Vom C9 hat er noch nichts weiter gehört.
4096x2160 in 10 Bit @ 120 Hz, 4:4:4 und Gsync darstellen???
(3) Do no mess with beta firmware! Beta firmware is only available through the Service Menu of the tv. The Service Menu is locked away under a code (password) and you need a special Service Remote (please be aware that you can do unrecoverable changes by entering the Service Menu and clicking buttons without knowing what they do). The C9 can be updated via USB but the beta firmware is not available for download so there is no way to update via USB. Messing around in the service menu is a dangerous area, a wrong setting change COULD brick your tv and possibly make it an expensive paperweight. Also installing beta firmware could possibly keep you from updating your tv normally. If the beta firmware number is higher then the publicly released firmware(s), you would not be able to upgrade until the public firmware reaches a higher number than the beta firmware. It's not a guarantee the public ones will go higher in number so you could be stuck work beta firmware for a long time and miss out on features and fixes with publicly released firmware. People with a C8 model who updated the beta firmware have already missed about 2 updates that were released publicly because the public release of the updates was numbered lower.
www.forbes.com
Sehe gerade es gibt nun ne Beta 3 (Afterbuner 4.6.2. Beta 3)
ScreenShift - on off hat natürlich nix gebracht - gleiche Overscan Fehler.
Auch der neue Nvidia Treiber (456.55) hat nichts an dem G-Sync Problem mit dem C9 behoben (wollte es nur sicherheitshalber ausprobieren).
Kurzes Update - MSI hat da was falsch verlinkt (und ich hab MSI blind vertraut und die genaue Version überlesen) - ist die alte Version 4.6.2 beta 3 - MSI Afterburner 4.6.3 Beta 2 Build 15840 ist noch immer die aktuelle.
[Sammelthread] - MSI Afterburner
Der Afterburner zeigt die Auslastung jetzt tatsächlich in Watt an und nicht mehr in Prozent. Das ist neu. Ohne HWInfo.www.hardwareluxx.de
Ein erneuter OC Scan -mit dem Afterburner- hat nun geringfügige niedrige OC Werte als vom letzten Scan ergeben (obwohl noch immer unstabile bei 99% steht), aber das reicht offenbar, dass mit den neuen OC Werten im Moment auch Anno 1800 stabil läuft. Hoffe es kommt bald die MSI Afterburner 4.6.3 Final raus, die ist dann hoffentlich mit der 3000er Serie stabiler.
zb: https://arnowelzel.de/tools/monitor-test#pattern-14Klingt ja nicht so toll. Kann man das Testbild mit wenig Aufwand selbst machen?
Bei meiner RTX 3080 kriege ich -wie geschrieben- genau den gleichen Fehler.Bei mir kommt bei Afterburner die Meldung "results are considered unstable" - hast du das schonmal gesehen und/oder weißt woran es liegen könnte?
Hey,
welches HDMI Kabel sollte man nun kaufen?
Gigabyte Eagle OC. Hatte noch keine Crashes, weder mit der ersten noch mit der zweiten Firmware, habe da auch alles mal ausprobiert, vor allem BF5 und SoTR Benchmarks. Habe aber eigentlich keinen Top-Chip, 00000000:2B:00.0 müsste es sein.
Will auch gar nicht übertakten, sondern nur schauen, ob die Karte gut ist![]()
Ja shit, Smartphone mit IR ist auch keins mehr im Haus. Muss ich mir jetzt echt fürn Zehner so eine scheiß Fernbedienung bestellen@takk¥u ...das Servicemenü. Da kommt man nur mit ner alternativen IR Fernbedienung rein.
