jetzt selber mal geguckt, in der tat hat mit Drücken also etwas Gewalt (Minimal) der Stecker noch geklickt :oops:
Bild 2. Man Sieht an der Nase er kann einrasten.
Fazit: Minderwertiger Adapter von Nvidia, den man am besten austauschen und nicht (mehr) nutzen sollte, weil er einen Konstruktionsmangel aufweist.
Dann bin ich froh, den NV-Adapter verpackt lassen zu können und mit dem beQuiet-Kabel arbeiten zu können. :cool:
Während der Entwicklung traten Fehler auf, und?
Das ist ganz normal.
Bei dreien bisher und bei allen anderen nicht. Ich habe meine TUF jetzt auch seit 2 Wochen im Einsatz und das Kabel ist immer noch tadellos. Die meisten in diesem Thread haben eine 4090 und kein einziger Stecker ist durchgeschmort.
Den Fakt ignorierst du bewusst. Für dich ist der Fall klar: Alle Stecker sind potentiell gefährlich, aber diese Aussage basiert eben nicht auf Fakten. Du hast weder Insiderwissen, noch gibt es die Fehelrquote von < 0,03% her.
"Es verteilen sich insgesamt vier dicke 14AWG-Leitungen auf insgesamt sechs Kontakte, wobei die beiden äußeren Leitungen an jeweils einen Pin angelötet werden und die beiden mittleren an jeweils zwei Pins. Lötbasis ist eine lediglich 0,2 mm dünne Kupferfolie mit 2 mm Breite pro eingehender Leitung, was für die mittleren Anschlüsse dann 4 mm pro Paar ergibt." IgorsLab
Reicht Dir das als Beleg? :)
Wie jetzt, ist es etwa doch ein grundsätzliches Problem? Dachte, sie lief bei Dir problemlos. Oh,warte, der Fehler liegt beim Nutzer, wenn ich das richtig verstanden habe ;)
Nene, du hast da was missverstanden. Das ist kein grundsätzliches Problem. Das ganze ist einfach durch die Sache selbst ein Problem. Es ist meist so das ales klappt und super läuft, dann liest man aber auf einmal in einem Forum etwas das bei einem passiert ist. Warum das passiert ist, weis natürlich keiner. Auch nicht ob es eigenes Versagen war. Trotzdem werden dann plötzlich Leute die gar keine Probleme haben hellhörig und geben Tipps worauf man achten sollte. Und andere prüfen das dann ebne auch und merken das auf einmal doch nicht alles richtig war, obwohl man nie ein Problem hatte. Das ist ähnlich wie manche auf einmal nachdem sowas in Foren gelesen wird verschmortes Plastik riechen. Davor war das nicht da. Vielleicht Nase zu wegen Erkältung, wer weis.
Ist eigentlich ähnlich wie damals mit dem hochgeschaukelten GTX 970 Drama das nie eins war. Keiner hatte Probleme und als bekannt wurde das die letzten 0,5 GB weniger schnell angebunden sind, haben plötzlich Leute massive FPS Probleme gehabt, die eine Stunde davor noch keine hatten. Solche Themen werden immer hochgeschaukelt und durch Communitys gepusht. Aus den Zeiten, in denen man eine Grafikkarte gekauft hat um einfach damit zu zocken, sind wir längst raus. Meistens wird damit erstmal in Foren gelesen und auf Probleme geachtet.
Am besten glaubst du Igor und machst das was du für richtig hälst. Hol dir besser keine 4090. Bleibt mehr für andere :) Du hast ja nicht mal verstanden was ich gemeint habe.
Ich sehe keinen Hate muss ich sagen. Vermutlich liegt das daran das du generell etwas negativ eingestellt bist. Ist eigentlich nur eine Reaktion auf ein Thema.
