[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das ist für mich an der Karte das beste gewesen der Halter.
Wen ich die Kupferheatpipes wieder sehe wir mir schlecht!
Boards kann Gigabyte durchaus schön getalten , aber die Grakas bei denen werden Gen. für Gen. immer hässlicher^^
@Sturmwind80 das wird so sicher sehr gut funktionieren. Welches Torrent Gehäuse ist das?
Das ist das "normale" Torrent. Ins compact oder wie die mittlere Größe heißt passt die Karte nicht rein.
Habe nur die Stütze von der Karte selber dran, da die bombenstabil ist. Soweit ich das bei der Torrent Stütze gesehen habe, schraubt man die nur rechts dran und schiebt einen Arm unter die Grafikkarte und ich weiß nicht ob das bei der Plastikabdeckung der Gigabyte so sinnvoll ist.
Ah ok. Hab nur die Torrent Stütze genommen bisher. Wird wohl umgebaut.
Die können garnichts gestalten, alles hässlich und Müll :D
Das Kunststoff der Master sah so extrem billig aus und dafür knapp 2400 Steine .
Hätte ich doch lieber versucht die TUF zu bekommen bei der Strixx hatte ich kein glück .
Na ja mal sehen vielleicht klappt das in 1-2 Wochen ja.
Hoffe mal die ganzen verrückten haben mal bald ihre Karte .
Das ist ja nicht normal.
Anscheinend hat nur die Gigabyte Master eine schlechte Lüftersteuerung wenn man hier so mit liest.
Oder hier laufen alle mit Ohropax rum?
Die Lüfter meiner Gigabyte waren nur mit 50% Top leider funktionierte das überschreiben mit dem AB nicht immer !
Der Silent Mode war für mich mega schlecht von der Lüftersteuerung her bis 65 C 0 RPM mit Zero Fan dann Lüfter Start mit 1450 -1500 RPM nach 2 min ca wieder 0 RPM nach 2-3 Mint 65 C wieder 1500RPm das ging mir aus ca 2,50m total auf den Geist .
OC Modus bis knapp 2000 RPM da kriegt man einen an der Waffel.
Fiepen Suren nur unter 400W okay aber immer noch minimal vorhanden wenn man nah ran ging .
Und die Material Anmutung OMG
Vllt. kommt da noch nen BIOS update für ne bessere Lüftersteuerung?
Hier ein Bild von dem guten Stück. Die Karte wird natürlich auch schon gut von den Gehäuselüftern gekühlt.
Mit Sound kann ich leider nicht dienen. keine Ahnung wo ich das hochladen soll.
Den GPU Halter sieht man oben rechts. Dieser wird an zwei Mainboard-Schrauben befestigt und die Verankerung schraubt man rechts an die Grafikkarte.
Wasn fetter Kühlkörper, glaube das is der dickste von den ganzen AiBs
Ja das Teil ist ein ganz schöner Brocken und da ich kein Fenster im Gehäuse habe, ist mir das Aussehen auch egal. Gibt ansonsten sicher schönere Karten. :bigok:
Ist mir egal die Karte ist weg.
Und nein den Größten Kühler hat die Master 4 Slot 358.5x162.8x75.1mm
aber in Natura hässlich wie die Nacht!:ROFLMAO:
Edit doch hast recht die Gaming ist ein müh dicker
340x150.2x75.2mm
Hey, ich konnte mit Hilfe von Ralle eine 4090er über Alternate ergattern. Nun steht aber unter Lieferstatus: "Der Auftrag kann aktuell nicht bearbeitet werden, da einer oder mehrere Artikel nicht lieferbar sind. " Hatte das jemand auch? Eine Storno incoming?
Endlich kein kabelsalat mehr 😩
Da kommt keine Storno, aber es gab halt ein Überverkauf und dir wurde in der Kommission keine Karte zugewiesen. Im Klartext "A hat mehr Karten verkauft als sie hatten". Deine Bestellung ist jetzt halt offen und wartet auf neue Ware. Da wirst du bestimmt in ein paar Tagen dann ne Info bekommen, wann das der Fall sein wird.
Dito:
Expressversand hätte das Ganze eventuell beschleunigt...
Meanwhile droppen nochmal 3 Stück der Phantom. Hätte nochmal 2 Cookies im Angebot.
Ich drücke euch die Daumen dass es noch umspringt und sich deren Warenwirtschaftssystem da ned verrechnet hat :(
Dito:
Ja, bei A muss man so Sachen immer per Express bestellen. Eine absolut lächerliche Warenwirtschaft. Und immer einzeln bestellen!!! Wenn ihr z.B. ne 4090 und ein Netzteil bestellt, wo das Netzteil nicht auf Lager ist, dann ist die gesamte Bestellung nicht reserviert!
Ich überlege am Montag Morgen direkt anzurufen und auf Express abzuändern. Hoffe, dass das noch geht. :geek:
Das Problem dahinter ist, dass bei A die Expressbestellungen priorisiert Kommissioniert werden. Sobald eine Express Bestellung eingeht, wird diese vor den "Standard Versand" Bestellungen bearbeitet. Selbst wenn du der Erste bei einer Karte warst, kann es so passieren, dass genug nach dir per Express bestellen und dann für dich keine Karte mehr da ist.
Ja… Corsair bietet nichts an und diesem Cable Pro Gedöns traue ich nicht.
Habe schon ganz viel schlechtes über deren Kabel gelesen.
Warte auch immer noch auf das Corsair Kabel :fire:
Meinst du Cablemod oder Cablepro? Corsairs kabel set hab ich schon ewig in betrieb mit meinem AX850 aber das neue 12VHpwr gibts auch noch nicht gelseeved direkt von Corsair soweit mir bekannt
Hab mal Support von A angeschrieben und dies kam als Antwort. Mal schauen ob es der Wahrheit entspricht. Bis jetzt wurde ich von A nie enttäuscht.
Normalerweise wird im Backend aber der letzte Status beibehalten, dass die Ware im Zulauf ist oä. Aber gut vielleicht haben sie ihre Verarbeitung da endlich verbessert. Ich drück euch die Daumen (y)
Ich auch noch nie. Ist für mich persönlich unter den "großen" Hardwareversendern noch der zuverlässigste Laden. Und der Scalperaufschlag ist dieses Mal auch nicht so drastisch wie bei den anderen Kandidaten...
Hat jemand eine Ahnung warum ich von der deutschen A Seite absolut nicht nach Österreich ordern kann?
A.at hat keine einzige 4090 im Programm
Echt zäh hier in Ö: A liefert nicht, MF auch nicht 🤬
Ich möchte endlich eine 4090 zu einem halbwegs fairen Preis
Und bei mir passen nur: FE, Palit, Gainward und PNY
Okay, gut zu wissen. Behalte ich für die Zukunft im Hinterkopf.
Ah ok.
War doch auch immer die rede das zB mit 3 Kabeln nur 450W Powertarget erreicht werden kann und man deshalb 4 für 600W anstecken soll, oder habe ich da was falsch verstanden?
350€ Zuviel. Heftig, wirklich heftig, obwohl die Karten wirklich besser verfügbar sind, als letzten Launch. Es beginnt von vorne. Mal sehen wenn die 14 Tage rückläufer zurück bei den Händlern sind.
Ja dann gibt es viele laute Karten die zurück gehen :)
