[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Für die LG OLEDS gibts die 19% also immerhin etwas.
Die sind aber trot dessen weit weg von Bestpreisen…
Wait bei 42er sind‘s mit Cashback 942€, dass ist tatsächlich ein sehr guter Preis 👌
Und einer der besten Monitore um die 4090 ausfahren zu können 😇
Kann ich bestätigen.. läuft super mit der 4090 zusammen. Der LG42C2 :)
oh, nach meinem Kommentar.. :d nen weiterer Teaser.. :)
@Scrush
Naja, ich nutze seit dem 3930K die HEDT-Plattformen von Intel und AMD, hauptsächlich weil man viel Speicher drann klemmen kann (früher noch SLI). Das ist schon nen Schritt für mich, das alles über Board zu schmeissen^^
Ich hab gerade meinen alten Threadripper gegen einen 13900K getauscht.
Da geht ja einiges im CPU-Limit mit der 4090.
Nicht überall, aber da wo es wichtig ist ... der HAMMER^^
Anhang anzeigen 808226Anhang anzeigen 808227
Anhang anzeigen 808228Anhang anzeigen 808229
Anhang anzeigen 808230Anhang anzeigen 808231
Anhang anzeigen 808237Anhang anzeigen 808238
Anhang anzeigen 808239Anhang anzeigen 808240
Najaaa was soll man erwarten mit einem Sprung von 11 Jahren :d
Jetzt habe ich das erste mal auch ein Problem mit meiner Strix gehabt.
Ich habe Halo Infinite gestartet und aufeinmal war das Bild weg, die Lüfter sind auf Vollanschlag gelaufen, GPU Daten der Temperatur war im CPU Lüfterdisplay weg.
Musste dann einen Neustart reset machen.
Er ist jetzt wieder normal hochgefahren, aber merkwürdig war es schon.
Hab heute nur das offizielle Bios Update gemacht.
Hab die letzten Tage alle möglichen Spiele zum testen gestartet und hatte nie Probleme.
Jetzt bin ich doch nochmal da.
Hatte jetzt bei Fortnite zwei Mal genau den gleichen Absturz, einmal beim starten und einmal im Spiel gleich zu beginn.
Bin jetzt wieder zurück zum Q Bios und bisher verhält es sich wieder normal.
Das ganze war aber erst nachdem ich das neue Asus Bios drauf habe.
ok ja wenn da noch was anderes dahinter stand ist das natürlich nochmal was anderes
Ich bin jetzt vom ganzen lesen hier doch ein wenig lost….. könnt ihr mir kurz eine Frage beantworten?!
Ich stelle mir derzeit einen neuen Gaming-PC zusammen - alles komplett neu.
Ich denke ich werde mir ein 850 Watt Netzteil holen - KEIN PCIe 5.0.
Brauche ich dazu noch irgendwelche zusätzlichen Kabel um die 4090 - sofern ich jemals eine bekomme - zum laufen zu bringen? Ich denke nicht. Wenn doch - welches?
Danke !
Es ist die Strix OC, also sollte sie ja mehr können.
Mein ganzes Problem ist nur das mir Leistung abgeht und da der Afterburner 90% angezeigt hatte, dachte ich das es da irgendein Problem gibt.
Ich habe beim Timespy zB für mein System Punkte, die ein gutes Stück unter dem vorletzten Platz ist.
Bei der Strix 3080 davor war ich im Mittelfeld.
Das Powerlimit nimmt er ja von den angeschlossenen Leitungen, oder?
Dann denkt er bei mir das nur 3 dran sind.
vielleicht antwortet da einer drauf bald
wie viel PL wird dir als Maximum angezeigt? Solltest du mit GPU Z auslesen können: meine Palit z.B. geht bis 450Watt :
Wenn ich bei Google 3960X eingebe, muss ich erstmal weit runter scrollen, bis da was von Intel kommt. :P
Ich hatte mit vertippt und 3960k eingegeben...da war Intel vorne...
Gerade mal etwas gestöbert und tatsächlich noch was gefunden. Da hat sich die MwSt.-Aktion ja richtig gelohnt :fresse:
Meine Suprim X geht zum Wochenende über die Bucht weg und somit habe ich auch kein Mauspad mehr. Siehe da, es gibt Ersatz für die TUF... https://www.mediamarkt.de/de/product/_asus-tuf-p1-gaming-mauspad-360-mm-x-260-mm-2767386.html
Anhang anzeigen 808242 Anhang anzeigen 808241
Hey super tipp....gleich 3 von dem Mauspad für die Arbeit bestellt....die sind dort ziemlich abgenudelt...
Kann sein, aber wie finde ich das am besten raus?
ohne das alte zu flashen wahrscheinlich garnicht, wobei ... bei der TUF sind Quiet und Perf. BIOS was das angeht afaik gleich, bei der Strix weiß ich es nicht
Danke !
nein brauchst du nicht
nimm ein seasonic Focus GX/PX 850 und schließe die karte mit 3x8pin an.
und peile mal eventuell den 90grad adapter an + ein cablemod kabel
da würde kein atx3.0 helfen
Danke !
Normalerweise brauchst du nur den Nvidia Adapter der bei jeder GPU dabei liegt. Die meisten Netzteile bieten genug PCI-E 8-Pin für 3-4 Stecker....außer du hast ganz kleine... wie 550W und kleiner.
Ähnliche Themen
