[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Endlich das gute Stück ist da
auch mal so zum thema ..der "neue" 12+4 pin an schluss ist wesentlich filigraner und empflindlicher was da die hitze angeht wenn du 3 mal so viele watt durch eine leitung ballerst wie vorgesehen .... ich würde es nicht riskieren auch schon nicht mit der 3090 :d aber muss jeder selber wissen ;D
shakoon als "gut" zu bezeichnen grenzt schon an körperverletzung ;D was hatn das teil überhaupt für ne zertifizierung ? Bronze ? edith sacht: ok es hat gold ...geht ja gerade noch so :d
Es gibt Menschen mit gewisser Schreibweise und inflationärer Falschverwendung bzw. fehlen von Satzzeichen, deren Wust an Worten an Körperverletzung grenzt ...
Das ist so natürlich falsch durch seine 1 auf 2 PCIe Splitter werden 'NUR' die eingangseiten der Splitterkabel und die Verbindung zwischen den und dem Netzteil überlastet , beim 12+4 Pin wird es keinerlei überlastung geben.
Be Quiet Straight Power 850W Frage.
Also muss ich bevor es das neuen Bequiet Kabel gibt so anschliessen, dass ich 4 einzelne Kabel vom Netzteil in die 4 Buchsen des 4090 Adpaters stecke?
Ich kann nicht 2 Kabel mit 4 Y Steckern an den Adapter anschliessen?
Was passiert dann? Meine 3090 hängt an einem Kabel mit Y Stekcern und zieht bis zu 375W. Warum kann dann die 4090 nicht mit 2 Kabeln 600W ziehen?
Sorry für die Frage aber ich peile es noch nicht.
Viel Spaß damit :) Ich bin gespannt ob bei der OC die Chips besser sind als bei der non OC. Nach der Ernüchterung bei meiner Suprim gehe ich davon aus, dass es wieder reine Lotterie ist. Unabhängig von Modell und Preisklasse (mit Ausnahme FE vermutlich). Meine TUF kommt heute, ich werde berichten.
Hab mir das Bequiet! Straight Power 850W Platinum bestellt. Laut Hompage soll es ja mit den neuen Kabel reichen für die 4090. hab ja nur nen 12400 i5 der zieht nicht viel.
Kabel habe ich noch keines sind ja ausverkauft
Kauf das Kabel bei Computeruniverse.
Das stimmt doch gar nicht. Die 8-Pin Buchsen am Netzteil können alle 300 Watt. Sonst gäbe es ja keine Y-Kabel. Alles im Rahmen.
Peak, nicht sustained. Da sollte man kein Vertrauen auf Dauer drin haben. Y-Kabel wenn möglich NICHT nutzen, sondern nur Einzelstecken. Wer keine 3 Slots an der PSU für die 4090 hat, sollte die auch nicht einbauen.
1x 8 pin hat 150 watt laut spezifikation .... klar kannst do dort auch 1 kw durchjagen ...aber eben nur kurz. über was reden wir hier, dass leute nicht wahrhaben wollen, dass man sein billo PSU nicht an ne 2000 euro grafikkarte hängen sollte ?
Beim Afterburner ist die Y-Achse der Voltage Curve ja auf 3000MHz begrenzt:ROFLMAO:
Oder hab ich einfach die neue Version vom Afterburner übersehen?
@Dampfkanes
Eventuell arbeitet Unwinder noch an einer neuen Version.
Es gibt ja diverse Betas (links gibts in der Regel bei Guru3D).
Letzte Beta, die ich auf Anhieb finde. 15. September. Als gerade mal einen Monat alt.
Bist Du eigentlich noch tief im OC? Wirst Du Deine 4090 mit LN2 quälen, oder ist das langsam Geschichte bei Dir?
einfach hier mitlesen :)
Du kennst also die Pinbelegung Netzteilseitig beim Sharkoon? Corsair hat auch nur 2x 8PIN auf 12VHPWR.
Beste Grüße
Nein, die Kabel sind für weitaus mehr ausgelegt. Meine es waren mehr als 300W.
Eine stark übertaktete 3090 zieht auch über 450W und die Kabel sind auch nicht durchgebrannt.
Suprim X SpeedWay
@Dampfkanes
Ich mach ja viel: MoRa im Winter auf den Balkon stellen inklusive Schläuche durch die halbe Wohnung + extra auf die CPU einen Luftkühler montieren + schwitzend unterm Tisch liegen, ob da jetzt ja noch nicht zu viel Kondenswasser entstanden ist. :ROFLMAO:
Oder mal im Winter für ne Stunde das Fenster auf und dann im arsch kalten Zimmer gebencht (zur GTX 580 zuletzt).
Oder das ganze System im Winter auf die Terasse gestellt (noch länger her).
Aber LN2 oder Trockeneis hab ich tatsächlich noch nie gemacht.
Da ist das Thema Spulen schon relevanter für mich. Seitdem ich weiß, das es da auch Modelle gibt, bei denen man quasi nichts hört (Ampere-Ref mit den hohen Spulen), achte
ich da mehr drauf.
zur 4090 Strix soweit:
Man hört tatsächlich "nur" das klassische hochfrequente Fiepen (z.B. 3080 FE, 3090 FE). Eine 3090 Strix, die ich mal hatte, hat ja eher unter Last (W) gerasselt, als das sie mit hohen Fps gefiept hätte.
Dieses Rasseln hat die 4090 jetzt zum Glück schon mal gar nicht.
Ob ich das jetzt mit Undervolting noch weiter runter bekomme (klappt bei meinre 3090 FTW3 sehr gut), hab ich noch nicht getestet.
Gestern wurden bei mir 3 Pakete verschickt. Eins DHL, eins Hermes, eins UPS. DHL und UPS werden heute zugestellt, Hermes morgen.
Dreimal dürft ihr raten in welchem die 4090 FE drin ist und wer ab morgen für ne Woche nicht Zuhause ist... Lustigerweise war Hermes gestern so optimistisch und hat ne heutige Zustellung prognostiziert, während DHL und UPS jeweils Samstag/Montag im Visier hatten.
Kaufst Du nun doch eine?
Mich würde ja noch interessieren, wie die Spulen bei der 4090 FE konkret sind.
Andere Karten habe ich wegen der voraussichtlichen Kühlerauswahl nicht auf dem Schirm.
Am schnöden Mammon habe ich tatsächlich weniger Interesse.
Uiuiui, wird ja noch besserer Tag. Schon so frühe Zustellung…
Erstens gehen auch 75W über die PCI-E Schiene, bei der 4090 ist dies eigentlich nicht vorgesehen.
Hatte die 3090 3x150W Stecker oder nur 2 bzw den 300W Stecker?
Und mir will NBB nicht auf meine Bestellung antworten...
so einfach mal lesen .... 1 - 8PIN hat eine SPEZIFIKATION von 150 !!!!! WATT NICHT MEHR NICHT WENIGER
2 x 8 pin 300 watt ..... und so weiter .... ohne worte das hier einige diese tatsache klein oder wegreden wollen
