[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
hmm... kann man den Rotz nicht in nem Docker laufen lassen? :d
Hab ich erst auch drüber nachgedacht aber bei nem Docker wollte es nicht richtig klappen mit Sys Infos auslesen. Aber anscheinend spielen die eh keine Rolle, wenn man die letzten Meldungen dazu hört.
Insofern ja Docker wäre ein Versuch Wert. Hab aber jetzt schon ein Installscript für die VMs fertig, daher bleib ich dabei :d
Ist das nicht der neumodische Mist ? Ich würde ja auf Cousin tippen, aber das klingt so uncool 8-)
Also tatsächlich ist das überhaupt nicht neumodisch, bei uns hier ist das Dialekt für Cousin...
Ist allerdings kein richtiger Fix für mich, da er die gewonnene Leistung durch den neuen Treiber wieder um ~5 FPS reduziert. Bin mit diesem "Fix" wieder permanent im CPU Limit mit einer GPU Auslastung von 94-95%. Mache ich diesen "Fix" wieder rückgängig über das SLI Profile Tool, habe ich wieder permanent 98-99% GPU Auslastung und gewinne 5 FPS.
Ah danke für die Info, das wußte ich noch nicht. Mit wäre die funktionierende Map aktuell allerdings deutlich wichtiger als 5 fps, Leistung habe ich mehr als genug im Moment glücklicherweise, es läuft auch so wie Butter :) Schaue mir das nachher aber nochmal an.
Edit: Gerade nochmal getestet. In der Tat, ohne fix GPU Auslastung 99% und 75fps Durchschnitt, mit Fix 96-97% Auslastung und knapp 72fps Durchschnitt.
Die Min-Fps liegen bei mir mit Fix aber 8 FPS höher (49 zu 41), dafür sind die Max-FPS 25fps niedriger (111 - 134). In letzterem liegt wahrscheinich auch der Grund warum ich in der Praxis nix merke, die Max-FPS mit Fix liegen nur etwas unterhalb meines Frame Limiters (117), der größte Teil an Max-FPS den mich der Fix kostet liegen im Bereich den ich eh wegcappe. Die höheren Min-FPS finde ich persönlich nützlicher, insgesamt ist es besser ausbalanciert. Aber definitv kostet der Fix ordentlich Leistung.
Media Markt hat ja noch mit die Fairsten Preise ... aber das Captcha dort macht einen ja Wahnsinnig. In den Warenkorb packen -> Captcha, Warenkorb aufrufen -> Captcha, Bezahlen -> Captcha, Fehler beim Bezahlen, Artikel nicht mehr vorrätig -> Captcha. Wieder in den Warenkorb legen -> Captcha Captcha Captcha.
Auch einmal blödsinn gemacht und Benchmark angeschmissen.
Viel mehr dürfte nicht drin sein mit dem Powerlimit von 490W.
Jetzt aber wieder Sweetspotten, oder wie sagt man dazu? :LOL:
Die werden dir eins Husten... aber beschäftige mal ruhig den Support, denen ist bestimmt total langweilig und freuen sich über solche Fragen. Aber hey, wer nicht wagt, der nicht gewinnt...
Schau mal hier ins MSI Support Forum da findest Du die Antwort. Ich würde mir die Zeit dafür sparen...
Proshop hat die Strix und die Tuf non Oc lagernd, die Non Oc für 2049 Euro
Also was Amazon da mit dem Pricing macht ist einfach nur frech, wollen die nicht eig immer die Günstigsten sein?
