[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Irgendwie bin ich froh keine FE mitten im hypetrain bekommen zu haben und die customs interessieren mich 0. Wüsste gar nicht was ich jetzt zocken sollte mit der 4090 da ich die meisten AAA schon durch hab oder aufgehört habe da sie brutal langweilig waren :fresse:
Das Dark Power Pro 11 aber nicht. Dachte immer die Stecker sind netzteilsetig kompatibel zueinander.
Es kommt halt drauf an was im Netzteil verbaut ist.
Offiziell ist PCIe 6+2 halt auf 150Watt garantiert/begrenzt das muß jeder Stecker/Buchse selbst mit den billigsten Messing Presskontakten aushalten die es auf dem Markt gibt.
Wenn aber BQ hochwertige Stecker/Buchsen z.B. vergoldete Kupferkontakte nimmt und dazu auch dickere Kabel verwendet können die halt auch 300Watt erlauben.
Was man aber jetzt nicht machen sollte ist das BQ Adapterkabel in irgentein anderes Netzteil (sei es von BQ oder Fremdherrsteller) stecken weil man halt nicht weiß ob das Netzteil halt für 300Watt über einen PCIe ausgelegt ist.
Das kenn ich, der beste Moment ist aber, wenn er nach dem nächsten Update schon vorbei gefahren ist und man nichts bekommen hat
oder er angibt "eine zustellung war nicht möglich" hää ich bin doch hier !!! :stupid: ... und die sendung wird nun zur nächsten filiale gebracht und kann dort frühsten am xxxxxxx abgeholt werden, toll wofür zahlt man da eigentlich? .... ende der geschichte, 2. zustellung beantragt, fahrer holte sendung nicht ab, lagerfrist über schritten, sendung zurück zum versender !!! weil keiner bock hat und sie selbst in der filiale nichts wissen oder überfordert sind, nur ärger !!! :(
Meine PSU: 750W Titanium Seasonic
Setup:
RTX 4090 Suprim auf Max OC (522 Watt laut AFterburner)
5900x
10 RGB Lüfter, AIO
PC schaltet sich nicht ab!
Aber ich weiß dass es sehr knapp ist.
Wenn ich den 5900X auch max übertakten würde, geht er aus.
War bei 3090 Strix auch schon so. Graka oder CPU max oc = ok. Beides max OC + 100% last = Pc aus. Aber soviel strom will ich eh nicht verballern, deswegen will ich niemals ein höheres netzteil :) Die wärme im Zimmer ist enorm und die stromkosten auch.
Hmmm, bei mir könnte ich mit dem Fahrrad (kein Auto, denn man muss ja Prioritäten setzen) zum Postauslieferungslaster fahren, denke aber bei der Paketgrösse bräuchte ich nen Fahrradanhänger ;)
ein größeres Netzteil heist doch nicht das er gleich die Leistung verbraucht. Nur wenn sie abgerufen wird. Da kannst du trotzdem ein 1200W Netzteil nehmen wenn nur 500W verbraucht werden.
Anderer User hatte ja schon Kontakt mit dem Support:
Nachdem das NT ausreichend ist meine 3090 zu versorgen würde ich auch annehmen das es mit dem Adapter eine 4090 packen würde. Da ich aktuell aber noch unentschlossen bin ob ich mir überhaupt eine kaufen soll ist die Frage eh rethorisch. Muss mich mal schlau machen was man so für ne 3090 heute noch gebraucht bekommt.
Man muss sich das alles eben nur so zurechtlegen, damit man keine +2000 Euro für eine GPU transferiert. Gute Methode. :d
Bei CaseKing kostet die normale TUF einfach mal 400€ mehr als bei ASUS direkt. Wie rechtfertigt der Saftladen das eigentlich?
2.43K für die TUF, wo Asus die selbst im Shop für 1949 € vertickt hat... frech.
Ist die OC Variante und die kostet bei ASUS auch 2,23K
Setup:
5900x
10 RGB Lüfter, AIO
Dann bin ich ja guter Dinge, dass es bei mir auch klappt :fresse2:
Setup:
5900x
10 RGB Lüfter, AIO
Das kannst du auch nur bei Seasonic NTs machen …
Würde keinem empfehlen sowas zu machen es gibt Netzteile die bei Überlastung das brennen anfangen oder noch schlimmer Spannungen Plötzlich extrem nach oben knallen. Das war’s dann nicht nur fürs NT sondern auch für z.B. MB, CPU oder GraKa …
Also wie gesagt Vorsicht bei solchen Tests mit doch recht teurer Hardware!
Naja ganz so schlimm ist es nicht, es ist die OC version, diese kostet bei Asus 2230€, es sind also 200€ Aufpreis bei Caseking, ist aber natürlich immer noch viel.
Setup:
5900x
10 RGB Lüfter, AIO
Karte für 2k aber kein NT was noch genug Reserven hat
OK 🤣🤣
Du nimmst ja auch originale BQ Kabel die von deinen Netzteil auf 2 * PCIe 8pol gehen, damit wird BQ auch sicherlich sowohl das netzteil als auch das Adapter kabel für 300Watt ausgelegt haben.
Dabei hätte ich auch keinerlei bedenken.
Ein anderes Thema ist halt wenn man externe Y-Kabel nimmt die aus 1* PCIe 8pol 2* PCIE 8pol machen.
Finde gut, dass es nun schon genug Karten gibt, zwar nicht die die man will, aber denke nächste oder übernächste Woche sollte dann jeder die Karte haben, die er möchte. Ne TUF möchte ich angesichts der Strix oder Suprim nicht, auch wenn sie wahrscheinlich mehr als ausreichen würde.
Meint Ihr die Karte passt da rein :d
Leider nicht also aufs Case warten oder offener Aufbau!
Das ist auch die OC Variante, die boostet 45! Mhz höher. Also gerechtfertigt der Preis :fresse:
Dieses ganze OC und nicht OC Karten System ist seit dem Auto-Übertakten/Spannungsanpassen der Karten eh Unfug. Die Teile werden nur noch durch Kühlung/Luftstrom/Chipqualität limitiert, da spielt die Software quasi keine Rolle - und von der Hardware sind die ja alle gleich.
Wer also wegen faktisch 5-30 Mhz (soweit die überhaupt die Chips händisch selektieren, unwahrscheinlich bei dem Kostenaufwand - vermutlich verpacken die einfach dieselben Karten unterschiedlich für künstliche Produktvielfalt) mehrere hundert € mehr ausgeben will, der möge sich eben an seinem Produkt erfreuen; ich verbleibe mit ner hochgezogenen Augenbraue.
Macht nicht jeder Paketdienst mit...
Hatte ich mal bei Amazon versucht. Dazu bis ich die 500m hingelaufen. Paket wollte er mir trotz Ausweis nicht geben.
Warum?
Die Fahrzeuge haben ja Echtzeit-Tracking und wegen "Mauscheleien" dürfen sie Pakete NUR am Wohnort abgeben ;)
War aber schon 2 Jahre her...
Was hat der Gute gemacht?
Hat mich in seinem Transporter mit vor die Haustür gebracht :d
3€ pro MHz :fresse:
Diese +45MHz machen vielleicht +0,1fps aus :d
Das war bei der 3090 schon absolut unlukrativ von der reinen Leistung her eine höherpreisige Custom zu kaufen. Lediglich in Bezug auf eine bessere/leisere Kühlung hatte es Vorteile.
Aber zu welchem Preis?
Die Preise steigen gefühlt jeden Tag um jeweils 100€ mehr :rolleyes2:
