[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mein Be Quiet Kabel kam auch grade. Das ist allerdings steifer als ein geiler Opa im Freibad. Da hat man für 20€ ein bisschen mehr erwarten können. Biegeradius nicht vorhanden am kleinen Stecker.
Ah verdammt das hatte ich befürchtet, muss man wieder mit Gewalt nachhelfen :d. Für 20€ hätte es auch einfach mal komplett gesleeved sein können.. kann man dann in 2 Monaten für nochmals mehr Geld nachkaufen :poop:
Das gleich wie beim Corsair nur das es nicht gesleeved ist. Lässt sich auch kaum biegen xD aber es macht sein Job
Leute versteh ich richtig das bei der 40er gen bei 4k 120hz schluss ist wegen DP 1.4? Ausser mit DSC dann 144?
Warum hast du ein 4K 240 HZ Monitor mit DP 2.X ?
Der Samsung hat auch keine höheren Anschlüsse .
Also nutzt das einem auch nichts ;)
BeQuiet Straight Power 1000 Watt. Wie von BeQuiet empfohlen die Karte an PciE 1 und 3 angeschlossen. Also Rail 12v3 und 12v4.
Gerade mal bei meinen Gehäuse (Phanteks Enthoo Pro 2) für GPU Länge angeben wird. 502 mm. Also von mir aus können Grafikkarten noch länger werden :d
nein aber das bedeutet das ohne dsc bei 120 in 4k schluss ist in dieser gen oder?
4K 144HZ + 8bit+FRC oder 4k 120 HZ 10bit nativ.
Bei HDMI 2.1 geht bis 4k 144HZ @ 10 bit nativ oder 120 HZ 12 bit nativ.
Alles darüber mit DSC .
@MADman
OMG wie hast Du die Karte an all den Schläuchen vorbei bekommen? Oder komplette Demontage der Wakü-Schläuche nötig gewesen?
Oh ich habe Straight Power 850W und PCI-E 1 / PCI-2 / PCI-3 alle angeschlossen einmal Y Kabel und 2x einfaches Kabel. Werde aber wenn das neue Kabel kommt extra wie du es sagst anschließen.
Hoffentlich kommt am Montag das 12VHPWR Kabel von BeQuiet. Das sieht ja verboten aus :(
Es handelt sich um die Zotac 4090 AMP Extreme Airo.
Erinnernt mich irgendwie an an das Raumschiff Orville ;-)
Kaum Spulenfiepen, dafür sind die Lüfterlager leider nicht die leisesten und geben ein leises "brummen" von sich.
Bei den ersten OC versuchen hat die Karte 3050 mhz durchgängig geschafft und bleibt mit knapp 65 Grad relativ kühl.
Ach da ist die AMP ja in Natura, sieht super aus, stimmt der Vegleich mit der Orville passt:LOL:,wer immer das Kabel durchgewunken hat gehört gefloated.
Bei meiner AMP steht immer noch in Zustellung...dabei war gerade schon einer von der DHL hier.
Hab' allerdings noch nie darauf geachtet, ob die DHL an die gleiche Adresse auch mal zwei Boten hat.
Nach einer Stunde auf den Desktop und Sachen einstellen habe ich 45°C GPU und ca. 21W Stromverbrauch laut GPU-Z
Dann müsste das ja mit meinem HX1000 auch funktionieren. Ich habe Angst 😅
Lg
warum sollte es mit dem hx1000 auch nicht gehen?
Ja, ist eigentlich lächerlich. Damals bei der 3000er Serie gab es wenigstens HDMI 2.1 als erneuerung. Warum die eine Karte mit soviel FPS am DP Port bechneiden ist mir ein Rätsel. Wahrscheinlich wird das was ganz tolles bei der 5000er Serie damit wir einen Upgrade Grund haben.
Lg
Bei dem Test von Igor hat sich gezeigt , dass die 4090 wesentlich entspannter ist bei Spannungsspitzen als es noch die 3090 war.
Also überhalb von 600W passiert da nichts . Mit einem 1000 Watt NT ist man gut gerüstet.
Meine das HX ist ja kein Chinaböller ;) .
Keine Ahnung mit dem Kabel das neue von Hersteller schreib da HX1200w kann man dieses nur benutzen ich würde das von MSI adaptermäßig nutzen
Lg
die beigelegten adapter gehen immer, von daher fand ich die frage etwas ungewöhnlich.
ob es ein passendes kabel für dein netzteil gibt, müsste man dann aber prüfen.
Lg
Will auch nur auf Nummer sicher gehen und mit einem schlechten Gefühl traue ich mich das nicht so anzuschließen HX1000w schließlich kostet die Grafikkarte geld ich meine bei meiner RTX 3090 Ti Fe läuft es ja auch
An die die schon eine Karte haben was für Netzteile nutzt ihr wie viel Watt und läuft es perfekt gibt es Probleme?
Corsair AX1600i...keine Probleme
Was hast Du denn genau erwartet? Daß das Kabel so steif ist ist doch gerade ein Qualitätsmerkmal, bei dem hohen Querschnitt geht das kaum anders. Meines Wissens sind das echte Cores und keine Litzen. Ein flexibles biegsames kann meist deutlich weniger Leistung ab.
@MADman
Ha, nein, das ging. Ist wie ne Type-9 bei Elite Dangerous zu landen, man muss ein wenig neigen und gieren und rollen und dann geht das schon. Habe die Schläuche kaum berührt, ein bisßchen Schildscratch ist aber doch immer ;) Aber ob die da auch wieder raus geht, wollte ich lieber erst mal nicht rausfinden :d
Ich habe jetzt knapp zwei Stunden Spiderman getestet und bin jetzt schon extrem begeistert von DLSS3. Selbst wenn man bei einer geringen Grund Framerate von 45-65FPS darauf die Frame Generation klatscht, sieht das trotzdem super aus. Daraus werden dann ungefähr 65-85FPS. Mein Ryzen 3900X limiert in diesem Spiel allerdings heftig. Bei einer besseren CPU dürfte da vielleicht noch mehr draus werden.
Ich tu mich hier verdammt schwer, überhaupt irgendwelche Artefakte ausmachen zu können. Das offensichtlichste ist der Missionsmarker, der ein halt ein bisschen "flackert". Wichtig ist, wie Alex von DF in seinem Video erklärt hat, nicht VSYNC zu triggern. In meinem Fall darf ich also keine 120Hz bzw. FPS auf meinem OLED erreichen, andernfalls gibt es eine spürbare Erhöhung des input lags (49ms vs 110ms wie im Video erwähnt).
Bewegt man sich aber innerhalb seiner VRR/GSYNC-Range ist das alles super fluffig spielbar. Dafür musste ich allerdings auf 5120*2880 ohne DLSS2 oder auf 5760*3240 mit DLSS2 quality gehen um sicher zu sein, stets unter 120FPS mit DLSS3 zu bleiben. Wohlgemerkt mit allen Settings + RT auf Anschlag und das bei 60% Power Target XD
Ich habe bei dem Spiel allerdings auch beobachtet, dass es ohne DLSS3 bei mir nicht smooth aussieht (mit DLSS3 wesentlich besser, aber auch nicht 100% perfekt). Spiele ich z.B. in 4K ohne DLSS3, habe ich trotz dreistelligen FPS starke frame pacing Probleme. Drehe ich die Kamera sieht man deutliches stuttering. Habe innerhalb der zwei Stunden auch nichts gefunden, was dagegen hilft. Meine einzige Vermutung ist, dass mein 3900X jetzt zu einem üblen Flaschenhals geworden ist und besonders bei diesem Spiel mit der 4090 nicht ansatzweise mithalten kann.
Bin mal gespannt ob der 5800X3D da was ändern wird.
Ich weiß ja nicht was für ein User die Frage stellt.
Mir persönlich sind +/- 100 Mhz völlig egal, und so wie es bis jetzt aussieht laufen alle Karten kühl.
Am Ende ist es wieder Chip-Lotterie.
Aber wenn ich der Mega-OC-Junkie bin, dann kauf ich mir keine Tuf Non-OC. Oder doch?
Bin ein User der Wert auf die Optik legt und wollte eine Karte der neuen Generation unter Wasser legen deswegen sind mir die OC Variante ja auch egal. Der Preis ist für mich entscheiden denn am Ende sehen die Karten unter Wasser alle gleich aus.
Habe hier nur die Wahl zwischen einer Gaming Trio, Suprim X, Asus TUF und der Zotac Extreme AMP Airo und bisher ist die Gaming Trio auch attraktiv für 2036€ (gut, Preislich sind die alle fett!) deswegen wollte ich einigermaßen Erfahrungswerte Sammeln bis ein passender Block für die jeweilige Karte erscheint…
In der Zeit sind halt die Karten als Luft Varianten im Gehäuse ….
Ja ich weiß auch nicht ^^“
Mein Sternzeichen ist Waage und ich bin relativ unausgeglichen 💁🏽
Also ich spiele das Game native in UHD mit 80-120 FPS. Wozu brauchst Du da noch DLSS oder FG?
