[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@SH
Du brauchst zum Benchen dringend einen schnelleren Prozessor^^
Ich muss PBO mal aktivieren^^
Wo gibt es denn diesen Halter Ich habe Fractal 2 xl
Lg
die frage ist, ob dein gehäuse da an der passenden stelle auch eine möglichkeit der montage hat oder ob der halter speziell fürs torrent gedacht ist.
wollen das die netzteile oder die nutzer der netzteile?
dem netzteil ist das eher egal.
und über 80 % wird auch nur die effizienz etwas schlechter... und es wird vermutlich ein wenig lauter.
Kommt ein wenig darauf an, wie man das ganze betrachtet.
Es gibt natürlich einmal den Effizienzgedanken (jedes Netzteil hat eine andere Effizienzkurve!) die am Ende sehr steil nach oben geht (wenn wir uns also zum Maximum hin begeben, wird eine Menge Strom verschwendet, die überhaupt nicht im PC "ankommt").
Dann haben wir natürlich den grundsätzlichen technischen Gedanken:
Die Umwandlung des Stroms aus der Wand erzeugt Wärme. Wenn sich die Komponenten erwärmen, steigt ihr Widerstand, sodass mehr Strom für den Stromkreis benötigt wird und die Wärmeerzeugung und der Widerstand weiter zunehmen. Wenn wir diesen Zustand dauerhaft haben, und nicht nur schub/phasenweise, werden die Komponenten (zu) heiß und die Wahrscheinlichkeit einer mittel-/kurzfristigen Beschädigung steigt stark an, was ihre Lebensdauer verkürzt, oder sie fallen spektakulär aus und es kommt zu Funkenbildung und Bränden. Wenn man die ganze Zeit mit der maximalen Nennleistung arbeitet, entsteht eine Menge Wärme. Das sollten man also schlichtweg nicht tun. Je weniger das Netzteil belastet wird, desto besser ist es im Hinblick auf Stromverbrauch und Wärmeentwicklung, als auch für die Langlebigkeit des Produkts.
Zudem kommt natürlich hinzu, dass die wenigsten Netzteile auf solche Maximal-Dauerbelastungen ausgelegt sind. Das sind Spitzenwerten, die von Herstellern beworben und getestet werden, nicht 24/7 6 Jahre lang an der Kotzgrenze laufen.
Wieviele Monitore dran?
Welche Auflösungen?
Mal nur einen z.B. 4K nur mit oder weniger 100Hz einstellen!
Fastboot ist hoffentlich auch aus. Hatte das auch schon beim Wechseln von Performance zum Silentbios wenn Fastboot an war.
Ansonsten viele Bildschirme mit hohen Bildwiederholfrequenzen hindert die Karte auch dran runter zu Takten …
Unterschiedliche Wiederholfrequenzen ist hier das Stichwort, das ist ein altes NVIDIA Problem - da gibt es aber Abhilfe, d.h. man kann der Karte "befehlen" bei bestimmten Leistungszustand in den Idle zu schalten, das macht aber Probleme wenn man verschiedene Frequenzen hat (ich muss zB meinen 144 Hz Monitor auf 120 drosseln, weil das ganze sonst nicht mit meinem 4k120hz und FullHD60hz harmoniert und sonst zu flickering und black screen führt).
So meine 4090 TUF non OC ausgiebig getestet.
Viel leiser als meine 3090FE, ganz leichtes Spulenrasseln, dafür kein fiepen. Case ist noch offen, eingespielt im geschlossenen Case evtl. gar nicht mehr wahrnehmbar.
getestet in UWQHD/144 und 4K/120
Bin sehr zufrieden, brachiale Leistung die werde ich behalten. Für UVP kann ich damit sehr gut leben. :)
Hat einer die 4090 in einem Evolv X Case verbaut?
Also die Gigabyte Windforce hat auch Spulenfiepen aber es hält sich in Grenzen!
Habe einmal Stock Timespy normal laufen lassen hier waren es 31857 Grafik Score. Kann man das als Okay nehmen oder ist das für ne 4090 recht schwach?
Die Umwandlung des Stroms aus der Wand erzeugt Wärme. Wenn sich die Komponenten erwärmen, steigt ihr Widerstand, sodass mehr Strom für den Stromkreis benötigt wird und die Wärmeerzeugung und der Widerstand weiter zunehmen. Wenn wir diesen Zustand dauerhaft haben, und nicht nur schub/phasenweise, werden die Komponenten (zu) heiß und werden entweder mittel-/kurzfristig beschädigt, was ihre Lebensdauer verkürzt, oder sie fallen spektakulär aus und es kommt zu Funkenbildung und Bränden. Wenn man die ganze Zeit mit der maximalen Nennleistung arbeitet, entsteht eine Menge Wärme. Das sollten man also schlichtweg nicht tun. Je weniger das Netzteil belastet wird, desto besser ist es im Hinblick auf Stromverbrauch und Wärmeentwicklung.
Zudem kommt natürlich hinzu, dass die wenigsten Netzteile auf solche Dauerbelastungen ausgelegt sind. Das sind Spitzenwerte die von Herstellern beworben und getestet werden, nicht 24/7 6 Jahre lang an der Kotzgrenze laufen.
ich nehme jetzt mal das 850 watt straight power als ausgang, da ich meine mich zu erinneren, dass dies der ausgang für den posting war.
zum thema effizienz ist dazu zu sagen:
im optimalen bereich ca. 50 % auslastung erreicht das netzteil hier im luxx test eine effizienz von ca. 93,5 %.
dagegen erreicht es bei 100 % last "nur" noch eine effizienz von 91,2 %.
wir reden hier also über einen verlust von etwa 2 %, da kann man jetzt streiten ob wir hier über eine menge stromverschwendung reden oder nicht.
be quiet! Straight Power 11 - 550W & 850W im Test
und nach deiner aussage deute ich es so, dass die hersteller ihre netzteile nicht auf 100 % last auslegen?
für was genau legen sie denn die netzteile aus, kann ich das beim hersteller irgendwo nachlesen?
was darf ich dem 850 watt netzteil zumuten?
@SH nicht eingeholt , dafür aber ne Geile Punktzahl. Bin glaub Fertig. SweetSpot liegt in dem bench bei +210MHz // +1600MHz
PS: Mit Temp kann man noch sehr Viel rausholen. Hatte für den Test die Karte auf 100% RPM Direkt mal 10grad Kühler und BoostTakt war dann auch 3090MHz. Ich freu mich schon die Karte meinem MO-RA vorzustellen :)
Also nur kurz nochmal zu meinen Problem das ich keine PCIE x16 4.0 auf meiner 4090 Tuf Oc schaffe.
Ich habe die Tuf 3090 wieder iengebaut und die funtioniert sofort mit PCie 4.0,dann habe ich die 4090er wieder eigebaut und trozdem nur PCie 3.0.
Sogar mit dem 4x Adapter statt dem Corsair Kabel .....Tzzzzzz das ich wiedermal so ein Pech habe und eine Defekte Karte erwischt habe??
Hast du mal den 3dmark PCI E Test gemacht?
Bei 3.0 hast du ca. 13Gbits und bei 4.0 26 Gbits
Hier gibt es 3dmark recht günstig https://www.mmoga.de/Software/Steam/3DMark-Steam-Key.html
Kaufe da seit Jahren ein.
Habe leider selber nur ein 10900K und da geht max. 3.0
PSU Hersteller reden in aller Regel nicht über ihre Tests zu den Netzteilen, dazu gibt es nicht so viele Informationen. GN hatte vor Jahren mal ein Video gemacht zu dem Thema, als einer der Hersteller die in seine Fabrik reingelassen hat (ohne Branding) - dort konnte man nur sehen, dass die Netzteile für eine gewisse Dauer (wir reden von Minuten bis wenigen Stunden, nicht länger ("testing is brief" wurde damals dazu gesagt)) nach dem Burn-In in einen einfachen Funktionstest reinkommen (CHROMA Tester). Weitergehende Dauertests gab es dort nicht.
Offiziell wird über die einfachen Parameter hinausgehend (die beworben werden) nur garantiert, dass die Spezifikationen von Intel (ATX) eingehalten werde (zB gewisse Millivolt Ripple Grenzen dürfen nicht überschritten werden). Alles andere kann nur durch Reviews/Erfahrungswerte herausgefunden werden; es sei denn natürlich, ein Industrie Insider packt aus. Dass Netzteile, die an der Kotzgrenze laufen, mit stark erhöhter Wahrscheinlichkeit zu Problemen führen, entstammt schlichtweg als Erkenntnis der Erfahrung: Gab/gibt - über die Jahre hinweg - (zich) tausende Berichte im Netz von Leuten, denen ist die GPU abgeraucht (und/oder andere Teile) und da hat sich hinterher rausgestellt, dass die Netzteile und/oder Kabel unterdimensioniert waren. Mal ganz abgesehen vom grundsätzlichen technischen Verständnis über Strom und Widerstand (s.o.), der nunmal bei Dauerbelastung gewisse Probleme vorhersagt (Heimverbrauchergeräte haben nunmal keine bis wenig Redundanz, um kaputte Schaltungen aufzufangen, wenn also irgendetwas schief geht, kommt's meist direkt zum Absturz/Abschaltung und/oder dauerhafter Beschädigung bzw. signifikanter Funktionseinschränkung).
Keine Angst habe auch ne TUF und selben Punkte wie du @ Stock.
20000 Punkte habe ich bei +245 GPU und +525 Speicher.
Also im normalen Timespy ist definitiv CPU limitieren.
Da bekommen nur die die dicksten Punkte die über die dickste CPU verfügen.
Leute mit meiner suprim x….wie warm ist eure Karte im desktobetrieb? Bei mir wird wird sie 54 grad….kommt mir etwas zu hoch vor
TUF OC
0,95V 2760Mhz Ram +500
Also 25% weniger Verbrauch bei ca 5% weniger FPS lohnt sich definitiv. Und kühl bleibt es im Gehäuse so auch.
hab nur 19185 @ Stock Gigabyte Windforce :(
Wollte meinen I5 12400 noch gegen nen i7 13700 tauschen. Denke das macht noch viel aus
Liegt wohl an der CPU. Die Grafikkarten sind Stock alle gleich.
Die Halterung von Fractal ist echt super!
Ich hab es nicht hingekriegt die sauber zu montieren, daher erstmal weggelassen.
Meine TUF hat schon beim speedway benchmark bei den knappen 100fps ein ziemlich hörbaren coil-whine. Weit stärker als meine alte 3090 FE
Denke nicht das es soviel ausgemacht.
Ich habe mit meinen uralt 9700k und DDR4 3200 19540 Punkte siehe Bild.
Obwohl deine CPU etwas besser ist als meine habe ich dennoch etwas mehr Punkte
Port Royal/Speedway bei 2820/+658MHZ bei 975mv
Hat sich hier jemand mal Schlau gemacht zu der Schraubhalterung bzw. Schraublöchern an der FE 4090? Diese ist für Industrie/Workstation Gehäuse vorgesehen, wo man die Karte horizontal am Gehäuse nochmal zusätzlich befestigen kann.
Gibt es da für den Heimanwendermarkt irgendwelche Alternativen bzw. Adapter? Würde meine Karte gerne irgendwie dort zusätzlich befestigen, aber die "normalen" Gehäusehersteller haben in der Richtung nichts.
Edit: hiervon rede ich (vertikalen, schwarzen Metallstreifen ignorieren, hatte Igor bei dem Bild dazu gelegt)
Haltet Ihr eure Ohren alle an den Grafikkarten?
Also ich höre bei keiner bei UHD irgendein Zirpen?
Ich dachte mal meine GTX970 zirpt. Aber im Endeffekt war es das Netzteil. Kann es das evtl. auch bei dem ein odere anderen sein?
Meine Gigabyte Windforce hat ca. 50 Grad im Desktop und beim Benchen mit Silent Bios hatte der GPU Hotspot 82 Grad und GPU max 72 Grad Speicher zeigt GPU Z nicht an.
Laut verschiedenen Test soll die 4090 FE nur 33 Grad am Desktop haben. Meine Stand da schon mit 52 Grad drin.
Bis jetzt bin ich schon sehr zufrieden mit der Gigabyte. Leistung meist 100-120% über meiner 3080 12GB im Benchmark.
die 3090 / ti sieht wirklich schlecht aus im vergleich. wenn man nur die balken vergleicht, wirkt die 3090 ti wie eine 3060 :d
schon krass wie die karten abgehen.
Thrawn wahrscheinlich auch nicht, das Alter bzw. der Gehörschaden regelt. :oops:
Einer Aussage bezüglich nicht oder kaum vorhandenem Spulenfiepen von jemandem der 50+ ist würde ich nur bedingt trauen. :sneaky:
Der gute Holzmann hat ja auch so ein lautloses modell, bei dem wundert mich nix mehr :d
lautlose spulen gibt es auch bei der 4090 wieder nicht. aber wie jede gen gibts halt wieder märchenstunde von einigen hier und die user die nicht die wahrnehmung einer kartoffel haben, fühlen sich dann scheiße mit ihrer karte, zu unrecht
@cHio
Was für Karten hattest du bislang? Ist die suprim die schlechteste bez. Spulenkrach?
Meine Macht schon Geräusche.. manchmal singt sie sogar etwas. Werde jetzt mal Power Limit runter setzten oder UV testen
Port Royal habe ich 25490 noch Stock wollte gleich UV testen.
Meine Fällt jetzt schon auf 47 Grad. War noch über 50 direkt nach den Benchen.
