[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Meine Gamerock OC hat heute die Biege gemacht. Rechner gestartet, kein Bild. Rote Mainboard LED GPU. Ich so, okay, hast komplett umgeräumt und Rechner bisschen bewegt. Also alle Kabel überprüft und neu eingesteckt. Nix!
3080 rein und zack Bild. Hmmh, shit. Also mal zurück schicken und schauen wie lang der Spaß dauert. Die non OC läuft beim Bekannten, hätte ich mal behalten sollen :)
Naja, es gibt wichtigeres. Mal schauen ob ich ne Neue oder Geld bekomme. Dann sehen wir weiter. So lange darf die EVGA noch bisschen schaffen.
Beste Grüße
Damn. Hmm berichte mal wie der Prozess so abläuft.
Mach ich gerne. Aber wird so wie jede ablaufen. Einreichen, angebot von Händler, eigene Vorstellung durchsetzen, neue Karte bekommen und wieder Geld verdienen. Ansonsten Trauzeugen einschalten.
Beste Grüße
Hab auch zwei Desktop PCs (Seasonic TX-1000 und 850) und nen Benchtable mit 650W BQ NT hier, wenn eine Karte gefiept hat, dann hat sie immer mit allen NT gefiept. Konnte das persönlich auch nie nachstellen dass andere NTs irgendetwas an der Sachlage ändern.
Denke das ist irgendein Urban Myth, den irgendjemand mal erzählt hat und den seither alle gebetsmühlenartig nachplappern ohne es selbst getestet zu haben.
Sofern die Karte selbst singt, dann ja. Im Falle der 3090FE war es aber so, dass die bestimmte Netzteile unerträglich haben surren und quietschen lassen. Mit dem TX-1000 auf einmal Stille. Die Karte selbst war immer okay, nicht lautlos aber kein Problem.
Weil mir die Lüftersteuerung und das Fiepen auf den Kecks gingen und hin zu kommt noch das die Material Anmutung für 2400 Euro absolut nicht das war was ich mir vorgestellt habe.
Der Kühler ist echt Potent aber die Lüftersteuerung hat man nicht gut umgesetzt..
Von 0 RPM legt die Karte bei 66 C plötzlich mit knapp 1500 RPM los was ich klar gehört habe dann nach 2 min bei unter 60C wieder aus und 2 Minuten Später wieder mit 1500 Attacke und das obwohl mein 1000D fast 2,70m weg steht.
Im OC Bios drehte sie bis hin zu 1750-1950 RPM
Ich hab es auch mit festgelegter Drehzahl bei ca 900RPM versucht mit dem AB an sich ganz gut aber jedoch manchmal nach Win Start Start Total Ausfall bei der Lüftersteuerung 0 RPM noch bei 75C also auch keine Option und weg damit !
Ich spiele viel über Lautsprecher und das geht für mich halt gar nicht klar!
Aber vorher so ein TamTam um die Karte veranstalten, um sie dann wieder zurückzusenden. 🙄
Ok hatte im Gaming Bios nur mit Aida getestet. In Dying Light 2 eben 65-67 Grad. Lüfter waren auf 1500-1600 vorher nur 1200. Hotspot 74 Grad. Sollte passen. Morgen baue ich noch seitliche Lüfter ein^^
AIDA Stresstest ca 420 W Verbrauch. Beim daddeln aber auch über 70..Gaming Bios.... Glaube vorne am 420er Radi kommt zu wenig rein...Da musste ich umbauen..
Den Radi an der Seite musste ich rausnehmen, ist mit der Karte kollidiert^^ Jetzt only CPU Wakü...
Ok hatte im Gaming Bios nur mit Aida getestet. In Dying Light 2 eben 65-67 Grad bei rund 400W. Lüfter waren auf 1500-1600 vorher nur 1200.
Nope, nie Probleme gehabt und ich bestelle regelmäßig in DE, auc zu Coronazeiten. Ist das erste mal mit einer Verzögerung. (y)
Aber hier gleich so einen Aufriss zu veranstalten geht gar nicht.
Gab es eigentlich bei jeder 4090 den Adapter dazu, sodass man es gleich an dem vorhandenen Netzteil anschließen konnte? Ich lese viel zwischendurch, dass viele einen Adapter bestellen wollen?
Wenn ja, wird das voraussichtlich auch bei den 4080-16GB so sein? Was meint ihr?
Jetzt ist die Shice dann tatsächlich doch noch hoite gekommen. (y)
So groß ist die Karte gar nicht wie alle sagen, passt doch locker ins Gehäuse. :o
Die Verarbeitung der FE ist schon ziemlich edel. (y)
Die GPU selbst scheint aber eine Krücke zu sein, +150 und speedway kackt sofort ab. Erst +100 schafft nen run, dazwischen nicht getestet, stable wird wohl aber näher bei +100 liegen als bei +150. (Oder ich mache was falsch?)
3GHz wohl wahrscheinlich nicht mal mit Wakü möglich. (y)
VRAM bisher nur +1500, scheint stable zu sein. Mehr habe ich noch ned getestet.
Spulenfappen scheinbar unhörbar, auch dann nicht wenn ich mit dem Ohr an die Graka move. Muss aber noch mehr testen (=ein lästiges Game-Menü finden). Lüfter sind in Ordnung, kein Rattern oder was da auch immer beschrieben wurde?
Leistung ist natürlich abartig, kann nur den Kopf schütteln und facepalmen. DLDSR 2,25x (+DLSS wenn verfügbar) bei 3440x1440 als Grundlage überhaupt kein Thema für die GPU. Das ist ne kranke Shice, komme aber auch von einer 2080Ti.
Schade um die schöne Karte in diesem Durcheinander.
Jede Karte hat einen Adapter. Was die Leute bestellen sind keine Adapter, sondern direkte Anschlusskabel für ihre Netzteil.
Das hat die gedankliche Lücke geschlossen, danke.
Wenn die Lüftersteuerung für mich Broke ist warum darf ich die Karte nicht einsenden?
Das hat nix mit dem Tam Tam zu tun ich hatte mich riesig auf die Karte gefreut die konnte nun mal meine Erwartungen nicht erfüllen.
Jetzt im nachhinein stellt sich heraus das es andere Hersteller viel besser hin bekommen die Tests gab es zum Bestellzeitpunkt nicht!
Ich hab auf zurück senden nie Bock hätte viel lieber heute Abend gezockt als jetzt nicht zu wissen wann ich die Strixx kaufen kann!
Ich habe nicht damit geprallt das ich sie zurück schicken musste.
Hocke hier jetzt auf einer GTX650. :wink:
Wenn man so eine 4090 OOB nutzt, wohin sollte die dann boosten bzw. ab wann ist sie wirklich schlecht?
Alles von 2700Mhz bis 2750 MHz ist so der Standard. Alles darüber oder darunter ist außerhalb. Aber alle sind aktuell absolu extrem schnelle. Also darüber keinen Kopp machen außer man will Ranglisten spielchen spielen.
Beste Grüße
Hmmm... meine TUF OC liefert unter 3D Mark TimeSpy Extreme nur 2670 oder so. Hab hier gelesen, man soll sich die Kurve im Afterburner anschauen im idle was da bei 1.050 V steht. Da stand bei mir am Anfang mal 2715 und jetzt 2700. Nachdem sie auch Coil Whine hat, denke ich dass ich sie evtl. zurückschicke. Das mit dem Takt wäre mir noch egaler. Coil Whine nervt schon. Auf der anderen Seite ist der Kühler extrem gut und leise... ist halt nur das Ding über 2000€ und dann Coil Whine... Ich weiß einfach nicht
Hab jetzt meine mal getestet und muss sagen, dass ich von der Karte wirklich begeistert bin. Lässt man im 3d Mark die Lüfter auf Auto starten diese kaum an. Ist es normal, dass die normale Zotac Trinity 4090 bis auf 2790Mhz boostet ohne irgendetwas geändert zu haben?? Hier hat meine „alte“ 3080 Ti ROG Strix oc keine Chance und wird zudem noch deutlich wärmer.
Würde das nicht verschreien, muss natürlich noch mehr Szenarien testen.
Spiel ein Video hier vor und dann sagen Dir alle die Karte rasselt und fiept 😂
Ich kann auch nur sagen die FE ist de top Karte und ich behalt meine auch. Ich höre da nichts dergleichen.
kommt aber dennoch unter nen wakü-Block das gute Stück, war der plan von Anfang an, sonnst würd meinem Mora ja langweilig 😆
Lass Dir nichts erzählen wenn Du zufrieden bist ist doch alles top.
Hmmm... meine TUF OC liefert unter 3D Mark TimeSpy Extreme nur 2650 oder so. Hab hier gelesen, man soll sich die Kurve im Afterburner anschauen im idle was da bei 1.050 V steht. Da stand bei mir am Anfang mal 2715 und jetzt 2700. Nachdem sie auch Coil Whine hat, denke ich dass ich sie evtl. zurückschicke. Das mit dem Takt wäre mir noch egaler. Coil Whine nervt schon. Auf der anderen Seite ist der Küler extrem gut und leise... ist halt nur das Ding über 2000€ und dann Coil Whine... Ich weiß einfach nicht
wie laut isses? aus dem geschlossenen case das auf dem boden steht herauszuhören?
Can mich nicht beklagen. Nur die +100MHz sind etwas enttäuschend. Werde die Karte trotzdem behalten und auch unter Wasser ballern. Vielleicht gehen sich die 3GHz doch noch aus, aber vllt mache ich einen Fehler beim OCen. Dunno.
Zieh im Afterburner mal den Voltage slider hoch, und setzt das Powerlimit auf Max.
Dann schau ob sieh höher taktet. Wenn nicht mal die Curve auf 3Ghz+ hochziehen ab 1.05V
Als Anhaltepunkt, hab so quick and dirty 10560Punkt in 3DMark speed way damit gemacht.
Unter Wasser wird denk noch etwas mehr gehen
Meine schafft 3Ghz, nötig ist das aber auch nicht unbedingt.
Im 24/7 wird die Karte eh im UV bzw Leistungsreduziert laufen.
An die Gainward Besitzer: Es gibt auf der Gainward Webseite ein BIOS Update. Ändert nix an den Lüftern aber ich kann jetzt auch im Silent BIOS das PL auf 500W setzen über das Gainward Experttool. Steht komischerweise aber nicht im Changelog
Normaler RMA Ablauf.
Beste Grüße
ja moin, hast du mal geschaut: für die Gamerock und OC Variante gabs heute ein BIOS Update. Anbei aus den Release notes:
VBIOS RELEASE NOTE
OBE builds with UEFI 70009 image, resolve no display issue before the driver loading
with some mobo when booting the system.
Habe meine auch seit Tag 1, non OC. Funktioniert wunderbar. poste später ein paar benches
Schon. Es ist jetzt nicht massiv laut. Und mein Case ist sehr offen (uraltes Cooler Master Cosmos S). Lustigerweise am unangenehmsten bei 180-200 fps. Ab 240 wirds angenehmer. Eher wie ein Rauschen. Bei 300 noch besser... sehr strange. Blöd ist aber, dass ich das auch bei 140-150 fps habe. Ich habe schließlich einen 144 Hz Monitor. Es wurde aber gefühlt besser seitdem sie läuft. Klar, wenn die Spulen wärmer werden, sollte das auch weniger werden. Ich mach morgen mit komplett kalter Maschine nochmal einen Test. Wenns dann wieder schlimmer ist, geht sie vermutlich zurück. Ich hab keinen Schmerz mal >2000€ auszugeben. Aber dann muss es eben auch passen. Meine 3080 hat auch in bestimmten Situationen Coil Whine. Aber da ist der Lüfter sehr viel lauter. Vermutlich isses deshalb so markant.
ja die 4090 laufen leiser. meine 3080ti strix hat das coilwhine welches die hatte übertönt
Blöde Frage: ein anderes Netzteil wird nix bringen beim Thema Coil Whine? Ich habe noch ein eingeschweißtes Seasonic liegen. Auch nur 850W, aber das wäre gleich umgebaut, wenns was bringen könnte.
Bei Ebay Kleinanzeigen verscalpt tatsächlich ein gewerblicher ne FE. Jemand Lust das Ding zwei Wochen zu testen und dann zu widerrufen? :P
Viele sagen nein, ich persönlich habe damit aber gute Erfahrungen gemacht. Ich habe mit dem E11 750W das ich derzeit nutze kein Fiepen mehr erlebt. Davor mit dem anderen Netzteil gab es immer wieder fiepen. Sogar im direkten Vergleich damals war das Fiepen weg beim NT Wechsel. Hochwertige Netzteile sind da sicher eine Option.
In über 10 Jahren hat das nie geklappt. Ist und bleibt echt ein Mythos ^^.
Wüsste auch nicht, was elektrotechnisch sich bei den Netzteilen untescheiden sollen ... außer vill. die Restwelligkeit.
Ähnliche Themen
Antworten
7K
Aufrufe
584K
