[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
edit : ach mist. das kabel wird mir das zunichte machen :fresse:
Den nicht mehr angewinkelten 12 (jetzt 16) Pin finde ich auch blöd, so muss ich mein Gehäuse in der Höhe wohl ein wenig pimpen.
Aber wofür gibt's 3D Drucker ;)
Hab eben auch meine 4090 FE mit Priority Access bestellt. Dachte das wäre nur für BestBuy, so stands zumindest in der Mail.
Danke für den Hinweis :d
Wie sieht so ne Mail eigentlich aus?
Der ganze verfluchte Drop Stress sollte ja damit dann endlich ein Ende haben. PartAlert und wehe man ist dann in nem Meeting und kann nicht innerhalb 10 Sek. auf den Link und nen Checkout machen...
Also ich kann mir nicht helfen, die 4090 ist einfach der Knaller. Hab meine TUF jetzt bei 2655MHz und 900mv gelocked, 3 fps weniger in Cyberpunk und die GPU genehmigt sich 255 - 275W.
OC ergibt dafür null Sinn, 3-4 Frames mehr für 460 - 480W. Aber schön das die auf 600W spezifiziert wurde, so kann man sich Wasser sparen, mit UV dümpelt meine TUF bei 54-56 Grad rum. Das einzige was nervt, ich bekomm mein o11d midi nicht mehr zu ... muss wohl ein vertikal kit her.
Solange die Nachfrage mit Invite-only groß genug ist, werden Sie das vermutlich beibehalten.
Find ich persönlich keine schlechte Sache, so kann NV seine treuen Kunden belohnen und man hat keinen Stress an die Karte zu kommen.
nicht falsch verstehen, es ist auf alle fälle was feines und eröffnet möglichkeiten an die karte zu kommen ohne stress und warterei auf einen drop.
Jap, so schmerzt ne Storno auch nicht mehr so, weil dann hat man noch 2 Tage Zeit um es mit x anderen Zahlungsarten zu versuchen.
d mini oder air mini? hab das air noch hier stehen
Also mit 0,900V und 2600Mhz läuft die bis jetzt stabil. Werde noch etwas runter.
Aber erstmal spielen nicht nur BeMachen. Spulenfiepen ist so gut wie nicht mehr hörbar.
Lüfterkurve auf 50-55% bis 80 Grad eingestellt. Die Karte wird aber nie so heiß dafür schön leise.
Bin auch ziemlich beeindruckt lasse sie aber stock laufen, mein 750W NT hat sich noch nicht beschwert.
Höre die Karte auch nicht mehr, wenn es rasselt dann sehr leise. So leise war meine Kiste seit 2 Jahren nicht.
Hab mit PayPal gezahlt, meine Bestellung am 12. und die erste mit Invite-Link wurden jedoch beide mehr oder weniger instant storniert.
Hab jetzt meine zweite Bestellung mit Invite über PayPal Express gemacht und die ist jetzt seit ner halben Stunde in Bearbeitung :fresse2:
Hääää nach welchen Regeln stornieren die bitte?
Da bekommt man nen Priority Link und dann trotzdem noch nen Storno? Crazy
Ich hoffe ja mal dass Nvidia die Acc welchen sie den Link schickt gut prüft. Alter Account + Nvidia Karte aktiv + einige Spiele + Spielzeit sollten schon drin sein. Andernfalls ziehen sonst die Scalper demnächst hunderte VMS hoch und installieren Experience um diese Links zu bekommen.
DA bekommt amn nen Priority Link und dann trotzdem noch nen Storno? Crazy
Das wüsste ich auch gerne.
Die zweite Bestellung ist jetzt jedenfalls seit ner dreiviertelstunde in Bearbeitung, also scheint jetzt geklappt zu haben :d
unten ist ein 120er. die karte liegt genau auf dem 120er auf. nach vorne ist kein milimeter mehr platz
sollte ich eine 4090fe kriegen wird das case vermutlich wieder größer werden müssen.
Ich würde mal vermuten die bekommt man geschickt, wenn man sich für die RTX 4090 Benachrichtigungen auf der NV Seite angemeldet hat.
Evtl. fließt auch noch die GPU die man im Rechner verbaut hat mit ein, bei mir war das halt ne RTX 3090 FE.
Das ist echt krass, ich frag mich was die Board Partner davon halten. Mittlerweile ist die FE so gut dass es kaum noch gute Gründe für Custom Karten gibt und jetzt noch dieser direkte Vertriebsweg über den Priority Zugriff. Gefühlt muss die Luft doch immer dünner werden.
Hmm habe ja das Glück eine FE bekommen zu haben. Die Karte ist nicht wirklich größer als eine 3090 FE. Bei der Qualität der 4090 FE hatte ich ganz leicht das Gefühlt dass da etw. "gespart" wurde. Scharfkantiger Kühlerblock, Lüfter auch iwie weniger massiv (der von der 3090 ist einfach massiver und man würde meinen das Lager dadurch auch besser).
Die Customs sind aber dagegen oft größer. Ich würde mal behaupten dass die Customs Potential zu niedrigeren Temps, niedrigerer Geräuschentwicklung und ggf je nach Bios Mod mehr OC Potential haben (wobei OC scheinbar nicht viel bringt da die paar FPS nicht mehr im Verhältnis zum steigenden Stromverbrauch stehen).
Schon 'ne feine Sache! Wird man denn auch per Mail benachrichtigt oder muss man tatsächlich immer mal bei Experience schauen?
Würde mich interessieren, nach welchen Kriterien die das überhaupt verschicken oder ist es komplett Random🤔
Vielleicht schauen die auch welche Spiele installiert sind. :unsure:
Aber herauszufinden nach welchen Kriterium Nvidia auswählt ist einfach unmöglich vielleicht ist es auch nur Zufall.
Kommt mir auch so vor als ob Nvidia den Markt an sich reißen will.
Ist die Artikelnummer der FE via GFE bestellt immer noch: „A 996979“ ?
