[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
na dafür schlagen sich die Strix und TUFs ziemlich gut gegen die anderen…
ich verfolg den thread hier zwar nicht tag ein tag aus, aber vom gefuehl her posten nur strix/tuf leute ihre scores und sonst niemand anderes, bzw andere benchen nicht mal
Gibt's eigentlich schon ne Übersicht aller angekündigten Wakü-Blocks + für welche PCBs sie passen? Ich erinnere mich, dass es zum Release von Ampere ne sehr gute Übersichts-Seite gab, die genau das bot (mit Ausblick auf z.B. auf den Watercool Block für die FTW3 3090)?
Wenn ich in den kommenden Monaten dann auch mal schwach werden sollte, würde ich mich gerne daran orientieren... "fertige" Wakü-Karten sind ja nicht angekündigt abseits der Inno-Karte, korrekt?
Ich kann ja noch nicht. :cry: Bin zwar auch kein Benchprofi, aber ich würde schon meine Werte zeigen.
Wenn du noch 1 bis 2 Wochen warten kannst, kann ich mit einer Inno3d X3 OC unter Wasser Benchmarks posten :d
Hmmm schwierig den Überblick zu behalten, aber ich glaube es wurde schon verglichen SH hat bereits mindestens selbst 2 verschiedene Modelle getestet und ich glaube bislang ist seine erste Strix ganz vorne mit dabei.
Wie gesagt die Frage ist halt wie genau das Binning nach so kurzer Zeit bei Asus ist. Die messen glaube ich den Chip auf Grund von gesammelter Ergebnisse einiger „weniger“ Testmodelle.
Mal schauen ob es nächste Woche eine 4090 zum vernünftigen Preis abzugreifen gibt. Sonst geht es sicher bald los, dass es einige Rückläuft wegen Fiepen usw. gibt und davon will ich keine haben. :-)
Klar reicht der aus, aber schön ist anders. ;)
Oh shit! Ich hab auch noch den hier an der GPU:
Mir fehlt gerade die Fantasie, wie das aussehen wird mit diesem Adapter🤦‍♂️
Und dann auch noch alles in ein Meshify 2 Compact. Eng ist ja sonst immer schön und gut, aber hier bekomm ich Kopfschmerzen.
Die Gainward Phantom GS hat bei FPS 300+ ein ganz leichtes Fiepen um das zu hören muss ich mein Glasgehäuse öffnen und mit mein Ohr an die Karte gehen. Sonst bin soweit zufrieden außer das Problem mit denn einen Lüfter
Hab mal 0.925 mit 2750 gemacht sofort Crash im Port Royal. Werde wieder Metro Exodus Benchmark installieren und dann langsam nach unten tasten.
Ich würde es mit 2600 MHz versuchen als Basis und dann den takt langsam erhöhen. Wobei mehr takt auch mehr voltage fördert. Un jetzt 100 MHz mehr oder weniger ist doch nei der Karte egal das gibt vielleicht 1-3 FPs mehr bei 2750 Mhz
wo ist das problem? :)
Ich suche nur nach Gründen um mein System upzudaten. Eigentlich wollte ich den 10900kf noch etwas länger behalten, weil es schon ein besonderes sample ist aber wenn er jetzt anfängt die 4090 auszubremsen, find ich nicht so geil, auch wenn die FPS immer noch reichen. Wie soll ich nachts jetzt ruhig schlafen können? :fresse2:
wenn die fps reichen, wozu dann upgrade? :)
ein 12900k wird auch mal langsamer sein als die 4090. ist halt abhängig von dem was man zockt.^^
Das Feature werde ich aufgrund von fehlendem V-Sync niemals nutzen. Mein Motto lautet seid über 20 Jahren gib tearing keine Chance. ;) Und bzgl. Inputlag hast du Reflex laufen?
Bei Spiderman funktioniert VSYNC in Verbindung mit VRR/GSYNC und DLSS3. Es vermeidet jegliches Tearing. Im Falle meines OLED, der 120Hz schafft, darf ich dann nur nicht an die 120Hz herankommen, denn dann greift VSYNC ein. Dann spürt man auch einen deutlicheren input lag. Bleibt man innerhalb der VRR-range sind es angenehme und perfekt spielbare 49ms. Wenn VSYNC reinkickt sind es 110ms. Ein Frame rate cap via MSI Afterburner/RTSS bringt nichts. Man muss die Settings so hochdrehen, dass man die maximale refreshrate des Displays stets unterschreitet. Reflex muss natürlich an sein.
Hab doch mit der Gigabyte schon Benches gemacht. Nur keine Links gepostet sondern Fotos oder Text
warum sollte ein framecap nichts bringen. 2 unter max range und das IL vom VS is weg
zack war die tuf weg :fresse:
Wird nen Rückläufer gewesen sein und bei MM würde ich sowieso nichts kaufen.
Ohne die 1.1V aushebeln zu können ist benchen auch etwas langweilig. Das ganze ist aktuell eine reine Chip Lotterie wie weit man kommt. Design der Karte spielt kaum eine Rolle, da man mit den 1.1V eh selten weit über 500Watt kommt.
wegen kommender pleite ?
Aus vielerlei Gründen, die ich hier ungern ausführen möchte, da auch OT aber ja auch deswegen. Ich denke nächste Woche werden wir wieder ein paar gute Drops bekommen. Heute kam ja nichts bisher.
macht es für den käufer der ein schnelles produkt möchte ohne viel experimentieren tatsächlich angenehm einfach.
Hat mal jemand auf Kleinazeigen geschaut, da stehen mittlerweile gut 150 Karten, soviel zur heftigen Nachfrage, die Scalper der RTX 3xxx Ära sind wieder am Start :stupid:
bin ich noch nicht ganz drinnen. Werd mich aber rein fuchsen :) überschreibt das dann die Bios werte?
Ja, wenn man es mal verstanden hat ist es eigentlich ziemlich easy. Schauen welcher Lüfter wo ist, dann Kurven anlegen und Sensoren zuweisen (z.B. GPU/CPU) und das war es eigentlich schon. Genau, BIOS wird überschrieben wenn das Programm geladen wird.
Die werden die aber kaum los und wenn, dann nur mit wenig Gewinn. Wer kauft eine so teure Karte denn Second Hand xD? Ist ja nicht so, dass morgen die Welt untergeht und man nie mehr eine bekommt.
Ich erinnere mich noch schmerzhaft an den DDR5 Launch, wo ich Unmengen an Geld für RAM ausgegeben habe und 1 Monat später wurde man mit DDR5 überschwemmt (200-300€ günstiger).
