[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was ich etwas seltsam finde: Den neuen Connector gibt es schon seit der 3090 TI. Warum wird das jetzt gerade bei den neuen Karten zum Problem? Wir hätten zumindest schon seit April Meldungen hierzu hören müssen, oder?
Bin mir da nicht so sicher. Vielleicht weil die Lastspitzen höher sind ? Oder gerne OC betrieben wird ? Hatte keine 3090TI, kann nicht sagen wie viel die maximal verbraucht hat.
Vielen Dank für eure Tipps, ich werde diese morgen mal ausprobieren.
weil die ti schrottkarte niemand gekauft hat. vll wirds durch die menge jetzt auffälliger
Nach meiner wissenschaftlichen Analyse :unsure: komme ich zu dem Fazit das die Begrenzung des Power Limit mit gleichzeitiger Erhöhung der Spannung, GPU und Vram overclock die besten Ergebnisse erzielt.
9891 Speed Way, bei 75% PL bzw. maximal 338 Watt. https://www.3dmark.com/3dm/81150314?
Also fast 50 Watt weniger als bei deiner wissenschaftlichen Empfehlung und trotzdem noch mehr Score. Nur so meine Meinung ;)
Ja ist nur eine Meinung. Ich habe alle Szenarien getestet und gemessen. Diese Einstellkung ist kompletter Nonsense. Erkläre ich alles in dem Video und möchte ich jetzt hier niicht noch einmal alles aufschreiben.
Aber stell ein was Du willst. Die FPS ist immer die gleiche. Nur macht es keinen Sinn etwas zu overclocken und gleichzeitig per Powerlimit auszubremsen. Nur weil Du hörere Gpu Clocks hast ist es nicht schneller. Du hast nur dfas Risiko eines Crashes erhöht.
Also in meinem 'Corsair 4000D Airflow'-Gehäuse sieht es so aus :/ Die Kabel stehen ca 2-3 cm weit heraus
Hoffe echt, das der 90° Adapter in vertikaler Richtung zusammen mit diesem Corsair '600W PCIe 5.0 12VHPWR Type-4 PSU'-Kabel da überhaupt reinpassen
Viel Luft nach unten ist nicht
GPU ist die ASUS TUF 4090 (NON-OC). Befeuert mit Corsair RM1000x
Stromverbrauch der GPU liegt bei mir im 1440p Betrieb in Cyberpunk (ULTRA/PSYCHO) bei ca 350W. Das gesamte PC inkl Peripherie (Monitor, Maus, Flightstick etc) hat eine Leistungsaufnahme von 490-570 Watt
Oh Man Igor investigativ :d
Bin noch net ganz fertig, aber wenigstens der Einbau ist nun durch. Karte (Phantom ohne GS) läuft tatsächlich ohne Murren und ohne UV mit meinem putzigen 700 Watt Netzteil völlig problemlos.
Extra bissel last drauf gegeben:
4x 3DMark durchlaufen lassen, Cyberpunk ne Stunde und zum Schluss Quake RTX, dort wird das Netzteil am meisten belastet, siehe:
(An der Steckdose ist nur der PC dran)
Läuft 🙏
Anhang anzeigen 808177Anhang anzeigen 808178
Läuft 🙏
Und surrt der Lüfter?
Ich möchte nochmal ein bisschen Feedback abgeben, nachdem ich inzwischen einige Tage mit der Inno3d X3 OC auf Wasserblock unterwegs bin
- Maximaltemperatur liegt bei 45 Grad bisher
- UV 900mv @ 2670 Mhz läuft sehr gut. Die Karte taktet out of the Box nur mit 2750 Mhz.
- Stromverbrauch liegt dauerhaft unter 300W. Das höchste was ich sehe sind 270 Watt bisher.
- Irgendwie geil: In Elder Scrolls Online sind die 100 FPS dauerhaft aktiv, egal bei was und es werden nur 60 Watt genutzt.
- Spulenfiepen nichts zu hören. Selbst in Menüs bis zu 600 FPS nicht.
Das einzige was man als Manko sehen könnte ist das wohl bei Inno3d die Garantie weg ist wenn man den Kühler abnimmt. Allerdings war auf der Karte kein Garantiesiegel und auch auf den Schrauben war kein Aufkleber. Aber da ich sowieso noch keine Garantiefälle hatte, ist das für mich komplett nebensächlich.
Für mich hat sich der Kauf absolut gelohnt, ich habe die Leistung die ich brauche und weniger Stromverbrauch als vorher. Dazu laufen jetzt die Lüfter auf 500 rpm dauerhaft und fahren nicht mehr hoch wenn das Wasser zu warm wird. Ich bin rundum zufrieden. Nur bekomme ich leider die 3090 nicht an den Mann. Das ist echt eine Herausforderung geworden.
p.s. das Kabelset das nach der RMA vom Netzteil weg war, wird kostenfrei ersetzt. Top Service.
Verdammt, das hört sich echt gut an. Wollte die zuerst auch haben, und dann den Alphacool Block draufklatschen, leider ist die Karte dann bei 2 Slots, und das passt in meinem Gehäuse nicht mehr rein, ohne den Radiator zu berühren...
Stattdessen muss ich auf Glück bei der FE Lotterie hoffen, und mir dann den EK Block holen.
Wie kann man die schönste Karte die FE mit nem Wasserblock umbauen???
Dann kannste doch jede andere Karte nehmen...
Welch Schande. Jeder wünscht sich eine FE wegen des Designs und bekommt sie nicht und du willst sie zerlegen. Dann lass uns doch tauschen. Bekommst ne TUF OC. :-)
Die MediaMarkt 19% Aktion ist eben angelaufen, bin gespannt ob die echt ein paar 4090er mit dem MwSt.-Rabatt raus hauen: https://www.mediamarkt.de/de/produc...sg-1-click-oc-nvidia-grafikkarte-2839053.html
Nein.
Von der Aktion ausgenommen sind: Alle Artikel der Hersteller Apple, Blink, Amazon, Microsoft, Xiaomi, Sonos, Liebherr, Miele, KOENIC, AVM, alle Konsolen, Tonie Starter Sets, ausgewählte TV-Geräte der Hersteller LG, Philips und Sony, ausgewählte Samsung Smartphones, ausgewählte Google Smartphones, Samsung Wearables, Drucker, Scanner und All in One Geräte von HP, ebook reader, Samsung Galaxy Buds2 Pro, Roborock S7 MAXV ULTRA, Sony HT-A 3000 DOLBY ATMOS, Canon Selphy CP 1300 Geräte, GoPro Hero9 Black, ausgewählte spiegellose Systemkameras von Sony, Canon EOS RP + RF 24-105MM F4-7.1 IS STM, Canon EOS 2000 D 18-55 +SB130+16GB, Vorbesteller-Artikel, jede Art von Download-/Content-/Gaming-Cards und digitalen Guthabenkarten, Games & Software, Tchibo und Tchibo Caffissimo, Nespresso Kapseln, Fotoarbeiten und -bücher, PC Komponenten, Verträge von und mit Drittanbietern und alle als Fundgruben-Artikel gekennzeichneten Produkte.
Das steht auf der Aktionsseite, bevor jemand fragt.
Das klingt tatsächlich nach Problem. Ich hoffe ja, dass das nur den Adapter betrifft und kein grundlegendes ist.
Hardware ist ausgeschlossen.
Weil ich ein ITX Gehäuse hab, und das nur leise ist wenns mit Wasser gekühlt wird. Ansonsten würde ich den Lüfter auch drauf lassen, aber der würde sowieso dann auf dem Schreibtisch stehen, damit er immer begutachtet werden kann ;)
Und die Tuf ist leider etwas zu lang für meinem geschmack, und die meisten fiepen wie blöd, also kein Wunder das du da tauschen willst haha
Dazu muss ich erstmal eine bekommen, bei den 3000ern hab ich es auch nie geschafft ne FE zu ergattern.
in der aktion ist nur der schund der sonst nicht weggeht
Ähnliche Themen
