[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Asus hat direkt am Stecker eine rote LED:
Aus = in Ordnung
Rot = no 12VPHWR
Rot blinkend = Voltage Drop (bleibt bis PC vom Strom getrennt wurde)
Bei mir geht das rote Licht aus wenn ich den PC hochfahre. Trotzdem bin ich auf 450 W limitiert
Habe so gerechnet:
Strix 4090 500 w default und 600 OC
Max power target 120% (in yt videos)
Ich habe max power target 90% (=450 W) da 100% die 500W Default wären.
Könnte das mitgelieferte 4 8pin auf 12vhpwr Kabel defekt sein?
Ist ja auch "Normalzustand". 600W OC.
3 oder 4 Kabel am Adapter angeschlossen? Wenn 4, vielleicht die Kabel mal anders am Netzteil einstecken.
Anscheinend sind seit Gestern weitere Invites zur FE raus!! Aber wie man gehört hat wurden ja bereits bei einem User hier dennoch die FE Storniert trotz Invite. o_O
Wo registriert man sich denn für die FE damit man einen "Invite" bekommt? Auf der HP von Nvidia und NBB finde ich nix o_O
Habe so gerechnet:
Ist das Netzteil in SingleRail-Stellung?
Ah ok danke :), dachte ich bin nur zu blöd den Button zu finden ;D
Ernsthaft? Ich bin der Gamer schlechthin und noch kein Invite...
Die Invites gehen eh nur an Scalper die die Software 5min laufen haben...
Da wo die 90nund 80 nebeneinander vorgestellt sind kannst du dich für eine Benachrichtigung eintragen lassen. Geht nur noch für die 4080 16
Ob das voraussetzung war, ka.
Futuremark hat sich geäußert wegen dem Score cheat in 3D Mark
„We are actively investigating the new 4090 scores and gathering data, stand by.“
Darf ich fragen welche Anbieter denn momentan für die Tuf eine Wakü anbieten? Also die passende Platte
Danke @hwk, hab mich da mal angemeldet ^^
Kann ich bestätigen, habe heute morgen einen invite per Email bekommen.
Für's Protokoll, in dem Rechner steckt eine 3090 FE.
Allerdings will ich die FE gar nicht. Die Karte ist für mich uninteressant, Strix, TUF, Aorus oder Suprim hätte ich viel lieber. Bin aber ganz ehrlich, es is schon verlockend wenn die FE wirklich für 3k weggehen. :unsure:
Gehen die wirklich so weg, oder sind das fake gebote? Ich hab das bislang gar nicht verfolgt.
Wiederkehrender Fehler?
Wäre am Link interessiert :d Kannst ja per PM schicken. ^^
Edit: Vielleicht kriege ich kein invite, weil ich aktuell nur ne 3060Ti drin habe, weil ich meine 3090FE schon verkauft habe...
Habe beides versucht. Single und multi
Hmm. Hab gerade mal getestet (hab auch das HX1200 in Single) und die Karte hat max 546Watt verbraten (hab aber auch das Corsair 2x8Pin AdapterKabel). Welche Pins sind denn beim Adapter bei den Sense-Kabeln belegt?
Die 4090er sind einfach schon als "standard" Varianten so abnormal schnell, das die OC für den "normalen" User nicht nötig sind. Bin mit der Palit, ob nun OC oder non OC (beide unter 2k), absolut zufrieden. Sellten so einfache zu nutzende Karten gehabt. Bisschen UV bei standard Boosttakt 2700 und man hat ne verdammt schnelle, leise, kühle Karte.
Beste Grüße
Aber wenn man 10mhz mehr schafft als der Nachbar dann hat man doch ne ganz andere Wertigkeit digger, dann hat man quasi den längsten im forum!!!11
