[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Könnte mir vorstellen, dass überlange Karten wie die Strix letztlich besser zu bekommen sind, weil sie kaum einer ins Gehäuse bekommt.
Bei mir gehen auch nur Karten bis maximal ca. 340cm rein, was die Auswahl schonmal stark einschränkt. /:
Die kaufen sich einfach ein passendes case gleich mit..Das ist kein Hindernis für die, die 2,4k für ne gpu ausgeben 😅
By the way, was könnte ich für meine 3090 von EVGA (noch drei Jahre Garantie) noch verlangen?
3090Ti gibt es neu für 1000 denke mal gebraucht geht deine 3090 für 700euro
Sicher aber der Bastelsaufwand gerade bei einem Wakü System ist immens.
Naja ich versuch mein Glück mal am 12.10 eine MSI Suprime X würde noch passen von den Premium Katen aber die Srix ist erstmal raus ....
Jo bei mir auch .
Wer nicht warten kann, kann eine Wassergekühlte RTX 4090 direkt mit PC kaufen. "Alle Teile auf Lager" :)
  • Handgefertigter Gaming-PC mit Custom-Loop
  • im PHANTEKS Enthoo Big-Tower
  • Intel Core i9-13900K Prozessor
  • Intel Z790 Mainboard
  • wassergekühlte GeForce RTX 4090
  • 1 TB große NVMe-PCIe-4.0-SSD und 32 GB DDR5-RAM
Über diesen Link in den Warenkorb legen
Hier das Produkt: https://www.caseking.de/King-Mod-Sy...0K-GHz-RTX-4090-SIPC-555.html?tplview=desktop
Ich dachte du wolltest dir ne Frostbite kaufen ? Doch zur gesinung gekommen und umentschieden ?
Wenn ich die Frostbite bekommen sollte würde ich sie nehmen aber man muss flexibel bleiben und nach Alternativen schauen, die passen, da würde zb. auch noch die Suprime Liquid X dazu gehören.
Am besten wird sein, erstmal zu gucken was man wirklich am 12.10 bekommt ....
Geht irgendwie nicht /:
Die CPU z. B. ist erst ab 20.10. lieferbar bei ck
Was genau geht nicht? Man kann nur den PC in den Warenkorb legen für knapp 9000 Euro. Nicht die Karten :)
Sorry, wieder 4090 Offtopic. Aber durch die 4080 Ergebnisse, bekommen wir eine Ahnung von den 4090 Ergebnissen :)
3000mhz mit max 60 Grad und max 330W. Klingt doch gut. Bestimmt geht da was in Richtung 275W mit 3GHZ beim undervolting.
Das sieht für Luftkühlung wirklich fantastisch aus, die Resonanz wird enstsprechend postitiv und groß sein.
Ich hoffe, dass bei der nächsten GEN die Kühler nicht wieder zu knapp dimensioniert sind... Die GPU ist bei voller gaming Last auch undervoltet mit Abstand das lauteste Teil!
Muss aber unter Garantie länger warten, als bis nächste Woche Mittwoch, da der PC ja auch noch zusammen gebaut werden muss. ;)
  • Danke
Reaktionen: SH
Wer muss sich alles ein neues Case kaufen?
Checkt bei 12:12 :)
Was habt ihr alle für Schneckenhäuser? Passt in mein jetziges Silverstone sowie in mein neues Phanteks Enthoo Pro 2, in dem ist dann auch noch ordentlich Luft unter der Karte + Bodenlüfter (Empfehlung :d)
Ich habe dieses hier :)
Bei mir passt tatsächlich aufgrund der 360AIO in der Front nur die 4090 FE....bei 33 cm ist schluss......Corsair 4000d
  • Wow
Reaktionen: SH
Platz en masse aber es kommt eh nur ein Wasserblock rein (samt neuer Holzblende :d ) ....
Meine strix 80ti liegt auf den Front Lüfter auf. Die Stromkabel berühren bereits die Scheibe.
Glaube das nzxt h7 flow wäre im Fall meine Wahl. Dessen verital braket ist sehr gut. Aber dann ist Ende mit luft cpu Kühlern 🤣
Wenn man bock hat auf Netzteil oben und den kabaelsalat 😅
Bin es mittlerweile gewöhnt alles unten in den shroud zu ballern und Ruhe 😆
Ähnliche Themen
Antworten
7K
Aufrufe
430K
