[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist halt für Overclocker, das das letzte Grad raus holen wollen.
Das is auch meine Vermutung .. aber nich für Otto Normal Overclocker die die Karten mit so 450 Watt fahren wollen sondern dann wohl für die verrückte 600 Watt Fraktion.
Klar wer das Geld über hat kann da natürlich zugreifen ich wollte nur sagen das der Gegenwert da eher marginal sein wird da bei der 4090 eben hinten kein VRAM verbaut ist
und somit ne normale Passive Backplate oder eben hinten "Nackt" völig ausreichend sein sollte
Weiss man eigentlich ob die Karten dann auch laufen wenn man sie Per Adapter ( die meisten Karten haben ja 4 x 8 Pin Adapter dabei liegen ) angeschlossen werden
aber nur 3 x 8 Pin am Netzteil hat und somit 1 x 8 Pin frei bleibt ? Laufen die karten dann oder laufen die erst wenn dann auch 4 x 8 Pin belegt ist ?
Weil wenn ich bei meiner 3080 Strix nur 2 x 8 Pin anschliese ( karte hat 3 x 8 Pin ) geht sie auch nich an .. kann also sein das wenn bei den Karten nur ein 4 x 8 Pin Adapter dabei is
man auch 4 x 8 Pin zwingend brauch und 3 x 8 pin dann nicht ausreichend ist und die Karte dann mit 3 x 8 Pin garnicht startet.
Kann aber auch sein das bei allen Karten dann 2 Adapter bei liegen .. 1 mal 3 x 8 Pin und 1 mal 4 x 8 Pin ... das währe da noch die Beste Lösung.
Aber bisher machte es auf mich den Anschein das fast bei jeder Karte nur 1 mal 4 x 8 Pin Adapter dabei liegt
An die die sich nen alphacool kaufen wollen. Tipp von mir kauft euch direkt anständige Pads für die backplate die 3kw Dinger die dabei liegen ist der reinste scheiß. Gemerkt an der 3080TI. Gut 20 Grad Kühler der Kram mit anständige Pads.
Schreib doch mal alphacool deswegen an und berichte von deinen Ergebnissen. Vielleicht ändern die dann was 👍
Hatte ich, und die wollten mir erst Pads schicken. Da hatte ich mir aber schon andere Pads gekauft. Als wieder gutmachen habe ich dann einen 10% Key bekommen für den nächsten einkauf
  • Danke
Reaktionen: SH
@Brainscan1979 Da muss aber noch was anderes nicht gepasst haben. 20 Grad kühler durch Pad Wechsel auf der Rückseite einer 3080Ti die hinten keine Chips hat? :unsure:
Es kann auch sein das was beim Einbau nicht 100pro richtig war. Es war danach halt 20 Grad Kühler und ich hab mich gefreut. Es gab aber noch jemand im thread ( mein / im alphacool thread) der das gleiche Problem hatte, und nach pas Wechsel war alles grün.
Wer kauf eigentlich von euch am 12.10.22 ne 4090? Und Welche? FE, Strix, Suprim, Master usw?
Inno3d ichill Frostbite :)
Ich hab mich aktuell auf die FE oder Suprim X eingeschossen 😄
Kauft euch alle mal die Krücken Inno. Sorry aber meckert nachher nicht. Wir haben euch gewarnt 😄😄😄
Was für Probleme?
Erstmal Funktionierte der vertikale Einbau nicht. Was ich noch vielleicht nachvollziehen kann. DANN kam der Umbau auf WB. 6 Monate lang lief es dann mit PT bei 370 W, (erhöhen war nicht) . Nach 6 Monate HDMI defekt. Austausch nicht möglich weil keine garantie wegen Umbau. Dann mit Support geredet, es gibt in Europa keine Möglichkeit die reparieren zu lassen( auf meine Kosten) , weil Inno kein Europa Support hat. Danach als defekt verkauft. Übertakten war auch nicht viel drin. Also aus meiner Sicht sind das die größten Krüppel Chips die nvidia verkaufen kann.
Naja mal sehen was da überhaupt verfügbar ist ...
Zeit für einen Verfügbarkeitsfred. (y)
Garantie sollte bei der frostbite zumindest kein Problem sein, WB ist ja schon drauf.
Das ist richtig. Aber rechnet doch mal mit. Aktuell wird die mit 2299€ angegeben. Und es ist Nur Ne Referenz Karte die mit Sicherheit keine Erhöhung des PT zulässt. Bedeutet ihr Zahlt mal schlappe 350€ für den Block der bei AC nur 159€ kostet. Holt euch ne MSI Gaming und den WB und ihr habt mit Sicherheit ne bessere Karte und ist 200€ günstiger.
Geht halt auch darum ab day 1 auf Wasser laufen zu lassen. MSI Gaming dürfte nen eigenen Block verlangen, den es gar nicht gibt. Auf Luft hab ich auch temporär kein Bock und ich lass keine 2k Euro Karte 1-2 Monate im Schrank bis der WB kommt ;)
Für mich wird die potentielle Auswahl schon dadurch eingeschränkt, daß die Karte keinesfalls länger als 34cm sein darf für mein Gehäuse weil der AGB nirgends anders hinpasst.
Und Day 1 Wakü kommt für mich nicht in die Frage, die sollte wenn später in meine Custom WaKü eingebunden werden und zuerst will ich meine Karten immer auf Luft auf Herz und Nieren testen.
Aktuell steht daher wenn die FE ganz vorne auf meiner Liste. Mal sehen.
Welches Powerlimit die FE und Referenz Karten haben werden wir ja hoffentlich am Mittwoch erfahren.
Nach der unglücklich Nummer mit dem Umbau, Garantieverlust und Defekt deiner 3080 kannst du doch vielleicht nachvollziehen das Leute hier eine 2k€ GPU nicht ohne Garantie betreiben wollen.
1. Zotac AMP Extreme Airo
2. Aorus Master
3. Suprim X
In der Reihenfolge und je nach Verfügbarkeit. Werde auch versuchen alle drei auf einmal zu bestellen und dann eben bei Bedarf Retour / Storno.
@Ekamin Habe ich jetzt schon in mehreren Foren gelesen. Eine Woche vor Launch scheint mir das auch plausibel. Auch die Custom Karten sind ja jetzt im Umlauf.
Ach ist das garnicht Fest das am 5 10 die NDA fällt? :(
Ich vermute, dass die Verfügbarkeit nach 1-2 Wochen erstaunlich gut sein wird.
Nachfrage nach Hardware ist deutlich geringer als vor 2 Jahren. Die Ryzen 7000 CPUs sind auch überall lieferbar.
Die Preise werden vermutlich auch nach und nach runtergehen.
@Brainscan1979
Woher entnimmst du denn diese Info?
Ähnliche Themen
Antworten
7K
Aufrufe
586K
