[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Passend zur 4090 eingetroffen :bigok:
Sahneteil, gehe voll steil. Befeuer ihn mit meiner alten 2080ti, und das garnicht mal schlecht
Hart erarbeitet, Entscheidung viel mir nicht leicht, jetzt bin ich froh es gemacht zu haben.
Für 1440p hätte sich die 4090 nicht gelohnt, upgrade nach ca. 5 Jahren..., der Kurs von der 4090 ist schon ekelhaft
ultrawide macht bock :) einige titel eigenen sich hier hervorragend. man muss aber immer mal wieder schauen bzgl. fov.
bei mir gibts monitorupgrade erst richtung oled
voll geil, gerade Btf 5 gezockt meeeegaaaa, cyberpunk oberkrass, das Format ist der Knaller, endlich vernünftige Monitore und Karten
Installier auf keinen Fall Armory Crate, das wirst du nicht mehr los ohne Windows neu zu installieren.
Gibt dafür ein programm namens openRGB, damit kannst du so ziemlich alle deine LED's steuern.
Vielen Dank für das Programm.
Mainboard-LEDs sind damit tatsächlich kein Problem.
Auch mein Keyboard wird gefunden.
Aber die TUF .... Prääääääp.
Schade eigentlich.
Schade eigentlich.
Hab jetzt keine Tuf daher kann ichs dir nicht sagen, aber probier mal die experimental version.
Laut Reddit wurden die RTX3000er TUFs auch nicht von OpenRGB erkannt, aber in der experimental version sollen sie wohl drin sein.
Ein versuch ist's wert.
Nach umbau zum 13900K und ein paar anderen 4090 ist das mein aktuell bestes Ergebnis beim Speed Way
Die 3090 Strix geht mit open RGB. Da wird demnächst mit Sicherheit ein Update kommen für die 40er. Es reicht einmal die Software starten und Beleuchtung auswählen, Profil speichern und schließen. Nach nem Neustart einmal kurz öffnen und load Profile -perfekt. Das Armoury Crate wäre ein gutes Programm falls es funktioniert. Das läuft Monate gut, dann kommt ein Update und zerschießt alles (z. b. 5% Prozzilast bei wechselnden RGB Farben oder Lüfter samt Steuerung gehen nicht mehr, siehe Rog Forum und Du wirst es nur mit Win neu los. Der Taskmanager voller Rog Services usw...)
Hoffe nächste woche gibts paar Strix zu bestellen :coffee3: Am liebsten wäre mir zwar immer noch die Tuf für 1949, aber die muss man erstmal bekommen.
Das stimmt doch überhaupt nicht was Du das hier in den Raum wirfst
ich konnte das in Fall meiner FE nicht bestätigen, es wird bei mir nicht mehr auch nicht bei höheren FPS.
Es ist schade das hier offenbar sehr viel daher geredet wird und anderen inform von pauschalen Aussagen suggeriert wird.
laut diversen test ist die founders edition immer lauter als die customes und hat in etlichen test ein surren sowie spulenfiepen
Jetzt wollte ich grad meinen 13900k auschecken, kickt mir MF den ausm Warenkorb und nun nicht mehr lieferbar. Sag mal was ist denn nur los xD
Ich verkauf den restlichen scheiß auch noch und spiel pacman am Laptop.
... nehme alles zurück, CPU inbound.
Ja ... leider ... k.A. komm nichtmehr dran an das Ergebnis ... Windows Updates dann gabs div. 3D Mark Updates ...
Ich liege auch bei Port Royal trotz höherem Takt (GPU und Memory) weiter hinten als andere.
Vielleicht finde ich den Fehler ja noch.
Glastisch? Wat is da denn verkehrt?
Die Map in cyberpunk wurde übrigens gefixt. K.a. Ob das nen Update von Cyperpunk war, jedenfalls ging es bei mir vorhin. Weil die map seit dem neuen Treiber nicht mehr ging und rumgeglitcht hatte.
Wer bestellt heutzutage noch bei dem Gammelladen MF?
Du kannst gerne kaufen was Dir andere empfehlen, das ist mir relativ egal.
ich für meinen Teil finde es ist eine sehr gelungene Karte.
Was die uns vorliegenden Muster angeht, ist das Störgeräusch (im Englischen "Coil Whine" genannt) etwas auffälliger als bei der RTX 3090 Ti.
Quelle: https://www.pcgameshardware.de/Gefo...t-Benchmarks-RTX-4090-vorbestellen-1404846/5/
kann dir aber auch andere Quellen nennen. aber das mit coil whine ist halt chip lotterie, trotzdem ist es halt fakt, dass die fe lauter ist als die custome karten, daher haben die leute hier nichts falsches erzählt was das Surren/coil whine angeht
Das Update kam von nVidia OTA ohne das man einen neuen Treiber installieren musste, es ist eigentlich nur ein Update im Profil, es werden keine Treiberdateien ausgetauscht meines Wissens. Offenbar kann der Treiber das selbst nachladen.
Ich hatte das schon über den manuellen Weg bei mir gefixt, dazu hat man lediglich die SLI Profile mit einem nVidia Tool exportiert, einen Eintrag angepasst und dann wieder importiert. Fand es lustig das die SLI Profile das Problem beeinflussen obwohl gar kein SLI mehr zum Einsatz kommt.
Der "Gammelladen" hat mir letzten Donnerstag eine Suprim X ohne extra Preisaufschlag verkauft (Suprim X UVP sozusagen), die ich letzten Samstag dann geliefert bekam. Ich kann nicht meckern, mich haben sie bisher noch nie hängengelassen. Ok, sie hätten sich DOnnerstags ein bißchen mehr beeilen können dann wäre sie bereits Freitag dagewesen aber will jetzt mal nicht zu hohe Ansprüche stellen.
was läuft den bei dem game falsch :)
hast du 3 kabel dran?
Ich hab 3 Kabel an der non OC TUF
Ich muss das Programm bei jedem Start öffnen?
Mach doch bitte mal ein Video mit dem Handy vom Windows Boot, Speed Way Benchmark starten und bis zum Anzeigen der Score. :) Natürlich alles ohne Pause.
Sofern ich das nicht sehe, gehe ich immer noch von einem klaren exploit von dir aus.
Bisschen Off - Topic
Welche CPU eignet sich um die RTX 4090 zu befeuern ? Aktuell Game ich noch auf dem 5800X und überlege auf dem 3DX zu Wechseln
Auf AM5 wollte ich erst mit Zen 5 wechseln …
Settings sind stets UHD - Max. Presets
