[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Frage an die fe user.
Bläst die fe hinten viel luft raus oder bleibt das meißte im gehäuse?
Auf 70% gehen die lüfter?
Meine tuf dümpelt bei vollast bei 1000rpm rum und ist unhörbar. Sind dann etwa 30--40%. Vielleicht ist dein geräusch die pwm steuerung?
Ja das Silent Bios der TUF ist echt der Hammer. Ich komme von der 3080 FE, der Unterschied in Lautstärke und Temps ist riesig.
Bisschen mal übertaktet und Power Limit höher gemacht :)
Meinst du? Konnte nur auf 108% PL gehen. Maximal 2900Mhz
Hab RAM schon plus 1000 und gpu +160Mhz
Beim CPU Test habe ich immer eine DIA Show. Armer 12400.
Nimm mal+1500-1600 danach Skaliert der nicht mehr gut
Kann man GeForce Experience eigentlich auch ohne NV Grafikkarte installieren? Hab meine 3090 schon verkauft...
Meine Suprim X macht beim VRam nicht sehr viel mit bei etwas über 1450MHZ ist langsam Ende /:
Cool, ich komm auf 10.869. Mehr geht aktuell nicht.
Ich hab die auf 210/1600 danach kommt nicht mehr viel. Versuch mal @Holzman
Naja, MEM +1600 wie bei Dir wären bereits jenseits der 1.500 MHz, also wird er da wohl nicht hinkommen. Ich hab bei mir erst mal bei +1500 MEM aufgehört, das läuft ohne Probleme, ein bißchen könnte da noch gehen. Bin mit meiner Suprim sehr zufrieden bisher, Takraten jenseits der 3.1 GHz gehabt, MEM läuft auf +1500, läuft sehr leise, alles einwandfrei bisher.
An die Gainward Besitzer mit Lüfter Problematik: Versucht mal das Silent BIOS über den Schalter zu aktivieren und Lüfter Kurve in Afterburner auf automatisch. Das beseitigt das Problem komplett bei mir, da die Karte dann im Idle 0rpm hat und bei mir ist es eh nur im Idle hörbar. Performancetechnisch macht es keine Unterschiede, habe fast dieselbe Punktzahl im 3D Mark wie mit dem Performance BIOS. Ist natürlich trotzdem nicht optimal, aber ich persönlich würde die so behalten bis die 5090 oder 5080 drin ist und mache dann ein RMA damit es für den Weiterverkauf gefixt ist.
Ich hab auch im Perf. BIOS Zero Fan im Idle. Mhm komische warum hast du das nicht?!?
+1450 im AB ist das allerhöchste was ich durch bekomme bei 1600 klappt die Karte sofort zusammen, dafür ist der Chip sehr gut +260 geht, entspricht bei mir so ca. 3150 MHz ....
Mit welchen settings und Karte :) hast die 10869 bekommen?
Ja oki ich bekomme die gpu nicht höher als 225mhz.
Hab mit PayPal gezahlt, meine Bestellung am 12. und die erste mit Invite-Link wurden jedoch beide mehr oder weniger instant storniert.
Hab jetzt meine zweite Bestellung mit Invite über PayPal Express gemacht und die ist jetzt seit ner halben Stunde in Bearbeitung :fresse2:
Was für ein Invite ist das? meinst du über die nvidia Seite?
Karte ist die Suprim X, Settings war +235 GPU und +1500 MEM. Timespy kann ich GPU auf +250 setzen, bei Port Royal muss ich auf +215 runter aber nicht jeder Durchlauf ist da stabil mit, erst bei +200 läuft es. Firestrikes laufen sogar auf +280 durch.
Ja spielt sich mit meinem Ergebnis wieder. 210/1600 hab ich im speedway 10888 pkt. Nach jedem run hab ich mir die benches genau angeschaut. Und hier Skaliert in speedway nichts mehr. Selbst wenn ich nur 15mhz höher gehe.
Also beim Ram +1500Mhz habe ich Pixelfehler und bei +170Mhz Core Stürzt der Bench ab.
Bin aber zufrieden mache ich ja eh nie. Gleich wieder UV.. muss ja Strom sparen :d
Wenn du zufrieden bist. Top
Am Anfang MUSS man die Karte Prügeln, man will ja wissen was für eine tolle Hardware man sich gekauft hat. Danach wenn Normalität einkehrt, geht's ans UV :)
Wie testet ihr das Fiepen? Habe bei meiner bei 240fps kein Fiepen gehört, womit kann man testen ab wann es kommt? Gibt es schon Vergleichswerte?
Der Worst-Case meiner Erfahrung nach ist Superposition 4k.
Hatte hier im Forum bisher stumm mitgelesen, mir nun aber wegen der Palit Gamerock Theamtik doch mal einen Account gemacht. :d
Meine Karte hat ab der niedrigsten Lüfterstufe (30%) schon so ein Motorengeräusch, das ich bisher von keiner Grafikkarte oder anderen Lüftern kannte. Durch das geschlossene Gehäuse ists nicht so extrem, aber bei niedrigen Drehzahlen schon nervig. Trotzdem bin ich unsicher ob das der Defekt ist von dem ich hier immer las.
Habe mal ein kurzes Video gemacht. Leider etwas rauschig durch die Luftzirkulation.
Wäre mega wenn jemand bestätigen kann ob sich das für die Karte normal anhört oder wirklich defekt ist. Würde mich dann Montag mal bei Mindfactory melden.
Ansonsten ist die 4090 von der Leistung echt heftig:d
Das gleiche haben wir mit der Gainward Phantom auch. Kurz gesagt es liegt vielleicht an Lüfter/Resonanz Igor hat Palit angeschrieben in der Hoffnung das man es per Bios fixen kann
Aber abwarten ob es wirklich daran liegt und nicht vielleicht doch ein Defekt an denn Lüfter/Motor liegt
Das ist meine Karte.
Hat noch eine außer ich bei Cyberport bestellt und wie sieht bei euch der Versandstatus aus Stand der Dinge jetzt.
Lg
Ich suche nur nach Gründen um mein System upzudaten. Eigentlich wollte ich den 10900kf noch etwas länger behalten, weil es schon ein besonderes sample ist aber wenn er jetzt anfängt die 4090 auszubremsen, find ich nicht so geil, auch wenn die FPS immer noch reichen. Wie soll ich nachts jetzt ruhig schlafen können? :fresse2:
Sag mal was ich kaufen soll, ich suche auch nur nach nem Grund zu basteln haha
Hat noch eine außer ich Cyberport bestellt und wie sieht bei euch der Versandstatus aus Stand der Dinge jetzt.
Lg
Bei mir sieht es jetzt so aus hat das schon mal wer gehabt ..?
Ja, ich habe mehrfach laut GPU-Z im Powerlimit gehangen. Mir geht es da aber auch eh nicht um die Punktejagd oder das letzte bißchen Performance, aber es ist eine gute Möglichekit um die eigene Karte grob einzuordnen, ob man ein gutes Exemplar erwischt hat. Aber stabiler +1500 MEM und Alle 3dMark Benchmarks bei >= +200 GPU durchzubekommen ist für mich eine gute Karte. Klar wird man bei härteren Benches wahrscheinlich noch weiter runtermüssen aber es ist ein guter Vergleichswert.
Ich bin auch sehr zufrieden. Werde auch nicht mehr groß was reißen wollen.
Wenn der WB kommt, schau ich nochmal was geht. Aber 210/1600 ist für mich ein Träumchen. Werde morgen so alle 3dmarks mit den Settings durchnudeln, danach geht's ans UV.
Hier mal mein Ergebnis:
