[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wieso sollte ich künstlich meine FPS verringern, nur um im GPU-Limit zu hängen und am Ende weniger fps zu haben? 😅
Wenn Du tatsächlich im CPU-Limit bist, kannst Du die Regler, die die Graka betreffen anziehen ohne einen einzigen FPS zu verlieren.
ABER dazu müsste man sich irgendwann mal mit den Reglern auseinandersetzen^^
Und ganz ehrlich .. das hinterhergerenne hinter dem letzten FPS .... alter Schwede. Geht euch das nicht selbst irgendwann auf den Sack?
Ich bin einfach zu alt für diese Scheisse. Hilfe meine FPS^^
Sorry, nicht bös gemeint 8-)
War es nicht so, dass jeder Hersteller mindestens 1 Karte zur UVP auf den Markt werfen musste ? Das erklärt dann wohl auch diesen Preis-Unterschied.
Ohne diese Regelung, wäre die Non-OC sicherlich auch 200Euro Teurer, und der unterschied nicht so heftig.
Hab das irgendwo mal aufgeschnappt mit der UVP. Ob es stimmt, keine Ahnung.
Du meinst als eine "Art" Teaser bzw. Leckerli? :d
Es gab damals tatsächlich öfter mal stix Karten, gerade bei alternate. Man konnte die katen sogar bestellen obwohl nicht auf Lager. Beliefert wurden dann aber dennoch die, die beim drop und vor allem expresslieferung gewählt hatte
Oder selbstabholer waren .. das war damals glaub ich beim Pro Shop ja so das Ding aber glaub auch bei Alternate das die Selbstabholer bevorzugt haben
auch wenn andere schon Wochen vorher Vorbestellt hatten .. was ja eher für empörung gesorgt hatte damals 2020
Die Shops sollten lieber nun alle erstmal Bunkern und wenn dann genug Ware da is dann die Shops öffnen statt immer nur so 1 - 2 Karten zu droppen die dann nach 30 sekunden weg sind
und man "The Flash" sein muss um da schnell genug zu sein ... und so hat man dann auch alle karten da und nich nur die Standart Karten
Natürlich kann ich immer noch Downsampling, etc. aktivieren, aber darum geht es doch gar nicht. Das Ziel sollte doch normalerweise sein in WQHD z.B. 144hz zu erreichen. Und da limitiert der gute alte 3700x heutzutage schon ordentlich. Natürlich muss man von Spiel zu Spiel schauen, aber so ganz zeitgemäß ist er nicht mehr, vor allem nicht mit einer 4090.
5800x3d aufs Board packen und dann ist die Sache gegessen . Noch aktuell das beste was man kaufen kann .
Warum geht es nicht darum? Wer rumheult seine Graka langweilt sich, der muss nur DL-SR anschmeißen und ne höhere Auflösung einstellen als aktuell. Und schon verschwindet das böse böse böse böse CPU-Limit.
Es ist so einfach, aber keiner macht es. Warum nicht? Weil es nicht darum geht?
Doch genau darum geht es. Die Leistung einer Graka kann man völlig fließend in FPS und Bildqualität aufteilen, und wenn meine CPU "zu schwach" für mehr FPS ist, dann nehme ich die "übrige" Leistung für Bidlqualität und setz mich nicht hin und heule rum, dass ich im CPU-Limit bin.
Das ist doch nur ein Armutszeugnis für mich, wenn ich das so mache.
Dem Glauben, dass man im CPU-Limit unbedingt ne neue CPU braucht sollte ruhig entgegengewirkt werden.
Eine Graka bekommt man immer klein, wen es stört dass er im CPU-Limit ist muss nur die Regler anziehen (sofern es nicht die FPS sind, die ihn stören).
Das CPU-Limit AN SICH hat man selbst in der Hand/ist man selbst drann schuld.
Für dich muss eine GPU erst entwickelt werden. Du machst ja alles klein :d
An den Reglern macht (für mich zumindest) nur soweit Sinn, dass ich auch was davon sehe/merke
Übertrieben gesagt, bringt es mir nichts, wenn ich die Härchen auf dem Blatt einer Brennessel sehen könnte, wenn ich daran vobei rushe
Dann muss Jeder für sich entscheiden, worauf er wert legt
btw:
Könntest du den VRAM hier auch voll machen? :fresse:
Die hypnose scheint bei Dir auch geklappt zu haben. Konntest ja nicht bis zur AMD warten :-)
so verstrahlt wie du bin ich nicht😂
alleine der text von dir sagt schon alles --> "Nvidia hat die Krone. Sie haben sie sich verdient. Und wer der Boss ist bestimmt halt die Regeln"
deiner Meinung nach darf nvidia alles weil sie die krone haben haha. oh gott ich kann nicht mehr
z.b. weil eine GPU dann deutlich weniger fiept und verbraucht. Bei einem 144Hz-Bildschirm muss meine GPU keine 300fps errechnen (bei Shootern mag es u.U. Sinn ergeben) 😅
Die FE war nach 15 min ausverkauft und nach so 3 std war alles weg am Mittwoch seit dem droppen nur hier und da mal die Standart Karten aber dann auch nur so 1 - 2 stück wo man dann 30 sekunden Zeit hat.
Ich versuche seit Mittwoch Nachmittag ne Strix zu bekommen .. nix .. wenn dann nur TUF.
Die FE war sogar nach 2 Minuten ausverkauft, zugegebermaßen (habs selber versucht) ;). Bei MF hatte man dagegen wie gesagt mehr Zeit am Donnerstag ne Suprim zu bekommnen, die hatten mehrere Hundert Stück, ich musste mich nicht stressen (aber klar, bis zum Abend warten war auch da nicht). Alternate hat immer wieder Karten gedroppt den ganzen Mittwoch abend und Stand jetzt haben nach meiner Analyse mehr Leute eine Karte bekommen als zur gleichen Zeit 2020. 2020 brauchest Du einen Buybot um überhaupt was zu bekommen. Ich habe damals Monate gewartet, diesmal weniger als 24 Stunden.
Nope .. es gab genau wie 2020 auch immer mal wieder Karten für nen Bruchteil an Sekunden zu kaufen .. damals war sehr oft die Zotac Trinigy und die Gigabyte Gaming zu haben auch in der Anfangszeit
eben die Standart karten genau wie 2022 zb die TUF.
Das war auch schon vor 2020 so, das ist nichts neues. Es war sogar schon deutlich schlimmer in der Vergangenheit bei echten Paperlaunches. Der Unterschied war die Dauer in der dieser Zustand angehalten hat. Früher hat sich das nach ein paar Tagen bis Wochen gelegt, 2022 hat der Zustand Monate angehalten. Es ist völlig normal das bei einem Produkt wie eienr Grafikkarte wo so stark selektiert wird und wo es vor allem nur eine Modellreihe überhaupt zu kaufen gibt, sich viel knubbelt. Das ist nicht automatisch ein Drama.
Und ich versuche seit Mittwoch 15 Uhr ne Strix zu bekommen sowie andere andere Karten bekommen wollen und uahc kein Glück hatten.
Das Forum hier ist aber auch voll mit Leuten die da scheinbar weniger Schweirigkeiten haben als Du, ne Menge Leute haben scheinbar ne Strix hier. Und auch andere Karten. Manche selektieren sogar schon durch. 2020 konnte man da nur zum Scalper rennen wenn man ungeduldig war, weil die Miner alles weggekauft hatten und das bei weniger Stückzahlen als diesmal.
Przentuall gibts hier mehr Leute die auf ne Karte warten
Sehe ich anders. Ich ziehe nämlich die Leute ab die auf ein bestimmtes Modell warten. Ich kann mich an keinen Release in den letzten Jahren erinnern wo begehrte Modelle jederzeit gut zu haben waren rund um die Uhr und weniger begehrte in den Lagern versauert sind. Bei Grafikarten waren die ersten Wochen immer anstrengend. Wenn das in ein paar Wochen immer noch so aussieht, dann kann man nochmal neu analysieren.
Ich kann natürlich Deinen Frust verstehen und für jemanden der noch keine Karte hat sieht die Situation natürlich gleich aus wie 2020 (damals keine Karte, diesmal keine Karte) aber die Situation ist trotzdem nicht genau gleich, weil nach meiner Analyse eben mehr Leute bereits eine Karte haben als damals zur gleichen Zeit (ich bin nur einer davon) und die Frequenz mit der Karten wieder in die Lager tröpfeln trotzdem höher ist als 2020, weil eben auch Stückzahlen, Lieferketten und Material alles besser ist als 2020. Ich sagte ja selbst es hätte natürlich besser laufen können (vielleicht hat nVidia selbst nicht glauben können wieviele Leute aktuell noch bereit sind 2k locker zu amchen) aber "genau gleich" passt halt nicht zu den Daten.
Ich drücke Dir natürlich trotzdem die Daumen das Du Deine Strix bald bekommst, aber Du hast Du da halt leider auch ein Modell ausgesucht, das nun mal sehr begehrt ist, weswegen es natürlich schwieriger wird. Aber ich glaube trotzdem das Du diesmal schneller eine Strix bekommen wirst, als Dir das 2020 möglich gewesen wäre.
Ich hab gestern mein Lieblings-Abschalt/Runterkomm-Spiel in 6144x3420 gezockt mit DL-SR.
Das sah wie ein völlig neues Game aus. Mit Details die ich vorher nie bemerkt habe.
Nativ ist das relativ räudig mit niedrig aufgelösten Texturen. Aber die zusätzlich wahrnehmbaren Details und dieses unglaublich ruhige Bild ohne Kanten, Textur und Shaderflimmern.
DAS SIEHST DU NICHT?
Wirklich jetzt? Du willst mich verarschen.
Es geht nicht darum, dass Du jedes Grashälmchen siehst, sondern darum dass kein TXAA die Grasfläche verschmoddert und Du nur noch Alias-Kanten/Flimmern hast und das Du MEHR Grashälmchen siehst^^
Schon ausprobiert?
Mir würden da zwei, drei Kandidaten einfallen^^
Nope, FPS>Everything. Immer. 8-) Und so war mit Sicherheit auch die Ausgangsfrage gemeint. Deine Abhandlungen machen reichlich wenig Sinn, weil sie an der Frage vorbeigehen. Auch wenn sie wahrlich nicht so kompliziert sind, wie du anscheinend denkst.
Ist eine persönliche Einstellung. Ich brauch nicht mehr FPS als mein Monitor Hz hat. Wer nen 360hz-Monitor hat und/oder unter 500 FPS keine Freude empfindet, der braucht ne schnelle CPU.
Aber wer einfach nur rumheult das er im CPU-Limit ist ... der ist selbst schuld. Denn er hat es selbst in der Hand.
Wer so wie Du an die Sache rangeht, der wird nie irgendwann auf einen grünen Zweig kommen, denn mehr FPS geht ja immer. Das ist ein Fass ohne Boden und so dermaßen ausgelutscht. Da braucht man sich dann aber auch nicht hinstellen und was von CPU-Limit erzählen. Wirklich nicht. Das ist umsonst.
Und ich machs nicht kompliziert, ich mach es einfach. Dir ist nur nicht zu helfen^^
Soll ja Leute geben, die irgendwann "genug" FPS haben, und genau für die ist meine Lösung.
Krass wa?
Da gabs doch riesenaufriss deswegen
Hab ich garnicht verfolgt. Aber das ist Sch...
Der normale User denkt, dass die Strix extrem schwer verfügbar ist, während sie "unterm Ladentisch" verkauft wird :rolleyes2:
Man kann zig VMs, IPs, KKs, Mailadressen etc generieren, aber ich persönlich hätte kein Problem damit pers. Daten rauszurücken, um ganz sicher meine Wunschkarte zu bekommen,
während es diesen gierigen Scalper sauschwer gemacht wird
Wieviele Strix hatten sie ?
Wo ich an dem Tag jedenfalls Online war war dort schon alles weg
Ich gebe zu 2020 war es etwas schlimmer .. nur is 2022 eben nich grad viel besser sondern vielleicht nur dezent besser.
Ingesamt ist es aber sehr ähnlich und ich bin ja nich der Einzige der das hier so sieht.
Hat ja auch niemand behauptet das es eins ist ... sondern nur das die Situ 2022 ziemlich indentisch zu 2020 ist.
Sowie auch mit Leuten die exakt die selbe Schwierigkeiten haben wie ich.... wie gesagt man lässt sich leicht täuschen
Die meisten haben eher ne TUF oder andere.
Ja traurig das es solche Menschen gibt ich hoffe die werden vom Blitz getroffen genau wie die Scalper
Danke .. da ich viele Geräte mit HDMI hab hab ich da halt nur die TUF und die Strix zu auswahl ... und wenn ich eh schon soviel Geld ausgeben muss nehm ich dann gleich das Top Model.
Wie sich manche Leute immer über höhere Preise bei knapper Ware aufregen. So funktioniert Marktwirtschaft nun einmal, wenn Nachfrage höher als Angebot, kann man höhere/hohe Preise verlangen. Da kann man Caseking und Co. doch nichts vorwerfen. Die wollen nicht euer best friend werden, sondern Gewinn machen. Muss doch außerdem niemand zahlen bei so unnötigem Spielzeug wie einer Grafikkarte, auf die kein Mensch wirklich angewiesen ist.
Nicht nachvollziehbar für mich, was manche da hier so schreiben.
Schon ausprobiert?
Hab keinen 8K-TV/-Moni :cry:
Vielleicht würde ich es dann sehen...? k.A. :rolleyes2:
Dich immer - nee, Spaß... :wink:
btw:
Was ist aus deiner VR-Geschichte geworden? Was hast du gerade am Laufen?
Da es jetzt langsam losgehen sollte, dass Händler Retourware wieder als Neu weiterverkaufen wäre es doch interessant zu wissen wie eure Karte versiegelt oder eingepackt war?
Die 4090 MSI Suprim X hat kein Siegel auf dem Karton. Die Kühler war aber voll mit abziehbarer Folie die man nach dem entfernen sicher nicht mehr drauf bekommt.
Davon kannst ausgehen.. wenn keine Folie auf Kühler dann Retoure
Ich glaube einfach nicht, dass es viele Leute gibt, die mit einer 4090 mit 8k downsampling auf WQHD mit 60fps spielen, nur um dem CPU-Limit zu entgehen. Aber ja, letztendlich bleibt es natürlich jedem selbst überlassen. Ein Verwandter von mir spielt mit einer 3080 auf einem Full-HD 60hz Screen. :LOL: Da gibt es dann zumindest kein Limit, außer dem Monitor.
Eine gpu verbraucht unter mehr last weniger?😁
Ich kaufe mir einfach immer ne schnelle CPU wenn möglich und ne schnelle Grafikkarte und dann schaue ich wo das Limit jeweils hängt und drehe die Regler entsprechend so wie HisN beschrieben hat. Dann bin ich jeweils glücklich, der Rest sind für mich eher theoretische Fragen ohne Relevanz für meine Kaufentscheidung oder Emotionen gegenüber der Komponenten. Ob ich ein paar FPS mehr haben könnte mit ner anderen CPU interessiert mich null, ich habe lange mit nem Threadripper und ner 3090 gezockt, war mir doch Latte ob ich wegen dem Threadripper ein paar Frames einbüße. Ich habe dann einfach dafür gesorgt, das der Threadripper nicht das Problem ist :) Und diesmal dann einen 7950X geholt bevor die 4090 kam. Klar ist der X3D schneller in Games und könnte mit dem CPU Limit helfen. Aber mir wieder Latte, was ich habe reicht völlig.
Ich verstehe das Thema wie gesagt aus theoretischer Sicht, aber praktisch hat es für mich persönlich keine Relevanz aktuell. Aber das ist nur meine Meinung :)
Ähnliche Themen
Antworten
7K
Aufrufe
585K
