[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wieviel hattest Du nochmal für Deine 3090Ti Suprim bezahlt? Muss verdammt hart sein, jetzt die Benchmarks zu sehen…
Habe damals 2500€ bezahlt :d, aber nein hart ist es nicht. Ich spiele zu 95% WoW auf einem UWQHD+ Monitor und da liegt die Auslastung meist bei 50-60%. Wirklich brauchen tue ich die 4090 nicht und da es noch eine 4090Ti geben wird + 13900KS + neues Mobo + 7200DDR5, denke ich, dass ich erst Mal abwarten werde und die CPU+Board+RAM ggfs. upgraden werde. Die 4090 ist zwar schneller/effizienter aber die 3090Ti dadurch keine Schrott-Karte ;).
Edit: Aber wie ich mich kenne, schlage ich in den nächsten 1-2 Tagen zu ;)! Wie manche schon geschrieben haben, Geld sitzt locker :d!
Der Igor hat schonmal seine fe im 3d Drucker eingescannt für den einen oder andere Hersteller. Byksi hat wohl direkt nen Block lieferbar, ek glaube erst ab dem 18. nov . Bisher nur für die fe.
Ein TearDown Video gabs noch nicht oder?
bin leider auch noch über keins gestolpert.
Hier im Artikel von Igor ist aber wenigstens schon mal ein wie ich finde recht aufschlussreiches Bild (ca. in der Mitte auf dieser Seite):
@der8auer hatte es ja schon angeteasert.
Jedenfalls sieht man auf igors Bild im Bereich der Slotblende einen Schlitz.
Dort kann man die "Backplate" bzw. die Abdeckung (beschriftet mit RTX 4090) derselbigen von der eigentlich Backplate abdrücken.
Man sieht auf der eigentlichen Backplate 9 Magnete.
Ansonsten ist diese Abdeckung dann noch mit 2 Stiften im Bereich des hinteren Kühlers in 2 Gummitülen geklemmt (analog zu 3080/90 (ti)
Seit Kurzem ist auch was für Colorful dabei. Ansonsten nur für Zotac
Ein Kühler für die Strix oder die Suprim wäre schön, keine Lust ewig darauf zu warten.
Ich bekomme keine der Karte mit Luftkühler in mein Case.
Weiß man schon, wann da was kommen wird.
Cablemod bringt einen 90° adapter für 16 Pin, somit haben die Karten dann in mehreren Cases Platz 😍
Wow danke. Ist ja ne komplette Anleitung.
Hier sieht man bissle was.
NGL, ich bin heiß wie Frittenfett. Luftkühler gesucht, gefunden und vorbereitet; Gleitcreme äh WLP steht daneben.
So NBB scheint sich langsam warm zu machen:
Also das Problem bei der 4090 FE mit den Lüftern finde ich für ne 2k Grafikkarte nicht so lustig. Da gabs schon bei der 2080 Ti FE Probleme mit der ersten Revision. Echt traurig, dass da so gespart wird...
Krass, nur 80W bei FHD in CS/GO :oops:
Leerlauf ist jedoch nicht so geil. Da würde ich mir auch unter 10W wünschen
Gibt es schon Infos wann es die Blöcke von Alphacool oder co. geben wird ?
Kommt stark auf die Karte an. Von Bykski für Zotac Ende Oktober, EKWB für FE Anfang November, Alphacool für Ref in ca. 7 Tagen. Von Phanteks und Corsair hab ich noch nichts gesehen (Edith: Also Verfügbarkeit(en)). Watercool Ende November für die FE.
Eigentlich wollte ich schon ein fertiges Modell, aber davon scheint es ja nur eines zu geben und das will offensichtlich jeder hier. Da hat man als Person die morgen nicht rund um die Uhr nach Verfügbarkeiten schauen kann, wenig Chance.
Jetzt da EVGA vom Markt ist, würde ich nicht mehr gerne umbauen. Aber ich überlege ob ich nicht die FE nehme und einfach doch einen Block on Top. Wobei mit UV würde ich die Karte bestimmt auch in Regionen bekommen die unter Luft Spaß machen für mich.
Eigentlich wollte ich schon ein fertiges Modell, aber davon scheint es ja nur eines zu geben. Jetzt da EVGA vom Markt ist, würde ich nicht mehr gerne umbauen. Aber ich überlege ob ich nicht die FE nehme und einfach doch einen Block on Top. Wobei mit UV würde ich die Karte bestimmt auch in Regionen bekommen die unter Luft Spaß machen für mich.
Bestimmt easy möglich. Torrent, paar gute Lüfter und ab geht der Lurch.
Schnelle Zwischenbildberechnung ist schon toll. Insofern man keine Fehler entdeckt
Ab und an mach ich bissl was mit "Topaz Photo AI" oder "Topaz Video Enhance AI". Ist schon der Hammer, was die AI/KI kann (siehe Spoiler)
Links das Original in 720p - rechts in 4K berechnet
ukgtuk-png.744211
Das Hemd und die Krawatte :oops:
zuioz-png.744212
ukgtuk-png.744211
zuioz-png.744212
Wie kann ich mir das vorstellen? Cutscenes damit schöner machen?
Im Spiel oder bei Video-Aufwertung?
Bei Video-Aufwertung sieht das zu so aus. Aus vielleicht 15fps s/w machen die 60fps color. Sowas begeistert mich enorm...
Diese Szene ist 120 Jahre alt... :oops:
Ähnliche Themen
Antworten
7K
Aufrufe
590K
