[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Joa dann verdient CK an so einer AMP ca. 375 € , wenn die Zotac ca. 1975€ mit Mehrwegsteuer kostet.
Wenn ich mal denke , dass damals vor Ampere der kleine Händler um die Ecke garkeine Karte verkauft hat , weil der Gewinn zu gering war.
Ne die Amp Extreme kostet mehr, habe jetzt von der normalen AMP non Oc gesprochen. Und glaube mir Caseking macht kaum Gewinn mit den Karten
Laut Igor hatte zumindest die suprimeX der 3000er Serie mit die besten Komponenten.
Laut MSI haben die spezielle Komponenten gegen Spulenfiepen verbaut.
MSI verbaut nach eigenen Angaben hocheffiziente Carbonyl-Induktionen (HCI), die dank eines speziellen Gussverfahrens ein Spulenfiepen verhindern sollen.
Dadurch ist die Suprim X wieder in meine Auswahl gekommen. Wenn die Kühler wirklich überdimensioniert und entsprechend leiser sein werden fällt Spulenfiepen mehr ins Gewicht. Wäre nervig eine leise Karte zu haben, die dann fiept ohne Ende. Ich hoffe darauf, dass die anderen Karten auch nicht zu viel Fiepen haben, da ich den Kühler der Suprim X nicht so toll finde.
Tendieren auch immer mehr zu der x Liquid mal sehen...
Vorallem wenn sie das Spulenfiepen ganz verhindern wäre das echt ein Traum.
Da bin ich mal sehr gespannt.
Edit: Auf der Produkseite heißt es dann doch nicht verhindern sondern nur weniger Spulenfiepen ... na mal schauen.
Bei 3090 Suprim X hört man so gut wie kein Spulenfiepen.
Die x Liquid wird doch das selbe pcb haben wie x oder?
Diese neuen spulen sollen auch auf der msi gaming trio und x trio sein
Wahrscheinlich haben alle msi modelle das gleiche pcb. Das spart kosten und macht auch binning Möglich
Bin gespannt ob die wirklich so leise sind, ansonsten hatten Palit/Gainward immer schon deutlich leisere Spulen als alle anderen. Meine Strix ist seit umbau auf Wakü witzigerweise auch deutlich leiser geworden, mt UV sogar unhörbar. Hatte ich vorher auch noch nie. ^^
Die spulen sind bei mir der Grund weshalb ich dieses mal ne msi kaufe. Hatte schon nen wb für das ref pcb vorbestellt 😂. Dann wieder storniert.. endlich mal ne leise Gpu…. Das wäre ein Traum. Man steckt hunderte in Lüfter und wakü dass alles leise ist und dann fiept die Grafikkarte wie ein Weltmeister…immer wieder ärgerlich 🤦🏻‍♂️
Geht's etwas genauer?
Wenn die Garantie entfallen ist, besteht aber noch die Gewährleistung. Innerhalb eines halben Jahres müsste der Hersteller darlegen und beweisen, dass der Kunde die Dysfunktion verursacht hat. Nach einem halben Jahr dreht sich die Beweislast um. Der Kunde müsste beweisen, dass der Umbau nicht kausal für die Dysfunktion war.
Wird schwierig und teuer, weil noch Gutachter zu beauftragen wären.
Nur so nebenbei...
Die gesetzliche Gewährleistung wurde ab 01.01.2022 von 6 auf 12 Monate erhöht ;)
Verdammt - @***** war schneller :d
Nachricht gelöscht
Ich kann mich nicht entscheiden entweder FE -Msi- Asus -Gigabyte oder palit 🤧
Lg
Die geringe Verfügbarkeit könnte dir die Entscheidung abnehmen;)
So ist es. Der Händler oder Hersteller versucht im besten Fall dann nur ein Garantiefall abzuwickeln der aber völlig auf Kulanz basiert. Ein Anspruch besteht nicht. Es sei denn in den Garantiebestimmungen ist eben definiert, dass eine Kühlerdemontage von der Garantie abgedeckt wird. Außer bei EVGA hab ich sowas allerdings noch bei keinem anderen gesehen.
Ja, die erlauben auch ein markenfremdes BIOS (nur bei Dual-BIOS-Karten
Alle anderen Hersteller erlauben es nicht - selbst nicht bei einem "Okta-BIOS" :fresse:
Gewährleistung hat mit dem Hersteller nichts zu tun sondern nur mit dem Händler. Und wenn die Karte umgebaut wurde, dann kann eben meist nicht mehr zweifelsfrei festgestellt werden ob der Mangel schon ab Kauf da war oder ob er vielleicht doch Folge des Umbaus war. Daher wird es dann auch schwierig mit der Gewährleistung. Wer diesen Nachweis dann genau erbringen muss kann ich nicht sagen, denn wenn der Händler nachweist, daß man die Karte umgebaut hat, dann kann das möglicherweise bereits reichen um seiner gesetzlichen Nachweispflicht genüge zu tun, dann muss der Käufer wieder ran um zu beweisen das es doch nicht die Ursache war.
Ein Beispiel das mir einfällt war z.B. das Rooten von Smartophones. Wenn bei einem Gerooteten Smartphone innerhalb der Gewährleistung das Display durch einen Hardwaredefekt ausfällt, dann kann nicht automatisch die Gewährleistung verweigert werden, weil das Rooten relativ klar nichts mit den Hardwaredefekt zu tun hat. Aber bei einer Grafikkarte wird das schwieriger zu trennen sein.
Das eigenständige Umbauen einer Grafikkarte auf WaKü bleibt immer mit Risiken verbunden, was einer der Gründe ist warum ich nie eine Karte sofort auf Wasser umbaue, sondern warum ich diese immer erst einige Wochen bis Monate auf Luft betreibe.
Seit diesem Jahr gilt nicht mehr ein halbes Jahr, sondern ein ganzes Jahr bis die Beweislastumkehr in Kraft tritt.
Korrekt, ja.
Ich will hier niemandem auf die Füße treten, und auch sicher keine Rechtsberatung abgeben, aber den Unterschied zwischen Garantie und Gewährleistung scheinen einige zu verwechseln. Die Gewährleistung hat mit dem Hersteller nichts zu tun; sondern nur mit dem Händler. Gewährleistung heißt auch nur, dass die gekaufte Sache zum Übergabezeitpunkt (Gefahrenübergang) frei von Mängeln war. Ein Defekt zu einem späteren Zeitpunkt ist nicht automatisch ein Fall für die Gewährleistung. Garantie dagegen ist vom Hersteller, und da kann der Hersteller nach eigenem Ermessen Regeln und Bedingungen aufstellen. Miteinander zu tun haben die beiden Dinge aber nichts.
Sehr schön auf den Punkt gebracht, ich hätte es nicht besser schreiben können :hail:
Lg
Erst mal die Tests ansehen am 11.10 dann sollten sich die Favoriten heraus kristallisieren.
Bis auf ein Paar Bilder haben wir doch kaum Daten zu den Karten!
Am 11 können wir das besser eingrenzennund haben 24 std Zeit ummuns zu entscheiden wen wir schon am 12 zuschlagen wollen!
Gruss
Der Test für die customs kommt erst am 12.10 glaube ich.
Bessere als die Strix OC?
Eine Frage von gestern scheint hier untergegangen zu sein...
Die TUF hat das gleiche PCB, wie die Strix. Aber was genau ist auf dem PCB anders?
Und gibt es keine Möglichkeit eine KK bei CK zu speichern? :oops:
Meine auch...
Hast du es auch anders gemacht, als beschrieben? :fresse:
Ich hab auf die Spulen WLPads geklatscht. Der Kram hat die Spulen schön mollig eingepackt, sodass die kaum noch einen Mucks machten :haha:
Wäre das ein Indiz, welche Leistungsaufnahme bei einer Grafikkarte möglich wäre, wenn man sich die Netzteilanforderung anschaut?
Allerdings wäre das kein gutes Zeichen bei der Suprim - Minimum 850Watt, sieht dann eher nicht nach max. 600 Watt bei der GPU aus.
Das wäre alles kein Problem, wenn Jeder die Möglichkeit hätte, die Kiste in einen anderen Raum zu stellen. Dort kann sie herumpusten, herumfiepen und herumheizen, wie sie will :d
Also "Linus-Style"... Nur noch Moni, Tasta, Maus und ein Terminal für Power, Reset, USB etc. Leiser und Kühler gehts nicht mehr :-)
Auf der ersten Seite sind die bereits bekannten PowerLimits. Alle anderen wissen wir wohl erst ab Dienstag 👍
Ähnliche Themen
Antworten
7K
Aufrufe
588K
