[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nochmal eine Frage an alle: Hattet ihr nicht auch das Gefühl, dass man ungewöhnlich viel Kraft benötigt, um sicher zu gehen, dass das Kabel zu 100% in der GPU steckt, ohne das dabei noch irgendeine Lücke zu sehen ist?
Nö ging eigentlich ohne viel Kraft oder Gewalt. Wenn es echt schwer reingeht, könnte es schon ein schlechtes Zeichen sein, dass erst die Terminals im Stecker aufgebogen werden müssen. Ist aber schwer zu beurteilen, man steckt ja nicht drinnen... im Stecker. :fresse2:
Ja, deswegen habe ich den Adapter hinter dem Stecker auch relativ unsanft anfassen müssen... Mache mir jetzt schon etwas Sorgen bei dem ganzen Gerede.
Wurde das wirklich so geschriebene oder ist das aus dem Kontext gerissen oder fake, kann das nicht glauben.... Dann wären alle anderen Kabel raus sowie neue netzteile mit passendem Kabel wenn man nur den original Stecker nehmen würde bzw sollte.... Halte das auch für eine Ente
Jup, letzter Absatz im Artikel.
"The chipmaker does warn against using third-party adapters, such as the Cablemod and the upcoming Seasonic one, which will void your warranty — though note that all the cases of melted connectors so far have been with the official Nvidia adapter. Can someone build a better right-angle connector than Nvidia's official adapter? Almost certainly, and it will still technically void your warranty."
https://www.tomshardware.com/news/right-angle-16-pin-connector-may-save-a-lot-of-rtx-4090-gpus
Musste auch keine Gewalt anwenden, liegt aber auch vielleicht daran, dass ich Bizeps wie ein Ochse habe.
ja korrekt. so einfach flutschig wie bei den alten anschlüssen war es defintiv nicht.
Meine Gigabyte Gaming OC taktet im Desktop Betrieb (Idle) nicht runter und läuft laut Afterburner mit 2535 MHz. Kein OC, keine Hintergrundanwendungen an, die die Karte stressen könnten, alles auf Standard im Afterburner.
Jemand ne Idee woran das liegen könnte?
treiber schonmal neu drauf gemacht und vorher mit DDU runter?
Ja, das BeQuiet Kabel brauchte viel kraft um es vollständig einzurasten.
Würde auch jedem empfehlen das nochmal zu kontrollieren mit dem Stecker von BeQuiet. Wenn ihr auch nur den geringsten Spalt seht, ist der Stecker nicht richtig drin. Keine Ahnung wie das bei den anderen Kabeln ist, der Adapter von Nvidia lies sich da besser rein friemeln.
ist aber eigentlich nicht nötig. hab meine 3080ti raus und die 4090 rein, rennt
Danke für den Tipp. Ich hatte dort einen Spalt. Habe dazu mal ein Short gemacht
Update: wie ein User vor mir schon schrieb kann ich den Ldlc Shop bisher auch sehr gut bewerten. Vor einer Woche eine PNY vorbestellt und einfach stornieren können - sehr netter und schneller (englischsprachiger) Support. Geld wurde generell nie abgebucht und passiert hier erst vor Auslieferung - ist auch nicht immer üblich.
Gestern konnte ich noch eine Gainward ergattern und ist heut früh rausgeschickt worden per DPD Tochterfirma.
Bisher alles top.
Kunde, da bekomme ich direkt Kopfschmerzen wenn ich das lese. Wenn be quiet einen speziellen 12VHWPR Adapter für mein fucking Netzteil anfertigt dann kann mich nvidia mal kreuzweise mir ihrem Drecksadapter und ihrem void warranty Geschwafel. Was bilden sie sich wieder ein. :stupid:
Schafft es irgendjemand bei MM oder Saturn zu kaufen? Ich habe mittlerweile schon bestimmt 5 x Karten im Warenkorb gehabt und war bereits angemeldet (also musste wirklich nur noch durchklicken zum Bezahlvorgang).
Jedesmal beim Bezahlen fliege ich raus (die Karte bleibt noch im Warenkorb).
So war das gestern ja auch noch, nur heute will sie es anders und ich habe nichts verändert seit gestern
Ich möchte nochmal ein bisschen Feedback abgeben, nachdem ich inzwischen einige Tage mit der Inno3d X3 OC auf Wasserblock unterwegs bin
- Maximaltemperatur liegt bei 45 Grad bisher
- UV 900mv @ 2670 Mhz läuft sehr gut. Die Karte taktet out of the Box nur mit 2750 Mhz.
- Stromverbrauch liegt dauerhaft unter 300W. Das höchste was ich sehe sind 270 Watt bisher.
- Irgendwie geil: In Elder Scrolls Online sind die 100 FPS dauerhaft aktiv, egal bei was und es werden nur 60 Watt genutzt.
- Spulenfiepen nichts zu hören. Selbst in Menüs bis zu 600 FPS nicht.
Das einzige was man als Manko sehen könnte ist das wohl bei Inno3d die Garantie weg ist wenn man den Kühler abnimmt. Allerdings war auf der Karte kein Garantiesiegel und auch auf den Schrauben war kein Aufkleber. Aber da ich sowieso noch keine Garantiefälle hatte, ist das für mich komplett nebensächlich.
Für mich hat sich der Kauf absolut gelohnt, ich habe die Leistung die ich brauche und weniger Stromverbrauch als vorher. Dazu laufen jetzt die Lüfter auf 500 rpm dauerhaft und fahren nicht mehr hoch wenn das Wasser zu warm wird. Ich bin rundum zufrieden. Nur bekomme ich leider die 3090 nicht an den Mann. Das ist echt eine Herausforderung geworden.
p.s. das Kabelset das nach der RMA vom Netzteil weg war, wird kostenfrei ersetzt. Top Service.
Also bei mir steht nach knapp 8 Jahren auch wieder eine Gaming PC Neuanschaffung an und selbstverständlich bekommt man bei den Leistungsbenchmarks extrem Lust auf die 4090.
Aber holla die Waldfee, man bezahlt 2 - 2,5k EUR für EINE Komponente und dann gehts erstmal los:
- Undervolten/ PT anpassen, damit es keinen Stromausfall in der City gibt und man die Rechnung noch bezahlen kann
- hoffen, dass man die Karte nicht in einen anderen Brandabschnitt stellen muss, weil die provisorisch wirkende Stromversorgung Probleme macht
- hoffen, dass man die Karte im gleichen Raum wie den Rechner betreiben kann, ohne Gehörschutz aufsetzen zu müssen.
Natürlich alles überspitzt dargestellt und ich bin niemand, der nicht gern an Hardware tweaked und Verständnis für die Technologie hat und klar, gibt auch mängelfreie Exemplare, aber come on...
für diesen Preis möchte ich eigentlich stressfreies Plug and Play und allerhöchste Qualität haben...
dauert effektiv 2 Minuten
Macht Sie nicht, wenn du mit nicht einer derer bist die denken das 2 CM ausreichen für den Biegeradios des Kabels.
Kannst du bei allen Customs Designs tun wie du in so gut wie allen Tests im Netz siehst.
Sonst noch Punkte ?
Natürlich alles überspitzt dargestellt unf ich bin niemand, der nicht gern an Hardware tweaked und Verständnis für die Technologie hat, aber come on...
Alles easy. Die ist out of the box gut. Aber man kann optimieren.
Also meinetwegen kann der berichten was er will. Für mich ändert das nichts. Ich schaue seine Test nicht an.
Ähnliche Themen
Antworten
7K
Aufrufe
477K
