[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
An die die sich nen alphacool kaufen wollen. Tipp von mir kauft euch direkt anständige Pads für die backplate die 3kw Dinger die dabei liegen ist der reinste scheiß. Gemerkt an der 3080TI. Gut 20 Grad Kühler der Kram mit anständige Pads.
Die Karte die mit Wakü am wenigstens fiept gewinnt für mich :)
Heute erst vergessen UV anzumachen da neu formatiert und wurde durch ein lautes Brummen direkt geweckt.
Dachte die Wakühersteller wollten sich damit auch mal auseinandersetzen :/
Du meinst wohl 3W/mk, wäre mir neu, dass Wärmeleitpads 3kW Leistungsaufnahme haben 😅
Wenn man sich die Produktbeschreibung vom neuen AC 4090 Block durchgelesen hätte, dann hätte man sehen können, dass beim 4090er Block 16W/mk 7W/mk (3W/mk für die Rückseite) Pads beiliegen.
Für den Preis echt top 👍
Wenn man sich die Produktbeschreibung vom neuen AC 4090 Block durchgelesen hätte, dann hätte man sehen können, dass beim 4090er Block 16W/mk Pads beiliegen.
Also wenn du schon Klugscheißen willst.
Das steht in der Beschreibung.
Also wenn du schon Klugscheißer willst.
Wer Wärmeleitpaste von Wärmeleitpads unterscheiden kann ist klar im Vorteil :rolleyes:
Aber immerhin legen Sie 7W/mk Pads für die Vorderseite bei, für die Backplate sind 3W/mk mehr als ausreichend.
Bei dem 300+€ EKWB Special Edition für die 3090 FE werden nur 3W/mk Pads mitgeliefert, da ist das für nen 160€ Block ne echte Ansage.
Muss ich dir widersprechen. Die PADS die standardmäßig beim 3080TI für die backplate dabei waren waren nicht ausreichend. Ob es ein Produktions Fehler war oder nicht kann ich nicht nachvollziehen. Aber als ich die dann mit 7w getauscht hatte waren die Temps hervorragend. Ich werde auf jedenfall egal welcher WB es wird, direkt die Pads für die Backplate direkt ersetzen. Es sei denn es kommt direkt nen Block mit Activer Backplate auf dem Markt 😄
PS muss auch sagen das der alphacool wb sowohl für die 3090 als auch für die 3080 und auch die 3080TI hervorragend ist.
Leider noch nicht/:
Kann auch stark vom Wasserblock abhängen. Beim 3090 FE Special Edition vom EKWB wird die Backplate mit Wärmeleitpaste mit dem Block auf der Vorderseite verbunden. In Kombination mit 2x 280mm Radiatoren reichen da 3W/mk Pads völlig aus um die GDDR6X Chips im Betrieb unter 80°C zu halten.
Kann deshalb ehrlicherweise nicht so ganz nachvollziehen wieso hier so viele nach ner aktiven Backplate verlangen, vor allem da Karten außer der 3090 nicht mal eine doppelseitige RAM Bestückung aufweisen.
Weil es cool aussieht vielleicht? Hab Aktuell keine drauf, weil die Active BP erst Viel später kamen und ich jetzt nicht noch mal umbauen wollte vor der 4090er.
Ich wär aber auch erst mal ohne zufrieden.
Es gibt ja ein Manual zu dem Block, da sieht man das Layout zumindest von Referenz-PCB und wo auf Vorder- und Rückseite die Pads hinkommen. Dürfte bei anderen Karte aber grundsätzlich ganz ähnlich sein: https://www.alphacool.com/download/...TX_4090_with_Backplate_(Reference)_Manual.pdf
Ich las auch irgendwo das Micron an den DDR6X chips etwas verändert hat und diese ne ganze ecke kühler laufen als noch vor zwei Jahren. Ohne heiße chips auf der Rückseite dürfte das wohl auch ohne aktive Backplate ganz gut in den Griff zu bekommen sein.
EKWB hat jetzt auch die aktive Backplate nachgeschoben
Ja den Preis haben sie auch etwas nachgeschoben : ( knapp 400 Euro für Front + Back )
Bringt das dann überhaupt ein paar Grad ? War ja damals eher für die 3090 / 3090 Ti gedacht die hinten auch noch VRAM hat das is bei der 4090 aber nich der Fall.
Meine 3080 Strix is hinten sogar Nackig da is nix drann und da komme ich mit bis zu 450 Watt absolut gut klar. ( mehr Watt kann die 3080 Strix ja nich )
Eine aktive backplate unterstützt das Kühlsystem immer positiv.
Hatte die 3090 Ti nicht auch schon kein VRam mehr hinten ?
Mag sein .. die Frage is halt ob die Karte dadurch 1 Grad kühler wird oder zb 10 Grad Kühler ... bei 1 Grad wäre mir das eindeutig zuviel Money sowie aufwand.
Bei der 3090 machte es ja noch Sinn weil die hinten auch VRAM hatte aber die 4090 hat das nun nicht mehr
Möglich ... hatte ich dann nich mehr weiterverfolgt hab nun nur gemutmasst aber die 3090 hatte das zumindest und deswegen gabs ja dann auch die Aktive Backplate die dann nachgeschoben wurde
sowas war ja vorher nie groß ein Thema soweit mir bekannt ( bis auf so kleine Experimente )
@Ronchan411 Ja, eigentlich nicht nötig. Aber ich glaube viele mögen die Optik der Rückseite wenn die Karte konventionell eingebaut ist. Bisschen gaga aber ihnen sei der Spaß gegönnt. FE+Doppelblock ist immer noch günstiger als Strix.
Meine 3080 Strix is hinten sogar Nackig da is nix drann.
Bleibt imo im Rahmen. Bei Watercool kostet der Ampere Kühler mit wassergekühlter Backplate 350€, bei der RTX 4090 dürfte das nicht günstiger werden.
Einzig Bykski dürfte das wieder deutlich unterbieten, Ampere liegt hier bei 230€ für die Founders Edition, Referenz- und mehrere Custom-PCBs:
Da kann sein. Ich gehöre zur Riser Kabel Fraktion, daher interessiert die Rückseite nicht ;). Und für 1-2 grad wäre es mir das Geld nicht wert.
Joa mag ja sein das es bei Bünksi bingsi günstiger is ... bleibt halt weiterhin die Frage nach dem Sinn einer Aktiven Backplate wenn hinten kein VRAM verbaut ist der gekühlt werden sollte.
Weil für -1 Grad würde ich keine 200 Euro ausgeben sondern vielleicht 1 Euro. .... hätte die 4090 hinten auch VRAM wär das ja alles kein Thema aber da sie hinten nix hat Hinterfrage ich da halt
die Sinnhaftigkeit einer Aktiven Backplate.
Es mag aber sein das es für Leute die die Karten mit 600 Watt betreiben größere Vorteile hat ... aber mit 450 Watt meiner 3080 Strix komm ich mit dem EK Block Vorne sowie hinten Nackig absolut klar.
Die 3090Ti hat auch keinen VRAM auf der Rückseite, weshalb die Karte um einiges kühler läuft bzw. man sie leichter kühlen kann. Das ist ein großer Mehrwert, welchen auch die 40er Karten haben werden!
@Ronchan411 Ich bin auch Team Riser Kabel ;)
Aber John Doe mit seinem überhitzen O11 Brutkasten kann neben Zen4 dann auch seine 4090 von beiden Seiten abkochen.
Genau mein Reden ... daher hinterfrage ich eben den Sinn einer Aktiven Backplate für die 4090 ... das wird da nich viel bringen weil hinten kein VRAM verbaut is bei der 4090
da sollte also entweder die alte Passive Backplate oder sogar hinten "nackt" wieder völlig ausreichen .. mein 3080 Strix mit EK Blockl läuft hinten auch Nackt und da hab ich 0 Probs mit 450 Watt
Ist halt für Overclocker, das das letzte Grad raus holen wollen.
Ähnliche Themen
Antworten
7K
Aufrufe
428K
