Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
AMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Chipset
X570
Memory
3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
Graphic
Integrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support
3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage
3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LAN
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Bluetooth
Bluetooth® 5.0
Audio
SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports
3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
Accessories
User's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS
256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic
1 x HDMI 2.0
1 x DisplayPort
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
Storage
Supports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN
1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFi
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth
Bluetooth® v5.2
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB Ports
AMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O Ports
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
Accessories
Cables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
BIOS
Form Factor
ATX Form Factor
Note
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
Chipset
X570
Memory
Graphic
Multi-GPU Support
Expansion Slots
AMD X570 chipset
2 x PCIe 4.0 x1
Storage
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
LAN
Anti-surge LANGuard
Audio
Audio Feature :
- Sonic Radar III
USB Ports
3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
Special Features
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
Accessories
User's manual
1 x Supporting DVD
BIOS
Form Factor
ATX Form Factor
Note
Chipset
X570
Memory
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Graphic
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
Expansion Slots
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
Storage
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
Supports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Bluetooth
Bluetooth® 5.0
Audio
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
USB Ports
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
Special Features
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
1 x DisplayPort
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports
1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
Accessories
User's manual
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
BIOS
Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note
*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
Sound setzt aus oder knistert
Immer wieder USB Disconnects
Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
USB Disconnects
Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
USB Flashback funktioniert nicht
Bitte folgende Punkte ausprobieren:
- Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
- Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
- Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
BIOS/UEFI Downgrade
Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
Ist der Chipsatz Lüfter regelbar?
Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
Chipsatz Temperatur zu hoch?
Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
Rechner bootet nicht, wenn eine Soundkarte verbaut ist
Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
@Straeter. Habe den Strix-F und auch umgebaut. Habe die Original Kühler wiederverwendet. Hier auf der Seite 63 ist mein umbau zu sehen. Die SSD geht bei mir nicht über 40°C .
Was für eine Temperatur hast du den bei der SSD wenn dein Wasserkühler drauf ist, ohne den Original kühler wollte gerne mein Wasserkühler drauf lassen.
Ich hoffe ihr könnt mir weiterhelfen, so langsam verliere ich die Nerven. :-( ich hab mir diverse YT Clips angesehen und war der Meinung ich kriege es hin einen neuen PC mit einzelnen Komponenten zusammenzubauen. Gesagt getan, Folgendes habe ich gekauft:
Alles ganz in Ruhe zusammengebaut , jede Verkabelung ganz in Ruhe kontrolliert . PC angeschaltet, Windows installiert, läuft.
nach 2 Stunden Pause , pc angeschaltet, alle Lüfter drehen, Aura LEDs leuchten, Monitor bleibt dunkel. Board zeigt mir Fehler C5 und gelbe LED dram an. Ich komme nicht mal ins Bios.
gestern dann einen Tag lang Fehlersuche: Verkabelung nochmal kontrolliert, ich finde keinen Fehler. Die Rams befinden sich in Bank 2 und 4 .
wenn ich einen Riegel rausnehme, startet der PC ganz normal. Daraufhin habe ich mit einem Riegel BIOS Auf aktuellen Stand geladen und installiert . 2ter Riegel wieder eingebaut und cmos reset gemacht. Fazit: Fehler C5 , gelbe LED leuchtet. Hab den Tipp gelesen , dass evtl die Wasserkühlung zu fest aufm Prozessor sitzt. Diese dezent gelockert, hat jedoch auch nicht geholfen . Im Bios steht alles auf Default. Die Rams werden allerdings nur mit 2133 anstatt 3200 betrieben. Hab versucht manuell auf 3200 zu stellen. Funktioniert auch nicht . Ich muss dazu sagen, bei Einstellungen im Bios bin ich mit meinem Wissen am Ende, davon hab ich keinen Plan. Es steht jedenfalls alles auf default und es geht mit 2 Riegeln nichts . Ich habe die Rams auch schon gewechselt , den 2er in den 4er gesetzt. Gleiches Spiel, Fehler C5. jetzt lese ich hier von Timings usw und bin da ehrlich gesagt überfordert. Könnt ihr mir Tipps geben, was ich noch machen kann? Hat von euch jemand meine Komponenten so am laufen? Wäre für jede Hilfe dankbar.
Wenn der Rechner Saft hat drehen sich alle Lüfter, dass Display der CPU-Kühlung läuft, nur die Rgb Beleuchtung des Arbeitsspeicher bleibt aus. Dafür brennt die gelbe Leuchte des Mainboards (RAM Probleme).
Anders als du bekomme ich überhaupt kein Bild - auch wenn der Ram nicht eingesteckt ist.
Da ich irgendwann genau so ratlos war wie du, habe ich das gleiche das Board und den Arbeitsspeicher noch ein Mal bestellt, um die Fehlerquelle zu ermitteln.
Das Resultat war genau das gleiche wie mit den alten Komponenten. Denke inzwischen das Board und Ram inkompatibel zueinander sind.
Habe gesehen das du auch die Vengeance RGB Pro verbaut hast. Sind es die CMW32GX4M2Z3200C16? Die sind ja anders als die 3600C18 auf der QVL Liste aufgeführt.
Ich habe mich jetzt dazu entschlossen die G.Skill Trident Z Neo DDR4-3600 DIMM CL16-19-19-39 Dual Kit zu verbauen. Die sind auch auf der QVL aufgelistet- wenn auch nur geprüft für die Ryzen 3000er Generation. Für die neue Ryzen Generation gibt es leider noch keine Liste.
Der Ram kommt wahrscheinlich Mittwoch hier an. Hoffe das löst das Problem, ansonsten geht der ganze Kram zurück und ich probiere es mit einem anderem Board.
Lüfterlautstärke empfand ich nicht als störend. Ist halt aber auch sehr Subjektiv. Hab es auf Wasser umgestellt da mir die Temperatur einfach zu hoch war. Nicht mal WLP hat da richtig besserung gebracht. Und mir kommt es so vor das sich die Wärme von Chipsatz auf die SSD ubertragen hat.
@Lel hallo und danke für deine Antwort. Ich habe beide Riegel komplett durchgetauscht und einzeln eingesetzt. Ich kann das Problem nicht auf einen Riegel eingrenzen. Mittlerweile habe ich bei Asus nach dieser QVL Liste gesucht und da sind meine Riegel gar nicht gelistet. Ich hatte mich ehrlich gesagt auf den Konfigurator von Alternate verlassen. Dieser zeigte keine Probleme an.
Ich Krieg morgen oder übermorgen zwei Rams von einem Kumpel geliehen, mal schauen wie der Pc sich damit verhält. Heute hatte ich mit dem Flugsimulator einen Windows stop mit Neustart. Ursache die angezeigt wurde Memory Management error. passt scheinbar ins Gesamtbild.
Ich würde mal den Alternate Support anschreiben und Mutmassen dass der Ram nicht voll Kompatibel sei, dieser sei dir vom Konfigurator vorgeschlagen worden. Denke die werden dann eher Kulant tauschen.
Also bei mir scheint es jetzt zu laufen. Ich hab den PC komplett auseinander gebaut, inkl CPU vom Board genommen, alle Stecker mehrfach kontrolliert und nun läuft es bisher ohne Bluescreens. Mit welchen Programm kann ich den einen schönen System Stresstest inkl RAM machen?
Wenn hier jemand eine der neuen Radeon und Ryzen abgreifen konnte, wäre ich sehr dankbar und neugierig für Informationen bzgl. funktioniert/existiert SAM auf unseren Boards und macht es tatsächlich einen Unterschied ("klappt es")
@Windell ... hatte einfach Lust drauf. Lässt man das Refresh mal weg, dann ist das die letzte CPU für den Sockel. Reicht mir, Stand jetzt, ... wieder ewig
Für den 3900x habe ich damals "nur" 375,- Euro gezahlt und diese Woche für 330,- Euro verkauft. Passt für mich ...
Moin, ich habe ein Problem beim Update des Bios Version 2802. USB auf FAT32 frisch formatiert, das Bios von hier zwei Mal mit unterschiedlichen Namen reinkopiert:
Die Bezeichnung des Bios lautet immer "ROG-STRIX-X570-E-GAMING-ASUS-2802" und die Updates auf die neueste Asus Version (original Bios) hat immer funktioniert.
Zurzeit habe ich das aktuellste Bios V2802 und wollte die modifizierte Version V2802 zum ersten Mal von hier updaten, dabei erhielt ich folgende Meldung: „Selected file is not a proper bios“
Die Suche im Forum war nicht ergiebig, insofern meine Frage hier im Thread.
Ich hatte ja direkt 2812 geflasht mit USB Stick im Bios. (kein Flashback) Muss 2802 wirklich über Flashback aufgespielt werden? Übrigens dem 2802-Zip liegt keine Readme bei. Die findet man auf der Homepage.
Mit USB-Stick über Bios muss normal nur die Zip-Datei entpackt werden und anschliessend die BIOSRenamer.exe ausgeführt werden. Danach die umbenannte Datei auf den USB-Stick laden und das Update im Bios starten.
Edit meint, dass ich den Teil mit modifiziertem Bios überlesen habe.
Habe mir gerade mal die Readme des modifizierten Bios angeschaut. QFan wurde auch modifiziert? Was kann das modifizierte Bios mehr? Ich lese das man nun bis 0% einstellen kann und max. 85°C. Ich hatte QFan zu beginn mal getestet, war aber, wie beim alten Asus Board, ziemlich unzufrieden. Ich kann irgendwie machen was ich will, aber wenn ich QFan Tuning bei meinen Fans, egal oder PWM oder auch 3 Pin mache, kann ich die Lüfter nicht vernünftig regeln. Den PWM Lüfter der CPU kann ich nicht unter 50% einstellen. Habe aktuell alles auf DC eingestellt und regle alles über eine Software (nicht die AI Suite, alte Versionen haben mir schon ordentlich das System zerschossen). Eigentlich hätte ich ja gerne alles über das Bios eingestellt. Ich überlege deshalb, wenn die Funktion noch immer unbrauchbar ist, mir einen Aqua Computer Octo zu holen... Aber vielleicht hilft mir da ja das modifizierte Bios?
Moin, eine Frage zum Asus x570-E Gaming und der Lüftersteuerung.
Ich habe mir eine Wasserkühlung für meine GPU gekauft, NZXT Kraken X63 & NZXT G12 und habe das Problem, wie ich die beiden Lüfter der X63 am Besten anschliessen soll (zur Zeit am CPU_OPT angeschlossen - was nicht die beste Lösung ist). Mir wurde hier im Forum empfohlen zu prüfen, ob eine Lüftersteuerung auf dem Mainboard durch die Grafikkarte gesteuert wird so dass die Lüfter entsprechend der Auslastung der Grafikkarte gesteuert werden können.
Leider kenn ich mich nicht so in Detail mit den Sensoren, insofern hat vielleicht jemand die Erfahrung und kann mir hier weiterhelfen!
Ich regle bei meinen Asus Boards alles über die % im QFan, da ich eine Wakü habe laufen die Lüfter auf einer fixen Drehzahl. Hast du die mind. Drehzahl deiner Lüfter auf dem Schirm? Bei meinen Noctuas kann ich auch nicht unter 40% gehen, weil alles darunter nimmt er nicht mehr an.
@VampireIsOnline
Lüfteranschlüsse haben nur folgende Temperatur Quellen als Auswahl: CPU, Mainboard und T-Sensor. Wenn du einen Temperatursensor hast, könntest du diesen auf deine Graka stecken und dann über den Chassis Fan regeln.
@player83
Die modifizierten Einstellungen sind nur nutzbar, wenn man alles manuell einstellt. Q-Fan Tuning ermittelt Werte und schreibt dir die min Drehzahl vor. Wenn, dann musst du alles manuell vornehmen.
Wenn Last erzeugt wird, wird das Wasser warm und dann die Abluft vom Radiator auch.
Was soll da nicht stimmen?
Muss man halt ein wenig ausloten und ein Mindestdrehzahl sollte man auch immer haben.
20 Grad Wassertemperatur wären mir zu kalt im Zimmer ;D
Die Wassertemperatur ist bei mir 20c bei einer Raumtemperatur 24c. Unter Last wird die Temperatur bei mir im Tower wärmer und die Abluft wird wärmer.
Kann nur von mir reden. Hatte es auch mal mit dem Anemometer gemessen, wie es aus sieht wenn der Luftstrom höher ist.
Fand den Unterschied zu ungenau. Dann lieber einen richtigen Sensor fürs Wasser.
Nun gut, egal
Danke. Ich vermute das mein vorinstallierter Fan Hub nicht korrekt funktioniert. Soll gemäss Hersteller mit PWM und 3-Pin Lüftern funktionieren, tut es jedoch nicht. Nach erneutem "Tuning", kann ich den CPU-Lüfter problemlos konfigurieren. Leider lässt QFan gerade mal 3 Punkte zu und eben das maximum ist 75°C und ab da laufen die Lüfter IMMER mit 100%. Für meine Zwecke einfach untauglich, bzw. zu "grob".
Die 3-Pin Lüfter am Hub erkennt er mittels PWM bis auf 20% runter. Aber egal was ich einstelle, die Dinger laufen immer auf 100%. Switch auf DC funktioniert dann besser, aber wieder nur 3 Punkte und max. 75°C. Das Maximum könnte ich mit Mod-Bios aufheben und auf 85°C anheben... aber vermutlich sind es immer noch nur 3 Punkte, richtig @Reous ?
Mit Argus Monitor kann ich die Lüfter perfekt einstellen. Die Software ist ziemlich mächtig und ich kann auch die GPU-Temperatur als Referenz nehmen. Aber ich bin auf die Software angewiesen und lieber wäre mir dies unabhängig. Also einstellen über die Software und gespeichert ist dann alles auf einem Controller.
@Atomic Frost sieht aus also ob du mit Aqua Computer. Funktioniert dessen Regelung nach Einstellung über die Software unabhängig von dieser oder muss diese auch immer im Hintergrund mitlaufen?
Hat jemand den Aqua Computer Quadro oder Octo im Einsatz? Funktioniert hier mein Vorhaben vielleicht? Wie ist es eigentlich mit dem CPU-Lüfter? Kann ich diesen auch über die Aqua Computer Software steuern? Funktioniert das überhaupt, da der Rechner vermutlich gar nicht erst startet ohne einen Lüfter am Anschluss?
Wie geht das?
Ich habe 20 C° im Zimmer, Plus/Minus 1C° Unterschied Decke zu Boden.
Das hat auch mein Radi (PC einige Stunden off), gemessen mit Infrarot Temperatur Messer.
@Joker (AC) die Mora`s hängen im Keller unter der Decke.
@player83 Ich habe einen Aquaero pro im Einsatz.
Die Software muss nicht mit laufen. Du stellst alles ein, was der Aquaero auch dann speichert.
Mit der Software kannst du alles auslesen oder verstellen.
Mit der Pro Version hast du noch ein Display wo alles abgelesen werden kann.
