[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ja , das hat aber überhaupt nichts mit meiner mutmaßung zu tun. Das was Igor hier zeigt ist eindeutig und verständlich. Ich mutmaße einfach nur 3Pin 450 Watt 4 Pin 600 Watt. Ob meine Mutmaßung richtig oder falsch ist wird sich am 12.10 Zeigen. Das man mit 3 Pins kein 600Watt ziehen kann ist mir auch klar.
Hm, so klar finde ich das nicht. Betrifft das nur die FE specs mit dem beigelegten Adapter?
Corsair z.B. bietet ja dieses Kabel an: https://www.corsair.com/de/de/Kateg...0-12VHPWR-Type-4-PSU-Power-Cable/p/CP-8920284
2x 8-Pin auf den PCIe 5.0 12VHPWR stecker, bis zu 600 Watt. Das selbst von Cablemod (https://eustore.cablemod.com/produc...-for-corsair/?attribute_pa_color=black-silver) hat 3x 8-Pin, aber keine Angabe zur maximalen Last. Was ist denn nun die echte Spec :confused:
hier wer die ultimative unboxing experience sucht
Corsair z.B. bietet ja dieses Kabel an: https://www.corsair.com/de/de/Kategorien/Produkte/Zubehör-|-Teile/PC-Komponenten/Netzteile/600W-PCIe-5-0-12VHPWR-Type-4-PSU-Power-Cable/p/CP-8920284
Nvidia muss bei dem Adapter einfach auf Nummer gehen und mit allen möglichen Netzteilen komptabel sein, darum 4x 8-Pin. Die PCIe Spezifikation sieht halt nur 150W pro Kabel vor.
Wenn das Netzteil jedoch hochwertige Terminals hat, kann man da aber auch 300W durchknallen. Deswegen reicht beim Corsair 2x 8-Pin.
Der Stecker muss einfach nur die Sense Pins für 600W belegen, mehr "Kommunikation" findet da nicht statt. Der Karte ist es daher im Endeffekt egal, wie der Strom dorthin gelangt. Hauptsache die Sense Pins sind belegt.
Die Aorus ist so ein übler Plastikbomber... ich hatte Mal beim 2080 Ti Release eine ausprobiert aber direkt zurück geschickt weil die Temperaturen brutal hoch waren und die Motoren der Lüfter Formel 1 Geräusche plus Lautstärke hatte. Seitdem bin ich von Aorus als Marke geheilt...
Ja, könnte viel Marketing-Bla-Blubb sein, wie bei Gamers Nexus angeprangert wurde (wie auf dem Smartphone-Markt)
Wie der die Folie von der Strix zieht 🫠😘😛
Jaaa, ASMR für Männer 😍 :ROFLMAO:
Das find ich ein gutes Vid vom der 8auer
am spannensten ist das Video imho ab 09:20:
Da hat er sich damit befasst, wohin die 4 Leitungen vom Adapter führen:
2 sollten auf Masse führen (2x Sense -> 600W) und 2 führen ins Leere. :d
Ich bin mal gespannt wie das dieses mal ablaufen wird nächste Woche.
Gefühlt sind es schon einige Käufer die zuschlagen "wollen" ... , oder?
Gibts eigentlich ne Umfrage für welche Karte sich die meisten hier entscheiden werden?
Die Chips sind alle gleich, egal ob FE für 1950€ oder Strix für +500€.
Ich hoffe es kommt noch ne Karte (außer die Inno) mit Fullcoverblock, dann werde ich wohl auch schwach um endlich ordentlich in 4k zocken zu können.
Alternativ hoffe ich auf Kingmod :)
Ne sind se nicht. Die eine kannst 150mhz oder höher takten die aber nur 25mhz ( Beispiel)
Und das macht in der Praxis dann wie viel FPS mehr aus das dann als Beispiel 500 Euro Mehrkosten rechtfertigt?
Würde immer die günstigste Karte nehmen + WaKü Block und ab die Post, selbst das ist dann immer noch günstiger als eine Luxus LuKü Karte und taktet dank niedriger Temperaturen höher und verbraucht weniger Strom.
Nur schade das die FE nur boost takt von 2520 hat. Hatte noch nie eine FE wie sieht so die Chip Qualität aus? Ist da viel mit OC drin?
Dieser "nur" Boost-Takt ist meines Wissens erst mal nur das was der Hersteller bereit ist zu garantieren. nVidia setzt hier scheinbar niedriger an. Das heißt aber nicht das Du beim eigenen OC auf einer FE nicht genau so hoch oder sogar höher kommen kannst wie bei einer Strix. Ich habe in der Vergangenheit schon ne Menge "OC ab Werk" Karten gesehen, die jenseits des eigentlich "garantierten" Boosttakts früher ausgestiegen sind als billigere Karten. Und das Asus oder andere AiBs es sich hier wirklich leisten können Chips zu binnen bei den Preisstrukturen die da scheinbar hinten dran stehen wage ich zu bezweifeln. Und nVidia wird sicher auch nicht den Abfall auf ihre eigenen Karten schrauben.
Aus meiner Sicht ist diese Frage daher hauptsächlich dann relevant, wenn man nicht vor hat, selber noch OC zu betreiben und daher möglichst viel ab Werk haben will. Wichtiger für die OC Frage ist daher aus meiner Sicht eher Energieversorgung und Kühlung der jeweiligen Karte. nVidia erlaubt auch auf ihren FEs bis zu 600W wenn ich das richtig gesehen habe, also bleibt für mich hauptsächlich die Frage, wie gut ist die Kühlung und die Versorgung der FE.
Ist schon irgendwas bekannt zum PL von Custom Modellen? Auf der Verpackung steht ja irgendwie nix.
Bisher nur zwei Karten glaub ich FE 600W und die Gainward 450/450 .
Hat wer nen Unboxing gesehen wo die Asus Strix und Gigabyte Aours Master verglichen werden?
Ist denn Galaxus serös?
Hab auch mal eine bestellt aber das Lieferdatum hat sich nicht geändert und ist bei Mitte November geblieben.
Ich mein das wäre ein Monat nach Release, ich weiß nicht recht?? :unsure:
Seriös sind die schon, ja.
Ähnliche Themen
Antworten
7K
Aufrufe
587K
