[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Liest man leider häufiger mal, dass die nicht 100% dicht sind :(
Gab wohl Chargen wo dies der Fall war .
Mein HK Tube D5 ist über 5 Jahre alt und bisher immernoch dicht . Schönes Teil eigentlich .
Also wenn ihr noch wenn kennt oder selbst betroffen seit kurz pn und die S/N nummer an mich.
Ich glaube, dasselbe Problem zu haben... bin hier sogar durch Zufall drauf gestoßen.
Leider kann ich dir @memphis@mg keine PM (aus "Spamschutzgründen") schreiben... erst in 2 Tagen. Vll schreibst du mir, wie ich dich kontaktieren kann. :)
Hab die Nieten geknackt... damit ist aber der Käfig im Arsch.
Bei Hunt Showdown mit Undervolting auf 875mv habe ich durchgehend 97 FPS (100 hz Monitor). Karte verbraucht 104 bis 120 watt und ist max 36°C kalt.
Schau dir mal Hunt mit Upsampling an !
:ROFLMAO:
Bisschen rumgespielt,
So aus dem Stand bei dem neuem Bench Speedway die Suprim mit Silent Bios :banana:
ist sogar durchgelaufen xD
Mein Intel ist halt nicht mehr so der schnellste
Aber die Karte macht sich gut
Bis an die 3135 Mhz
Durchschnittliche Taktfrequenz 3110 Mhz
Herzlichen Glückwunsch, obwohl ich schon etwas madge bin dass jemand der nach mir bestellt hat seine FE bekommt und ich nicht 😭
Bin auch nach wie vor pissed, weil ich a) keine Custom in mein Gehäuse bekomme und b) von der Optik her auch nur eine FE will.
NBB hat die Stornos mal wieder komplett random ausgewürfelt. Nach all den Infos die wir hier kollektiv sammeln konnten gibt es kein Schema, das in irgendeiner Weise Sinn ergeben würde. Spätere Bestellungen gingen durch, Zahlungsmethoden egal, sogar Bestellungen über die NV Seite wurden storniert etc. :eek:
Bin schon versucht eine vom Scalper zu kaufen...
Würde mal abwarten mit der FE , weil die Vermutung nahe liegt , dass etwas nicht mit den Lüftern inordnung ist .
Whoopsie daisy, ich hatte gerade was merkwürdiges: Übertaktet, dann Crash mit bunten Bildfehlern. Soweit nichts spektakuläres. Beim Neustart jedoch ohne OC beim Windows Login sofort wieder Crash, auch nach stromlos stellen. Musste dann in den abgesicherten Modus und mit DDU drüber, dann ging's wieder :hmm: Hatte ich so noch nie, dachte schon direkt Schrott :fresse2:
Ich gucke nämlich gerade... mein Heatkiller-Tube ist unten an den vier Säulen leicht undicht :(
Christian von Watercool hatte mir neue O-Ringe angeboten, aber irgendwie ist das Vertrauen gerade nicht da. Es gab nämlich einen Fehler, dass das Glas leicht schief durch die Glashütte ausgeschnitten wurde.
Puh, ich hatte heute auch nen Herzinfarkt Moment mit meiner watercool Durchführung. War nach dem Einbau undicht. Hab Glück gehabt, das es von außen war. Hab die fittinge nicht fest genug gezogen gehabt ...
Na sowas...
Gestern noch 6-7 Wochen - jetzt wieder 1-3 Tage :d
Wird doch nicht der Block sein, den ich gestern storniert hab :fresse:
Liegen doch noch welche bei aquatuning rum.(y)
Ich habe auch das selbe Problem mit den Lüftern der Gainward Phantom GS, PN geht aber erst wegen SPAM Gefahr in 2 Tagen.
Krass, das scheint ja echt ein großes Problem zu sein. Glaube du bist die Nummer 5 nur hier im Forum. Und von der Palit habe ich auch schon gelesen, dass dasselbe Problem auftreten kann. Da scheint was gehörig schief zu laufen in der Fertigung. Mich stört es nicht besonders und ist nur ganz leicht zu vernehmen aber wenn man später die Karte wieder verkaufen will könnte das ein Thema sein. Früher oder später werde ich da wahrscheinlich auch ein RMA machen müssen, falls sich das nicht über die Zeit komplett legt. Leider sind Gainward und Palit die einzigen Modelle neben der FE, die bei mir ins Gehäuse passen und noch gerade so bezahlbar sind, daher werde ich da jetzt auch nichts retournieren bei der aktuellen Verfügbarkeit.
Geil, meine TUF OC ist DOA, der mittlere DP Anschluss funktioniert nur sporadisch.:wall:
Ich bin ja mal sehr gespannt ob und wie die RMA abläuft, um 9 mal bei CU anrufen. Ich habe keine Lust jetzt Wochen oder Monate ohne Karte da zu stehen.
Nicht zu vergessen, das es einige Fälle gab wo NBB mal wieder ein Systemfehler hatte und keine Bestellungen überhaupt ankamen...
In meinem Fall, Bestellung über NV Store und mit Amazon-Pay. Die Bestellung ging auf meiner Seite komplett normal durch, auch Amazon-Pay hat eine richtige Bestellnummer etc. Aber NBB hat angeblich nie was davon gesehen.
Ich will auch unbedingt eine FE...meine 3060Ti ist entweder das schlechteste Silicon das es gibt, oder der Kühler selbst hat einen Fehler...Es ist eine Dual Mini 3060ti und ich kann die nur mit <150W laufen lassen, da sie sonst 100°C heiß wird... Zuvor war eine 3090FE im PC und die kam mit 400W nicht ans Limit...am Gehäuse liegt es also nicht. :d
Daher brauche ich eher dringend eine neue GPU und nur die FE passt hier rein...
Das war auch schon bei meiner 3090Fe der Fall und die hatte ich 10 Monate nach dem Launch bekommen.
Ist nur der mittlere defekt oder ist der mittlere der einzige der wenigstens etwas funktioniert? Das habe ich nicht ganz verstanden. Wenn nur der mittlere defekt ist und die anderen gehen und Du nicht zwingend sofort drei Monitore anschließen musst, dann kannst Du auch erst mal warten, Du hast ja mittlerweile 12 statt 6 Monate bis zur Beweislastumkehr und es läßt sich jederzeit argumentieren, mann hätte es erst bemerkt als man versucht hat einen neuen Monitor da anzuschließen und daß der Mangel somit schon zu Beginn bestanden hat. So könntest Du die RMA ggf. in einen Zeitraum verschieben wo die Verfügbarkeit besser aussieht als jetzt. Und der Defekt ist ja zu Beginn schon wirklich dagewesen, also betrügst Du auch aus meiner Sicht auch niemanden, Du verlegst lediglich den RMA-Zeitpunkt der Dir sowieso zusteht auf einen Zeitpunkt der Dir besser passt und für den Händler sollte es keine Rolle spielen, er muss Dir eh Ersatz liefern. Ist für ihn vielleicht auch besser als jetzt wo er nicht liefern kann. Nur so ne Idee.
Grundsätzlich keine schlechte Idee. Allerdings möchte ich 3 Monitore anschließen und der mittlere ist kaputt, die anderen 2 funktionieren. Ich kann das ganze erstmal umgehen in dem ich HDMI benutze, allerdings taktet die GPU nicht runter wenn man Displayport und HDMI mischt. Das macht 45 watt unterschied, bei 16 Stunden Betriebszeit pro Tag macht sich das schon bemerkbar :LOL:
Vielleicht warte ich wirklich noch ein paar Tage ab und hoffe das die Verfügbarkeit besser wird.
So sieht das nebenbei aus. Falls es nach 20 mal ein und ausstecken Bild gibt.
kleines statusupdate:
gemeldet oder auch hier angekündigt sind es aktuell 10 user incl mir. also von "nur" einem zufall kann hier nicht mehr gesprochen werden. ich werde auch palit dazu noch eine email schreiben da die 1:1 gleichen kühler verbauen UND die gleichen lüfter benutzen!
bedenkt bitte es ist wochenende also eh ich eine antwort bekomme wirds noch einige tage dauern!
Bis an die 3135 Mhz
Geil! Mit wieviel Volt bist du auf die 3,1 gekommen? Meine schafft knapp 3 Ghz mit 1,1v aber alles im grünen Bereich, hatte nur den Wunsch die große 3 zu knacken und das passt ja. Vram geht bei meiner TUF non-oc ganz gut, +1500 läuft. Karte hängt an einem Pcie 3x Riser Kabel, aber scheint ja für die Performance wenig auszumachen. https://www.3dmark.com/3dm/81017180?
In der Speed Way Hall of Fame kommen ein paar Namen sehr bekannt vor :LOL: https://www.3dmark.com/hall-of-fame-2/speed+way+3dmark+score+performance+preset/version+1.0
@SH @TobiWahnKenobi @Brainscan1979 @Holzmann @Don @Dampfkanes
#10 😘 freut mich einfach für dich!
#40 Raffster ist übrigens er hier
@Dwayne_Johnson Im Benchmark nimmt sich die TUF schon bis zu 500W
Hey mein Gehäuse ist in Zustellung. Also kann ich dich meine Gigabyte heute testen ♥️
Ja gebe gleich Bescheid. Werde sie auch UV oder PL. Dank des neuen Cases Ist das NT oben da tausche ich das Kabel dann schnell mal so.
Dauert aber etwas hatte noch nie RGB Lüfter und Lüfter Hub. Erstmal alles lernen. Und am Mini ITX hab ich ja nicht viele Anschlüsse.
Hier mal meine Taktraten und Temps unter Last:
Hm, Deine Temps sind deutlich höher als meine. Den Gesamtscore können wir ja logischerweise vergessen, da Du ja offensichtlich die E-Cores disabled hast, gelle. Ich habe ne ziemlich ähnliche Konfig und meine Suprim boostet auch nicht über 3GHz und dennoch hab ich im Graphicscore im Schnitt etwas höhere Werte was mit den E-Cores zusammenhängt denke ich. Aber die Temps!!! Ich muss allerdings sagen, dass ich die Lüfterkurve editiert habe. Ich hatte übrigens die Werte aus dem OC-Scan vom Afterburner erstmal übernommen und sogar den RAM-Takt bei diesem Run etwas reduziert.
https://www.3dmark.com/3dm/80985044
Was hast du vor mit CUDA?
Wenn du benchenn willst, sind 2 kleine RAM-Riegel schneller, als 4 Große. Aber das weißt du ja sicher ;)
Schach - lc0
Dieses Programm behält den gesamten Suchbaum im Speicher und crasht wenn der voll ist. Von daher sollte man bei starker Graka nicht unter 128 GB anfangen. Alternativen zu dem Programm gibt es im Bereich KI nicht.
Versuchs mal in 4k die 4090 ist sogar schneller hier wie 2x 3090
Es geht um CUDA für KI - da rechnet die Graka nur, die Auflösung hat keinerlei Einfluss, da nichts in 3D gemacht wird.
Ich hab jetzt 75% CPU Auslastung in Cyberpunk in 3440x1440p WTF das ist mal wild. Ist ein 10900k mittlerweile nicht mehr zeitgemäß ???
Montag kommt jetzt endlich meine Suprim X von proshop bestellt am Mittwoch 15:01.
Ist halt DPD und ein langer Weg von Dänemark nach Österreich. Dafür hatte ich gleich Erfolg bei der Bestellung.
Also nur kurz nochmal zu meinen Problem das ich keine PCIE x16 4.0 auf meiner 4090 Tuf Oc schaffe.
Ich habe die Tuf 3090 wieder iengebaut und die funtioniert sofort mit PCie 4.0,dann habe ich die 4090er wieder eigebaut und trozdem nur PCie 3.0.
Sogar mit dem 4x Adapter statt dem Corsair Kabel .....Tzzzzzz das ich wiedermal so ein Pech habe und eine Defekte Karte erwischt habe??
Vielleicht auch mal die PCIE-Schnittstelle der TUF checken ob da irgendwie eine Verschmutzung vorliegt. ich hatte sowas mal vor Jahren und bei mir lag es nach dem Zusammenbau daran, dass doch tatsächlich ein klitzekleiner Rest Wärmeleitpaste bei meiner CPU auf den Kontakten war. Das kann es aber bei Dir nicht sein. Aber vielleicht ähnliches auf der Schnittstelle der TUF!?
