[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
so verstrahlt wie du bin ich nicht😂
alleine der text von dir sagt schon alles --> "Nvidia hat die Krone. Sie haben sie sich verdient. Und wer der Boss ist bestimmt halt die Regeln"
deiner Meinung nach darf nvidia alles weil sie die krone haben haha. oh gott ich kann nicht mehr
Ja siehste doch das die alles können. Haben dich auch dazu gebracht 2000 auszugeben. Du bist genau do verstrahlt. Merkst es nur nicht.
hast du denn mal geprüft ob der 12400 wirklich bremst? dazu brauchst du ja nicht die neue karte. das geht ja auch schon jetzt
Ich hab doch die neue Karte schon. Oder was meinst du? Konnte nicht testen da ich bis Donnerstag auf Schulung bin. Nur iPad hier.
Welche Tests nimmt man am besten?
Aber lohnt sich der 13700k nur fürs reine 4K Gaming? Der 12400 ist so sparsam 😅
die cpu hat nix mit der auflösung zu tun
schafft dein 12400 deine wunsch fps? wenn ja, keine neue cpu benötigt
das ist alles was du testen musst.
Er lohnt doch allem wegen dem Mehr an E-Kernen, L2- und L3-Cache. Also eher was fürs Arbeiten.
Naja reicht locker. Soll ja dlss 3.0 noch kommen. Hab jetzt 4K Psycho in CP 65-110FPS reicht. Und in anderen Games hab ich meist durch fps Cap eh weniger Last.
Kann kein ppl1 oder ppl2 einstellen denk ich hab nur ein Asus Strix b660-i Mini itx Board. War ja vorher ein Mini itx Build
Für mich haben Zotac, Gigabyte, Gainward etc. einen schlechten Beigeschmack, auch, wenn er teilweise unbegründet ist (gerade in dieser Gen. soll Gigabyte gut sein). Im OC Forum schreiben viele, dass man MSI und Zotac diese Gen. meiden soll, auf Grund der Qualität und der Spulen (evtl. des geringen PLs). Irgendwie ist es sehr schwer, sich für eine Karte zu entscheiden.
Im neuen der8auer Video wird ja gesagt, dass eine Erhöhung der Spannung nicht zu viel mehr Leistung führt aber der Verbrauch stark ansteigt und die Karte dann im PL hängt. Die Hersteller haben mit ihrem PL/Spannungswert den Sweetspot dieser Gen. gefunden.
Och nö... :cry:
Naja das sind ja nur subjektive Meinungen. Das Problem ist, dass es von jedem Hersteller richtig gute und richtig schlechte Karten gibt. Es gab einige Meldungen, dass eine Suprim X von einem User total bescheiden läuft und sehr laut surrt, wohingegen eine Gigabyte OC teilweise überdurchschnittlichen OC aushält und leise und kühl läuft. Auch haben manche ne Strix, die genauso gut läuft wie eine FE oder Gigabyte OC, man kann halt nicht sicher sein, dass man eine "Premium" Karte kauft und diese auch ihren Preis wert ist.
Zitat aus dem OC Forum: "I backordered the pictureless regular ASUS TUF from B&H on Saturday. Not positive I will get anything from them, but we'll see. Once they return from their holidays I bet they will cancel most of the preorders 😂. I almost managed to grab a Zotac Trinity. But Zotac and MSI are a big no-no this generation."
Hier mal das Video mit dem Volt-Mod:
Kannst du das Forum mal verlinken. Warum genau sollen Zotac und MSI für RTX 4000 ein No-Go sein?
Wo sieht man wie gut PCBs sind? Wie schneidet die Windforce da ab? Drei Jahre hab ich die Karte eh nicht denke ich. In 2 Jahren wird gewechselt 😅
Kann Dir nur den Link zu dem Forum posten und Du kannst ja mal die Erfahrungsberichte der Leute lesen.
Auf YouTube gibt es ja auch ein paar Videos von MSI Karten, welche absurdes Spulenfiepen-/rasseln haben! Bei einigen aus dem Forum läuft die Karte jedoch sehr leise. Ist halt eine sehr große Streuung der Qualität!
Auch wird berichtet, dass MSI zwar das beste PCB Layout haben soll aber die Spulen der Asus Strix z.B. viel hochwertiger sein sollen. Auch gibt es Gigabyte OC Karten, die über 3100Mhz takten können. Daher ist Premium Karte diese Gen. eben nicht immer gleich premium.
Aus dem OC Forum hat das jemand (bezüglich PCB Layout) zusammengefasst:
1. MSI SUPRIM X (LIQUID) - Vcore: 26x70A MPS mem:4x70A MPS
2. ASUS STRIX - Vcore 24x70A Onsemi, mem 4x70A Onsemi
3. FOUNDERS EDITION - Vcore: 20x70A MPS mem:3x70A MPS
4. Colorful Vulcan OC-V - Vcore: 24x55A Alpha&Omega, mem 4x55A
5. GB MASTER (WATERFORCE) - Vishay 24x50A, mem: 4x50A Vishay
6. MSI TRIO X - Vcore: 18x70A MPS mem:4x70A MPS
7. ASUS TUF Vcore: 18x70A Infineon, mem: 4x50A Vishay
8. GB GAMING OC Vcore: 20x50A Vishay, mem 4x50A Vishay
Äh Leute? Ist das ein Scherz??? :oops:
Schau mal im LG Oled Thread, da wurde das schon seit einiger Zeit besprochen! Ist wohl kein Witz aber noch nicht final und wie die Umsetzung aussehen wird, weiss auch niemand!
Das es ab März eine Änderung per Gesetz gibt und auch nur noch gute Energielabels verkauft werden dürfen, ist tatsächlich kein Witz. Das trifft auf viele Bereiche zu. Da muss übrigens bei so gut wie allen Bildschirmen usw rangegangen werden. Da die meisten ein enorm schlechtes Energielabel haben. F und G sind da fast Alltag.
so traurig wirklich. wegen solchen wie dir die alles hinnehmen und nvidia kaum kritisieren sondern feiern sind wir genau da wo wir sind.
ach übrigens, ich habe für die 4090 windforce nur 1300€ bezahlt🤝
Uh das ja mies! Mal sehen was mein Wunsch Monitor hat.
@HisN
ist das mit dem DSR normal dass das manche games nicht mögen
overwatch 2 z.b. zoom mir komplett rein.
leider per screenshot nicht machbar
das ist doch das hier oder?
Lustig oder? OLEDs müssen Energielabels erfüllen, die Software muss ja mittlerweile darauf hinweisen, wenn ich Einstellungen am TV ändere die dem Verbrauch erhöhen, 600W GPUs aber mit immer mehr 8Pin Steckern damit’s überhaupt noch funktioniert sind kein Problem. 🤪
Abwarten bis die EU spitz bekommt was die GPUs heutzutage so verbrauchen. Dann rasieren die so fette 600W Monster mit 40cm/2.5KG Kühlern aber sowas von ab. 🤣
nur das die 4090 mit 350w viel besser läuft. nvida hätte das deutlich besser verpacken können
Beim aktuellen Kurs der EU würde mich nicht wundern wenn es eine Wattbeschränkung der Netzteile oder Komponenten bald geben wird. Leider. Und ich schätze das wird dann auch keine 300 Watt GPU am ende werden wohl eher ne 250 Watt Gesamtsystemleistunsgrenze oder kleineres :d
In manchen Staaten der USA gibt es sowas soweit ich weiß sogar schon aber zum Glück nur für Komplettsysteme.
