[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
weil corsair hier lügt und sich ausserhalb der spezifikation bewegt.... evtl haben die aber hier wesentlich dickere querschnitte in ihren kabeln UND ihren netzteilen, und die RAILS sind so ausgelegt, dass über 1 8 PIN 300 watt dauerhaft gehen. das garantiert dann aber nur corsair so ..und gilt sicherlich nicht für alle anderen ...
ich würde dieses Kabel NIE verwenden,
Es gab ja gestern das Drama auf dem Discord von GamersNexus mit JonnyGuru (Netzteil Entwickler für Corsair) der dort ziemlich "ausgerastet" ist, nachdem er GN und Guru3D unterstellt hat sie würden "Falschinformationen" und "Totalen Schwachsinn" verbreiten mit der Aussage, die 4090 erkennt wenn von den 4 Adapterkabeln lediglich 3 oder weniger angeschlossen werden.
Später stellte sich heraus, dass er - angeblich - von Nvidia falsche Informationen bezüglich der Spezifikation (Verschaltung/Relevanz der Sense Leitung) bekommen hat. Ich wäre mir also gar nicht so sicher, ob deren Adapter so funktioniert wie er soll :rolleyes2:
Wenn BeQuiet! ein Kabel raus bringt das NT Seitig mit 2 Steckern angeschlossen wird, wird das schon so passen denke ich!
Meine Karte ist in 5 Min da! :d Leider wird alles nur auf den Tisch montiert da das Gehäuse erst Montag kommt und da bin ich 1 Woche weg.
Offener Aufbau ist auch mal was tolles. Vielleicht ist dann das neue Netzteil Kabel schon da und ich kann alles richtig einbauen.
Nun gut, jetzt kommt die TUF doch heute statt morgen und ich sitz im Büro, schade :d
Das war JonnyGuru? Der galt in den USA ja eigentlich immer als allwissender PSU Gott.
Meine TUF kommt gleich an, aber so richtig Bock hab ich nicht ^^
Muss dann die 3090 Strix mit WaKü Block entsprechend aus dem Kreislauf entfernen :kotz:
Werde es aber notdürftig machen, richtig warten werde ich es dann, wenn der Block für die 4090 antanzt.
Bei mir auch. Mein schöner Build, völlig zerrupfen, ne hässliche Soft-Tube von der Pumpe zum CPU Block als Bypass legen und warten ob Bykski oder EK schneller liefert :d
Kabel ist jetzt bei Computeruniverse kurzfristig lieferbar. (3-5 Tage)
Liefertermin Unbekannt!
Moin zusammen!
Heute wird meine 4090 FE geliefert. Da ich mit so einem Monster zuvor noch nie hantiert habe, bin ich nun ziemlich verunsichert, wie ich die Karte an das Netzteil anschließen muss.
Ich habe ein Corsair RM750x. Ich werde die Karte zunächst mit 70% PL betreiben, da ich das Netzteil erst aufrüsten möchte, wenn ATX 3.0 so richtig am Markt angekommen ist - falls das überhaupt erforderlich sein wird.
Ist es richtig, dass ich das mitgelieferte Kabel der 4090 FE einfach direkt an das Netzteil anschließe und zwar an die eingerahmten Anschlüsse? Oder benötige ich noch Kabel von meinem Netzteil, die ich zunächst mit dem Kabel verbinden muss? Ich möchte nichts falsch machen. :)
PS: Ich habe hier schon ewig mitgelesen, mich aber heute endlich angemeldet. Also an dieser Stell noch ein "Hey! :)" von mir.
Bei der Karte ist ein Adapter bei welches du mit deinen pci-e 8pin vom Netzteil verbindest.
Für rund 20€ kannste aber bei Corsair direkt ein passendes Kabel für dein Netzteil bestellen mit diesem (16-Pin) Anschluss.
Liefertermin unbekannt!
Lustig wie jetzt hier die Diskussionen über Adapter für die 4090 zum Hauptthema werden. :d
Ich habe mir ganz entspannt in weiser Voraussicht bei Cablemod den passenden Adapter konfiguriert und bestellt:
Als ich heute um 8:00 bestellt hab, war es noch "kurzfristig lieferbar", hoffentlich bin ich dann bei der ersten Fuhre dabei....
Zumindest laut Bestell-Details: Wareneingang bei uns voraussichtlich erwartet am 19.10.2022
Das hat sich auch nicht groß geändert, es denke es war hier einfach ein Missverständnis bzw. die Information fehlte Ihm einfach. Er hat vielleicht bisschen arg reagiert und hätte Gamers Nexus nicht schlecht reden sollen. Gerade "Tech Jesus" macht doch alles 300%ig.
TuF TuF (scalpling addicted)
detect
Unabhängig davon hat dieses Thema für sehr viel Verwirrung gesorgt bzw. tut dies noch immer. Wenn ein NT mit Splitter Kabeln ausgeliefert wird, welche dann 300W leisten über 1 Kabel, dann sollten diese meiner Meinung nach auch verwendet werden können. Anderer Querschnitt hin oder hin, alles andere wäre doch reinster Wahnsinn und die PSU würden links und rechts explodieren.
Da fühle ich mich mit meiner TUF OC von saturn ja als hätte ich einen Schnapper gemacht :-)
Die Kaufen wahrscheinlich irgendwo selber teuer ein. Ich weiß nicht was solche Händler immer treiben ^^
Konnte eine ZOTAC Extreme Airo in den Warenkorb packen und per Vorkasse tätigen
Falls wer Interesse hat 😄
Ich hätte es wirklich nicht gedacht, dass nach dem Release die Preise hoch gehen.
Aber wenigstens ist die Verfügbarkeit nicht so erbärmlich wie zu 3090-Release.
Also nix gegen die Mitarbeiter von Caseking aber das sind schon gesalzene Preise und m.E. maßlos übertrieben!
Ähnliche Themen
Antworten
7K
Aufrufe
583K
