[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
beim 13900k testen gestern, habe ich kurz verbranntes plastik gerochen.
mal gucken wie mein bequiet kabel auf der 4090 nachher aussieht wenn ich nachhause komme :d
ja, die einbildung spielt bei sowas auch schon mit. Ich möchte auch nicht wissen wieviele jetzt ständig am PC rumriechen oder schauen ob was angekorkelt ist. Dabei ist es ein stinknormales Problem das immer bei gebogenen Stromleitungen passiert. Man muss einfach nur vernünftig den Biegeradius auswählen. Diese Probleme sind zu 100% hausgemacht.
Ich schaue mir keine Videos an. Ich habe eine 4090 hier und habe getestet was besser ist. Bei mir ist es UV. Da ist mir ehrlichgesagt total egal was bei dir besser ist. Nicht böse sein :)
Bei mir hat UV auf 0.91V bei 2610 MHz auch besser abgeschnitten als nur das Powertarget zu senken... Powertarget runter und Takt rauf kann auch gut Ergebnisse liefern, muss man dann auch wieder ausloten und das muss dann auch wieder nicht sein.bund ich begrenzen die Spannung lieber nach oben hin.
Im TSE Graphic Test 2 geht sie bei mir über 300W zeitweise, um die 330-340 sonst in Games aber 220-300 je nach Auslastung oder drunter wenn sie sich total langweilt...
Eine Kabelverbindung hat das auszuhalten wofür sie spezifiziert wurde. Mit den festgelegten Normen und das wars auch schon. Geht´s kaputt muss der Hersteller haften...ende. Mach mir da gar keinen Kopf.
Also meine Karte brauch fast nie die 300W mit 900mv
Mit 900mV geht sie bei mir auch im TSE GT2 über 300W ;)
Plague Tale: Requiem schafft die 300W auch ohne frame Generation in 5160x2160, so ziemlich genau auf den Punkt :d
Ja, das BeQuiet Kabel brauchte viel kraft um es vollständig einzurasten.
Würde auch jedem empfehlen das nochmal zu kontrollieren mit dem Stecker von BeQuiet. Wenn ihr auch nur den geringsten Spalt seht ist der Stecker nicht richtig drin, keine Ahnung wie das bei den anderen Kabeln ist. Der Adapter von Nvidia lies sich da besser rein friemeln.
Beim be quiet Adapter muss man echt aufpassen und vorher jede einzelne Ader via Zugprobe kontrollieren ob die Terminals überhaupt vernünftig eingehakt sind, sonst drückt man sie unter Umständen hinten wieder raus. Darfst auch wieder keinem erzählen was die sich wieder leisten. Warte immer noch auf ein offizielles Statement zu dem Thema, bis jetzt heißt es nur "melde dich beim Support, wir tauschen sie aus, haben aber aktuell nichts vorrätig..." Danke.
Hast gut getestet! :-) Ich nehme auch UV. Allerdings ist PL oder UV am Ende genau das gleiche. Gleiche Leistung, gleicher Strom gleiche Temperatur
Vorteil PL: Du musst nicht den Sweetspot suchen und kannst nicht crashen
Vorteil UV: Kein Powertargethitting und schwankende GPU Clock
ganz genau. Was das Kabel auch tut.
Korrekt, wenn es richtig genutzt wurde. Aber wenn ich weis das meine Karte so breit ist das ich zwischen Gehäusewand und GPU nur 2 bis 3 CM habe und das Kabel extrem biegen muss, was natürlich nicht vorgegeben ist. Dann ist das ein Fehler des Nutzers. Und hier sieht man sehr viele Bilder wo man direkt sieht das das Kabel viel zu stark gebogen wurde.
Nochmal, jeder weis das ein Stromkabel nicht stark gebogen werden sollte. Das trifft auf jedes Kabel zu.
Hat noch wer glatte 884 mV als Mindest- und Standard-Voltage? Selbst wenn ich die Kurve auf 875 setze legt er immer mindestens 884 manchmal 885 an...was los darein
Warum hast du einen neuen Account?!
Weil ich wegen eines Mitglieds hier gesperrt wurde. Er hat mich wohl gemeldet da ich ihn wegen seiner 4090fe privat anschrieb die er bei ebay reinsetzen wollte. War ein komischer Vogel.
Der Support von HWLUXX hat auf meine Anfrage 1 Woche lang nicht reagiert. Da habe ich das Konto gelöscht.
@WilliWonka Aber Du bist ein normaler User/Laie, kein Profi. Für dich gelten nicht die selben Maßstäbe wie z.B. für einen gewerblichen Zusammenbau. Gibt der Hersteller es dir so an die Hand muss es " Idiotensicher" sein. Sonst dürfte er es äußerst schwer haben eine Haftung zu vermeiden. Es sei denn Du hast grob Fahrlässig gehandelt.
Habe mir ein Thermometer bestellt und werde mal schauen wie heiß der BeQuiet Stecker wird.. die Karte voll auszufahren traue ich mich aber jetzt nicht mehr 🙈
Kannst du dir sparen. Keine Ahnung wie man es schafft die Stecker abzufackeln. Ok ist jetzt nur der Dreizack (Bild), wird aber nicht mal annähernd kritisch. Die Leute wo nicht wissen ob ihr Stecker komplett eingesteckt war oder ist sollten sich mal gedanken machen. Am Stecker ist wie bei den 8 Pin auch ein kleiner Halteclip und den hört man sehr wohl wenn dieser einrastet. Ist das nicht der Fall dann ist der Stecker eben auch noch lose und es kann zu einen Wackelkontakt kommen.
Genau deswegen habe ich das Video gemacht. Du hast eine Meinung und ich eine wissenschaftliche Analyse dazu.
Falsch, ich habe eine Karte hier verbaut die mir zeigt das ich genau das habe was ich schreibe. Deine Analyse dazu ist fürn Hintern. Mal grob gesagt. Da sowieso bei jedem andere Werte auftreten. Man muss da schon selbst testen.
Ggf bei DHL etw. aufpassen wenn man was bestellt. Vielleicht doch nen anderen Versand wählen...?
Schafft es irgendjemand bei MM oder Saturn zu kaufen? Ich habe mittlerweile schon bestimmt 5 x Karten im Warenkorb gehabt und war bereits angemeldet (also musste wirklich nur noch durchklicken zum Bezahlvorgang).
Jedesmal beim Bezahlen fliege ich raus (die Karte bleibt noch im Warenkorb).
bei mir ist es Genauso,Unmöglich da eine Karte zu bestellen
Gute Frage! Ich weiß ehrlich gesagt nicht, ob die 5800X eine iGPU hat:unsure:
Nein hat keine. Das ist dann blöd. Wird Zeit für eine zweit 4090 :)
Habe aber das selbe Problem. Bei mir hat das Mainboard keinen HDMI/DP Anschluß. Auch ich könnte bei Defekt nicht mal den PC nutzen.
Ähnliche Themen
Antworten
7K
Aufrufe
587K
