[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gerade die Bestätigung bekommen, Gamingrocks kommen heute :d
Mal schauen was so ne billig 4090 reißen kann.
Beste Grüße
Dlss 3 macht nur bei bildschirmen ab 240hz sinn.
Man sollte mindestens 100fps nativ haben und dann erst dlss3 nutzen. Also nix da cyberpunk am oled smooth mit 120hz.
Und welche auflösung?
Na klar. Wenn du einzeln Frames begutachten willst....
Na Frame Generation ist noch am Anfang wie DLSS 1.0
Das kommt in jeder Analyse nicht gut weg!
Da muss man erst über die Zeit sehen was NV daraus macht!
Es ist halt eine Zwischenbilderechnung die derzeit noch Fehler aufweist sie auch die DF Analyse.
Auch Gsync funktioniert nicht wen ich das richtig verstanden habe nur Vsync dann aber mit noch stärkeren Inputlag!
Das ist erstmal alles noch Baustelle das sollte man wissen!
Man könnte einfach retournieren statt zu scalpen
Das gleiche wie jede andere auch. Nur in hässlich
Ach, ich finds sie z.B. schicker als die Strix, aber das ist ja für jeden anders.
Bin für selbe Leistung einfach nicht gewillt 400€ drauf zu legen.
Die Phantom ohne GS hätte ich auch genommen, war aber da schon weg.
Beste Grüße
ASUS Shop cached sehr merkwürdig und auch serversided (aber async für verschiedene Clients), daher stimmen auch die Verfügbarkeitshinweise des Luxx Bots noch nicht so ganz bei den sporadischen Redrops mit nur einer Karte. Werde ich, wenn ich aus dem Urlaub zurück bin, wohl umbauen und einfach Verfügbarkeit melden wenn das Carten klappt, glaube das ist bei dem Shop die beste Variante.
Apropos Verfügbarkeitshinweise... Mediamarkt wird seit Vorgestern 17 Uhr und Saturn seit gestern 17 Uhr nicht mehr getrackt (geht mal mit Inkognito Tab auf die Seite, dann wisst ihr warum)... kann ich leider aus dem Urlaub nicht so easy beheben.
Woher bekomme ich diesen luxx bot bitte?
Mega frech von Caseking für die tuf fast 300 Euro mehr zu nehmen als alle anderen Shops! Im Asus Shop gibt's die zum uvp Preis
Bei 4090 sollte eine VRAM-Übertaktung etwas bringen. Bitte postet eure VRAM OC Werte.
Hat schon jemand das neue Corsair Kabel in Betrieb am HX1200i!
Sollte ja egal sein wo die 2*8Pin da an geklemmt werden oder gibt es da bestimmt Ports führ ?
Das 12VHPWR-Kabel von be quiet ist vereinzelt auch schon im Handel gelistet, allerdings wird das wohl nichts mit kurzfristiger Verfügbarkeit. Meh. Warum haben die nicht selbst einfach mehr von dem Kabel über den Ersatzteilshop verkauft...
Kabel ist jetzt bei Computeruniverse kurzfristig lieferbar. (3-5 Tage)
Du musst min. 3 Buchsen am NT belegen. Und KEINE Kabel mit 2 Steckern an 2 Buchsen am Adapter anschliessen. So hast du max. 450W
Erst mit allen 4 Kabeln (also 4 Buchsen am NT) stehen 600W zur Verfügung
Nicht beim Dark Power Pro 12, da reichen zwei Buchsen am Netzteil da diese 12pin sind. Was du meinst ist nicht per DaisyChain verbinden. Mein Netzteil hat kein DaisyChain die Y-Leitungen sind im Grunde Doppelleitungen.
Umgekehrt. Gsync funktioniert aber kein Vsync. Womit die FPS dann deine Bildwiederholrate des Monitors überschreiten und es zu Tearing kommt. Framelimiter sollen auch nicht funktionieren. Da müsste man dann das Powerlimit so einstellen, dass die Karte nicht über die max HZ des Monitors kommt.
Darum gehts nicht. Es geht darum, dass Du ein Laggy Spielgfühl hast obwohl das Bild flüssig aussieht. Sprich. Wenn Du mit DLSS3 120FPS hast spielt es sich wie mit 60FPS.
Also, ich werd es probieren. Habe nen quiet pro 10 750 Watt Netzteil. Aktuell hängt die 3090 mit dem speziellen bequiet-Kabel an einem Kabel in Buchse 12V2 mit 1 Stecker. Laut Anleitung kann die buchse 25 ampere bei 12 Volt. Sind 300 Watt. Auszug aus der Anleitung:
Da ich noch nen 8700K hab, wird das schon ausreichen. OC der 3090 mit CPU OC hatte Max 606 Watt gezogen. Ich werde mit 2 Kabeln je 1 x 12V2 und 1 x 12V3 in die Grafikkarte gehen. Da ich die 4090 nicht OCen wollt, wird es schon reichen, schön hässlich. :d die Kabel sind aber auch aufgeteilt.
Das heißt, am Ende sind 4 Kabel im Adapter. Und laut dem Handbuch, kommt das hin. Mit der Watt Zahl.
Moin zusammen!
Heute wird meine 4090 FE geliefert. Da ich mit so einem Monster zuvor noch nie hantiert habe, bin ich nun ziemlich verunsichert, wie ich die Karte an das Netzteil anschließen muss.
Ich habe ein Corsair RM750x. Ich werde die Karte zunächst mit 70% PL betreiben, da ich das Netzteil erst aufrüsten möchte, wenn ATX 3.0 so richtig am Markt angekommen ist - falls das überhaupt erforderlich sein wird.
Ist es richtig, dass ich das mitgelieferte Kabel der 4090 FE einfach direkt an das Netzteil anschließe und zwar an die eingerahmten Anschlüsse? Oder benötige ich noch Kabel von meinem Netzteil, die ich zunächst mit dem Kabel verbinden muss? Ich möchte nichts falsch machen. :)
PS: Ich habe hier schon ewig mitgelesen, mich aber heute endlich angemeldet. Also an dieser Stell noch ein "Hey! :)" von mir.
Meine kommt jetzt Sa. Obwohl ich um 15 Uhr bestellt hatte am Mittwoch. Das NT kommt heute. Wurde 18 Uhr bestellt. Gehäuse Dienstag. Wurde mit NT zusammen bestellt 😭 ohne Gehäuse kann ich nichts ein bauen. Hab ja nur ein Mini ITX.
Sieht bestimmt lustig aus. Fractal Torrent mit Mini ITX Board und 4090 😎
BeQuiet hat ausdrücklich gewarnt das alte 3090TI Kabel von BeQuiet zu nutzen. Ich würde also vorsichtig sein.
Gelbe Karte @PC-Neuling
Beim nächsten Ausfall fliegst du aus dem Thread.
Zügel deine Wortwahl, lies nach was zum Thema bereits aus der letzten Generation öffentlich ist. Wenn dir das nicht reicht... dein Problem.
Moin zusammen!
Habe ein SF750 von Corsair hab aber auf 850W bequiet gewechselt. werde da das neue Kabel bestellen. Sollte mit 75% PL und demnächst i7 13700k klar kommen.
Ich nehme niemals dieses Adapter Kabel. Ich nehme die beiliegenden zum Netzteil. Das Adapter Kabel der 3090 hat doch gar nicht die 4 zusatzpins. Sieht man auch an den Kabeln die auf dem Boden fotografiert sind.
Das ist das ominöse adapterkabel, das man NICHT für die 4090 nehmen darf.
Update! Karte ist in Zustellung. Ob ich die auspacke. KA wollte ja ne TUF. Und geöffnet gebe ich nicht gerne Karten zurück.
bzw. liegt der pc dann offen am Tisch bis das gehäuse kommt.
Diese Aussage ist nur teilweise richtig !
das be quiet! 12Pin Kabel (dual PCIe) kann man verwenden, das single PCIe bitte nicht.
Also das Kabel das gestern hier gezeigt wurde kann man ohne bedenken bestellen oder? Das 2 Stecker vom Netzteil auf den neuen geht?
