[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Und warum triggert es dich, was Andere mit ihren GPUs an Strom verbraten?
Andere düsen um die Welt. Ist mir völlig wurscht...
noch verbrät doch gar keiner etwas.. ich würde sogar sagen, dass ich mit meiner graka atm noch die speerspitze der verbräuche bilde. falls ich sie mit ausgefahrenen 480W PL zum spielen missbrauchen würde.
tobi
wird wohl Fake sein aber ich teile es mal.
alle videos ohne overlay sind für mich fake :d
und selbst mit isses nicht 100% legit ^^
Falls das Video echt ist, wäre das ein akzeptabler Sprung :)
Dieser Benchmark wurde mit einer Thunderburne Special Limited Edition gemacht :fresse:
@SH das schönste was jemand bisher für mich hier im Forum je gemacht hat :wink:
Ist Fake, vor drei Tagen hatten die Tester noch nicht bzw gerade erst die Treiber gekriegt, afaik Freitag stand bei videocardz irgendwo
So das Thermaltake 1650W kam heute an und es geht am Dienstag direkt wieder zurück.
Es scheint ab Werk defekt zu sein.
Habe es an 2 Systemen getestet x570 und x670, mehr Lebenszeichen als das der Lüfter sofort auf Maximale Drehzahl
springt, kann ich dem Teil nicht entlocken. Beide MSI Bords ließen sich damit jedenfalls nicht Booten.
Naja meine Vorahnung bezüglich des Fabrikats ..................
Gut das ich während des Release Urlaub habe, evtl komme ich ja an eine Karte :).
Oh wunder
Wird schon klappen :)
Ja die Videos sind alle Fake. 😃👍
Moin moin,
würdet Ihr z.B. die 4090 FE an einem Be quiet DPP 11 850 Watt dranhängen oder würdet Ihr Euch ein stärkeres holen, falls ich doch schwach werde...noch würde ich das Netzteil nicht austauschen wollen. Sonst hängt noch ein 12700k drin aber nicht übertaktet. Sollte doch eigentlich passen. Beste Grüße und viel Glück beim bestellen.
Moin moin,
Ich würde das in jedem Fall ausprobieren und denke das reicht auch außer du gehst voll ins OC bis 660W.
Moin moin,
Das passt ohne OC 👍
Perfekt und Danke, ich werds auf jeden Fall probieren. Mir reichts mit max 450 Watt. Brauchs (was heißt brauchen😂🙈)für Simracing Triplescreen 7680x1440 und die jetzige 3090 "erwärmt" den Zockerraum schon brutal. Außerdem bin ich echt am überlegen ob ich überhaupt zuschlagen soll...es ist soviel Luft zum Vollausbau bei 4090/4080 ob und in welcher Form der da kommen möge oder mit X Zwischenmodellen...bin gespannt ob man diesmal mit abwarten besser oder nicht besser dran ist...
Mein 850W hat mit der 3090 @480W überhaupt keinen Stress. Wenn man bei der 4090 nicht am Powerlimit dreht, sollte das eigentlich kein Thema sein.
@Kabel Situation: Das Corsair Kabel ist in DE immer noch nicht bestellbar. Geht mir langsam ein bisschen auf den Sack, das Teil müsste ja auch noch den Weg aus Taiwan zurücklegen. Überlege gerade, jetzt doch dieses hier zu nehmen. Hier hatte doch jemand Erfahrung mit dem Shop... ist das "Ultra-Soft Silicone Wire" oder das "Premium Silver Wire" besser? Alles gleich teuer :hmm:
Der fiktive Vollausbau hat 2048 oder 12,5% mehr Shader. Die Leistung skaliert aber nicht 1:1. Bei gleichem Takt würde ich so mit ca. 10% mehr Raster Performance rechnen.
Was denkt ihr über 525 W wird es wohl nur mit den Karten geben die mindestens den 4*8Pin mit liefern oder ?
Ich glaub einfach nicht das die FE mehr wie 525W zulassen wird mit dem Serien Bios.
Ehr sogar im Bereich 480-516W gedeckelt.Auch ist 4*8Pin nicht direkt ein Indiez für 660W sondern kann auch gerade so die 525W überschreiten mit z.b 540 oder ähnlichem .
Mit um an die 600W kann ich mir vielleicht noch die Strixx vorstellen die Master vielleicht noch mit 575W rum .
Ich bin gespannt wer das höchste PT liefert!
Die schöne Frostbite Tip ich mal so auf Max 516 W was angesichts des Wasserkühlers zu wenig ist .
Auch im Hinblick das man mit dem OC eine 4090Ti obsolet machen könnte und ich nicht glaube das jeder Kühler über 525W vernünftig abführen kann wen die auch konstant anliegen!
Na ja. Was heißt besser? Gibt gesleevt in verschiedenen Farben, schwarzes Plastik und durchsichtiges. Hab da Mittwoch bestellt (erste Mal) und Tracking sagt das noch nicht übergeben wurde / noch hergestellt wird. Ich hoffe auf raschen Versand kommende Woche. Mit Luftpost (kommt aus Hongkong) könnte sich das noch ausgehen. Übergangsweise mit Adapter der Karte. Wenn man denn eine erwischt (und Tests "ja" sagen)
Sleeved
Farben
Schwarz
Transparent
Ja kA, die Optionen klingen so als ob sich das auch in der Qualität unterscheidet. Aber wenn das nur optisch ist… dann gibt es schlicht schwarz.
Die Preise der Strix OC - puh. Und das ist „nur“ UVP nehme ich an 😳
Nur copy paste und schlechte Recherche von Computerbase, da schon fast alle deutschen Seiten die Preise anzeigen. :)
NBB hat schon fast 1 Woche den Preis angezeigt.
Etwas Lekütre für Sonntagmorgen. In der direkten Aufstellung sieht auch die 4080 12G gegenüber der 3080 12 GB gut aus. TFLOPS bzw. RT TFLOPS ca. +55% bei gleicher UVP.
Wegen dem Powerlimit würde ich mir keine Sorgen machen. Die werden wohl alle die 660W bekommen. Mit Alphacool habe ich gesprochen, den Wasserblock haben sie bis 800W getestet. Galax 4090 Ti Hall of Fame incoming? o_O
  • nvidia-ada-gpu-architecture.pdf
Ich weiß nicht 660W wird nur kommuniziert werden weil das der Stecker mit 600W kann und der PCIE 75W liefern kann.
Ich bleib dabei 600W wenn nur für die Absoluten Top Karten!
Das ganze andere Zeug wird meistens bei unter 525W Max PT liegen.
Sonst würde so eine Strixx oder Master und sonstige keinen Sinn machen.
Die 800W hat Alphacool wie getestet !
Da gibt es 3 Möglichkeiten zu !
Über eine Heizplatte über eine gemodete 3090/3090Ti oder über eine 4090 und die haben sie garantiert nicht gehabt wen die Presse jetzt erst welche bekommen hat!
Ähnliche Themen
Antworten
7K
Aufrufe
431K
