[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Für Wakü User ist es halt echt mega dumm dass jetzt jeder Hersteller sein eigenes PCB macht. Offenbar hat nur die Inno3d das Referenz PCB.
Eigentlich bleiben als Optionen nur die TUF Non OC oder für 2200 oder so ne FE von Ebay...zumindest wenn man gerne wieder einen Heatkiller Block hätte...
Schon lustig dass die Trio-X quasi eine um paar Phasen abgespeckte Suprim X ist, NV hat den AIBs doch sichtbar weniger Freiheiten zugestanden.
Also reicht ja im Prinzip auch der Dreizack statt Vierzack, der der MSI Trio beiliegt, vollkommen aus, wenn man eh undervolten will. Die sonstigen Komponenten sehen wertiger aus als die, welche die Windforce hat, welche ja die gleiche UVP wie die Trio hat.
Bei der suprimX wird es mit der Zeit etwas besser zudem betreibe ich UV mit der Karte für den Alltag, die karte macht bis zu 3150 MHz oder 2600 MHz bei 865 mV im UV ist sie kaum zu hören
wirds für die suprim x ein waterblock geben? wurde da schon was bestätigt oder sollte man was waterblock angeht eher zu asus umschwenken?
EK will deine kohle. sicher kommt da was :d
Neues ASMR-Video für Männer :d
Ach der Schraubendreher ist auch ein GPU-Holder?
Hab mich schon gefragt was das soll ... ist leider "zu lang", da ich die Graka im unteren x16 Slot von meinem HEDT-System habe, da ich sonst meine voll bestückte Hyper M.2 X16 Card nicht unter bekomme. Packe ich die Karte in den oberen x16 Slot, wird der untere blockiert. Ändert sich erst mit Wasserkühler und dann braucht man den Halter auch nicht mehr. Aber schönes Gimmick^^
die karte wird vertikal verbaut sicher nicht passen wenn man nen luftkühler nutzt oder?
ich brauch jetzt ein neues case und habe das h7 flow im blick. das hat nen vertical gpu kit. mein matx board hat den pcie16x ganz oben statt im 2. slot
aber die tuf ist schon recht tief.
Alphacool scheint da was zu machen.
Von Bykski kommt bestimmt auch was und Oblitek vom User @Regok wird auch einen Kühler für die Suprim X bringen.
Zustellung erfolgt :d
Morgen kommt die 4090 erstmal in den Zweitrechner und wird unter Luft auf Fiepen getestet. Das wüsste ich gerne bevor ich auf Wasser gehe. Und dann findet am Freitag der Umbau statt im Hauptrechner. Weitere Fotos folgen.
Zusatzinfo falls wer über einen Kauf nachdenkt: Der Stromadapter hat nur die Möglichkeit 3x PCIe anzuschließen und nicht wie bei anderen Karten 4x PCIe
was mich halt jetzt an dieser tabelle interessiert ist, ob wir das als laien bemerken würden oder reden wir hier nur von einer tabelle, wo und welche karte sie beste für benchmark ist?
also ist die suprim x die stärkste karte was benchmark angeht und das mit einem pt von 520W? und man als tuf oc besitzer 300€ zahlt und sich von einer fe einholen lässt was die platine angeht? oder wie deutet ihr die tabelle?
bräuchte mal aufklärung der da mehr Ahnung in der Materie hat. danke vorab😄
alright kann nicht meckern, karte macht 250/1500 unter luft
block kann garnicht schnell genug kommen
jay´s FE schlägt seine strix
es ist völlig random
was hast du für eine? fe?
Update zur Suprim Liquid X. Hätte ich sie nicht selbst eingebaut (Meshify C), wüsste ich nicht, ob eine drin ist. Im Idle nicht zu hören, unter Vollast nur der Luftstrom.
Pumpe: Ausser dem initialen Glucksen nach Einbau nicht wahrnehmbar.
Coil Whine? Welches Coil Whine? Aus nächster Nähe und mit ganz harter Konzentrationierung - Stille. Presbyakusis will ich nicht ausschliessen. Scherz :)
OC interessiert mich nicht, hab den Regler nur 1x auf 3050 gestellt (die Zahl hab ich irgendwo aufgeschnappt). Lief unter Vollast jedenfalls stabil bei 60-62 Grad.
Bin kein Gamer und hab entsprechend keine aussagekräftigen Titel zum Installieren (Cookie Clicker zeigt übrigens keine FPS).
Mir ist der Verbrauch im Idle allerdings wichtig (keine Sprüche bitte). Die Karte allein verbraucht unschuldige 50-60 Watt. Ja, im Idle. Dabei interessiert sie es wenig, ob sie für ein Display genutzt wird oder nicht. WTF.
Klar zieht die Pumpe auch im Idle; die Lüfter sind immerhin aus. Erscheint mir etwas hoch. Was sagen die Fachleute hier? Könnte da ein neues BIOS prinzipiell helfen?
EDIT: Neue Messung, Idle auf 40 W runter (https://www.hardwareluxx.de/communi...rktplatz-handeln-sperre.1323338/post-29499013)
Media Markt Droppt eine Zotac nach der anderen
Hat jemand das bequiet Adapter Kabel bestellt und wurde es schon verschickt? Hängt bei mir bei Alternate seit Tagen in der Logistik.
Mir ist der Verbrauch im Idle allerdings wichtig (keine Sprüche bitte). Die Karte allein verbraucht unschuldige 50-60 Watt. Dabei interessiert sie es wenig, ob sie für ein Display genutzt wird oder nicht. WTF.
auf jedenfall ein schickes kärtchen die liquid :)
hast du den radi im deckel oder front?
Wie jetzt?! Lief sie im Idle 50-60 Watt oder unter Vollast?
Im Idle sollte sie laut Tests ca. 24 Watt saugen.
Hast du vielleicht so ein dynamisches Desktop?
Ähnliche Themen
