Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
AMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Chipset
X570
Memory
3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
Graphic
Integrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support
3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage
3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LAN
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Bluetooth
Bluetooth® 5.0
Audio
SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports
3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
Accessories
User's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS
256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic
1 x HDMI 2.0
1 x DisplayPort
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
Storage
Supports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN
1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFi
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth
Bluetooth® v5.2
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB Ports
AMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O Ports
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
Accessories
Cables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
BIOS
Form Factor
ATX Form Factor
Note
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
Chipset
X570
Memory
Graphic
Multi-GPU Support
Expansion Slots
AMD X570 chipset
2 x PCIe 4.0 x1
Storage
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
LAN
Anti-surge LANGuard
Audio
Audio Feature :
- Sonic Radar III
USB Ports
3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
Special Features
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
Accessories
User's manual
1 x Supporting DVD
BIOS
Form Factor
ATX Form Factor
Note
Chipset
X570
Memory
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Graphic
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
Expansion Slots
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
Storage
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
Supports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Bluetooth
Bluetooth® 5.0
Audio
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
USB Ports
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
Special Features
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
1 x DisplayPort
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports
1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
Accessories
User's manual
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
BIOS
Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note
*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
Sound setzt aus oder knistert
Immer wieder USB Disconnects
Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
USB Disconnects
Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
USB Flashback funktioniert nicht
Bitte folgende Punkte ausprobieren:
- Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
- Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
- Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
BIOS/UEFI Downgrade
Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
Ist der Chipsatz Lüfter regelbar?
Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
Chipsatz Temperatur zu hoch?
Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
Rechner bootet nicht, wenn eine Soundkarte verbaut ist
Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Die wurde zugunsten Armory Crate eingestellt/wird nicht mehr weiter entwickelt.
Bei mir funktionierte Armory Crate eigentlich einwandfrei. Tuts prinzipiell immer noch, aber die neueste Version der Aura Bibliothek lässt sich nicht installieren, daher kann ich mit der Software die Lichter nicht mehr steuern. Interessanterweise funktioniert die Steuerung über iCue und das ASUS Plug-In trotzdem weiterhin.
Braucht man für das Asus Plug-In im iCue das Armoury Crate?
Ich habe nämlich mal testweise das Armoury Crate deinstalliert und nun ist auch das Mainboard im iCue verschwunden.
Das klappt natürlich nicht, denn iCUE ersetzt das nicht, sondern greift nur über eine Schnittstelle auf die Steuerung zu, ähnlich wie das Spiele tun. Der Aura Dienst muss also immer installiert/am laufen sein. Aber danach lässt sich alles über iCUE steuern.
Ich habe den Thread hier noch nicht komplett durchgelesen, aber was ich bisher probiert habe ist das mit den PCIe auf Gen 3
umzustellen,- hat aber temperaturmässig auf dem Chipsatz nichts ausgemacht, es blieb bei 58°C. Aber durch das aktivieren der ASPM
Funktion ist der Chipsatz jetzt bei 51-52°C. Ich hoffe es gibt keine Leistungseinbußen dadurch. Der PCH-Lüfter war vorher auch schon unhörbar.
Was ich merkwürdig finde, dass durch das Absenken der VCore per Offset (es waren bis zu -0,2V) habe ich satten CPU-Leistungsverlust, im
Cinebench ging es von 49xx auf 40xx zurück, - die CPU taktet dabei genauso wie vorher hoch.
Wenn dir das Optische nicht so wichtig ist, dann entferne noch die Lüfter Abdeckung. Sollte auch nochmal ein paar Grad bringen.
Bei aktiviertem ASPM drauf achten ob du nun USB Disconnects hast oder Boot Probleme aus dem Standby/Ruhezustand.
Eigentlich sind die Temps ok, die m.2 Karte im oberen Slot ist auch bei 36°C im idle.
Aber das mit der Abdeckung werde ich auch mal testen
PS: ich habe im BIOS die SOC Voltage auf 1,025V fixiert, vorher war es auf AUTO 1,100V
Seitdem hatte ich noch kein einziges Mal diese Neustart - bzw. aus dem BIOS raus - Hänger
Der DRAM Calculator ist mehr als brauchbar , kann die FAST Settings bei mir komplett so übernehmen
-es sieht sehr gut aus!!
Wie erreicht man solche Temperaturen mit der M.2 SSD im oberen Steckplatz?
Ich habe eine Samsung 970 Evo Plus und die ist im Idle bei 50 Grad und bei Last bis zu 65 Grad.
Ich habe mir jetzt schon ein besseres Wärmeleitpad (Alphacool Eisschicht) bestellt und hoffe das es dadurch ein paar Grad weniger sind.
Auch der Chipsatz wird relativ warm (Idle 62 Grad und Last 72 Grad)
Dadurch höre ich im Idle leider den Chipsatzlüfter (sonst wäre der PC nahezu lautlos).
Ich vermute es liegt an der RTX2080. Die Abwärme geht Richtung Chipsatz und M.2 SSD.
Wie lange braucht denn dein System um zu booten und was für eine Zeit ziehst du als Referenz her? Falls du jedes mal CSM deaktiviert hast, braucht er immer länger, weil vermutlich deine Graka dies nicht unterstützt und er sich erst wieder selbstständig aktivieren muss.
Ja. Ich habe das finale Engineering Sample der PCIe 4.0 zertifizierten Ultimate Kabel von LinkUp. Die gibt es glaub ich mittlerweile auch regulär bei Amazon zu kaufen.
Also meine Last BIOS time beim Gaming-F ist jetzt gerade zum Beispiel 25.8 Sekunden.
Die Kiste bootet trotz 3x so viel Kerne (3900x) und NVME exakt genauso schnell wie mein 6 Jahre alter 4770K es von einer Sata SSD tat ... selbst von eine WD Black war das nicht viel anders.
Vielleicht habe ich ein bisschen viel komische Hardware dran und Software drin oder so
Aber ich hatte auch irgenwie erwartet, dass es schneller geht. Aber so oft bootet man ja auch nicht.
Tatsächlich finde ich aber die Zeit vom Anschalten über Post bis das Windows-Booten mal losgeht auch schon recht lang. Das sind viele Sekunden.
Also mangelnde Gehäusebelüftung kann es bei mir eigentlich nicht sein. Habe 4x BeQuiet 140er Lüfter eingebaut. Zwei davon blasen Luft rein und 2 raus. Die drehen im Idle mit ca. 500 rpm und unter Last mit 800 rpm.
Werde mal das andere Wärmeleitpad für die M.2 SSD ausprobieren.
Nur die Chipsatztemperatur wird sich dadurch ja wahrscheinlich nicht ändern.
Ist mit dem Mod Bios eigentlich die Chipsatztemperatur (noch) höher wenn der Chipsatzlüfter sich langsamer dreht?
Der Großteil der Zeit dürfte auf das Initialisieren der Hardware entfallen. Blöd gesagt: was mehr kann, braucht mehr Zeit.
Ist nicht ganz glücklich, mir gehts vom i5-4590 auf den 3700X ja ebenso. Aber ist nicht tragisch, wir sprechen ja dennoch letztlich nur von Sekunden...
Ich habe ein altes CM HAF932 Gehäuse da sind 2x120er Lüfter von unten, 1x 250er glaub ich von vorne und 4x120er von der Seite die reinblasen, und dann
1x140er hinten und oben 3x120er Lüfter beidseitg am Radiator, die Luft abführen. Laufen alle sehr langsam, man höert nur angenehmes sehr leises Rauschen.
Hatte noch nie irgendwelche Temperaturprobleme mit keinem System hier
Ich habe ausser dem Mod-BIOS kein anderes geflasht gehabt, bei mir lief nur sehr langsam bei 58°C, und mit aktiviertem ASPM sind es jetzt knapp über 50 und der Lüfter steht.
Meine BIOS Zeit (Gaming-E) liegt bei ca. 18 Sekunden.
Man kann im BIOS einiges abschalten was nicht benötigt wird und den RAM händisch einstellen, dann braucht das Board nicht so lange zum initialisieren.
Im Vergleich zum C6H mit dem X370er bootet das Strix erheblich schneller, geradezu eine Wohltat.
Auf der anderen Seite, wie oft startet man den Rechner am Tag neu?
Ich habe bei mir im Taskmanager unter Autostart 12,4 Sek. stehen. Windows 10 ist fertig eingerichtet mit sämtlicher Software
wie Kaspersky, Office o.ä. Dienste aufgeräumt, Unnötiges Zeug deinstalliert/entfernt.
Vom Gefühl her würde ich sagen zwischen 5-7 sek vom Post-Ton bis Windows-Desktop. Is mit Abstand das schnellste Booten was ich hatte.
PS: Windows ist im UEFI-Modus installiert, kann das etwas ausmachen?
Im BIOS unter Bootreihenfolge habe ich UEFI-Manager oder so an erster Stelle stehen, -muss nachschauen wie es genau heisst.
Ansonsten sind 4 weitere SSD's und ein optisches LW verbaut, keine Festplatten.
Edit:
Heisst Windows Boot Manager(m.2_1 xxxxxxx im BIOS
Mal zu meinen RAM-Versuchen:
Kann es sein dass das Board die Settings was die Widerstände angeht falsch setzt, bzw. nicht übernimmt, oder werden sie im Windows falsch ausgelesen
vom Ryzen Master?
Habe 4 Riegeln nun drin, und es verhält sich nun ganz ganz komisch. - auf AUTO nix zu machen
Booten mit 3600 ging überhaupt nicht, nicht mal alles auf Default, 3733 nach ein Paar versuchen plötzlich, nach mehrmaligem Speichern im BIOS ohne dabei etwas zu ändern.
Mit 2 Riegeln gingen auch die 4000 ohne grosses rumprobieren, natürlich nur mit FCLK auf 1900
Kann es sein dass das Board die Settings was die Widerstände angeht falsch setzt, bzw. nicht übernimmt, oder werden sie im Windows falsch ausgelesen vom Ryzen Master?
Mit der aktuellen Version werden die Widerstände korrekt ausgelesen. Was zeigt er denn bei dir an? Die Rtts und ggf. Vddp spielen bei Vollbestückung eine große Rolle.
Wenn diese direkt angeschlossen sind, dann sollten sich theoretisch alle regeln lassen. Es gibt Probleme bei der Erkennung, wenn sie über einen Hub angeschlossen sind. Wo hast du sie denn angeschlossen und welche lassen sich nicht kontrollieren?
In Aura gibts irgendwo einen Schalter mit Synchronisieren im Text. Der schaltet die LEDs nach dem Runterfahren aus. Bei mir hat der Wasserkühler der VII sonst weitergeleuchtet.
Ja, auf AUTO EInstellungen geht gar nichts, die Timings manuell zu setzen egal wie hoch bringt nichts.
Was ich jetzt zumindest bei mir verstanden habe, dass die ProcODT ( geht nur 53,3 und 48) sowie von dir genannten RTT's (7-3-1)auf jeden Fall manuell gesetzt werden müssen!!, auch die beiden VDDG's leicht erhöht auf 0,99 - bei etwas mehr wie 1,0- kein Boot mehr.
Die CAD_BUS Einstellungen habe ich die erste und die vierte manuell gesetzt - ging, bei der dritten und vierten genügtre es nicht nur eine zu fixieren, es mussten
unbedingt beide aufeinmal manuell gesetzt werden, sonst auch kein Boot.
Es muss wohl die Kombination genau passen, nicht nur eine Einstellung
Ich bin inzwischen bei 3600 sehr stabil, und die Timings konnte ich genauso scharf anziehen wie mit 2 Riegeln.
Zu erwähnen ist dass wenn ich stabilere Settings gefunden habe, durfte ich nur in sehr kleinen Schritten weiter etwas verstellen, und nur
1-2 Optionen, ansonsten kein Booten wenn man viel aufeinmal verstellt, selbst wenn es auch nur Boot-Optionen sind....
Der ryzen Master hat mir mal bei den Widerständen mal 20, mal 24 angezeigt, obwohl die Option manuell fixert war.
Könntest du spaßeshalber mal noch Rtt 5-3-0 oder wenn diese Kombi nicht bootet noch 7-3-0 probieren und dann ggf. mit einer niedrigeren ProcODT.
Mir geht es so ähnlich wie bei dir, wenn ich 4xSR nutze. Habe das ganze aufgrund von Zeitmangel aber erst einmal eingestellt. Das Mit Ryzen Master ist interessant. War bisher der Meinung bei mir wurde immer alles richtig angezeigt.
7-3-0 gingen nach dem ersten fehlgeschlagenen Boot- Versuch (Board versucht es ja 3 mal), scheint genauso stabil zu sein, TestMem 5 läuft grad.
Jetzt dann auch niedrigere ProcODT versuchen?
Die ProcODT 43 geht jetzt auch problemlos.
Muss noch auf Stabilität prüfen. Hab jetzt keine Zeit mehr - muss arbeiten.
Also laut dem Handbuch von Asus können 5 Fans insgesamt gesteuert werden per Q-Fan.
An CPU_FAN hab ich natürlich den CPU Lüfter drangehangen.
An AIO_PUMP hab ich einen 140er der nach oben hin rauspustet rausgehangen.
An CHA_FAN1 hab ich einen 120er gepackt der nach hinten pustet.
An CHA_FAN2 hab ich 1 140er gepackt der von vorne reinpustet.
An M.2_Fan hab ich einen 1 140er gepackt der von vorne reinpustet.
Hab das Problem selbst gelöst,hatte einen Lüfter falsch drangesteckt (AIO_PUMP). Hab diesen an CPUFAN_OPT drangehangen und kann ihn "leider" nur zusammen mit dem CPU_Fan kontrollieren.
Die 5-3-xx funktionieren nicht, habs hartnäckig versucht dem Board es einzureden auch mit anderen ProcODT und RTT's.
Die 3600 habe ich soweit optimal eingestellt, ist stabil, Benchmarks passen und vor allem jederzeit bootbar wenn ich das gespeicherte Profil wieder lade.
Ich mach mich dann an die 3666 ran, so langsam bekomme ich das Gefühl für das Ganze
Die 3660 sehen gut aus
Die SoC wird vom RM falsch ausgelesen - ist im BIOS bei 1,05
Kann sein dasss das Board falsch einstellt - auf jeden fall gibts da unstimmigkeiten
Die 3733 jetzt scheinen ganz vom anderen Schlag zu sein.
Habs einmal zu starten geschafft, mit gelockerten Timings und angepassten ProcODT, CAD#s und RTT's + etwas mehr VSoC und VRAM
Dachte habe nun auch eine Basis zum optimieren weil alles sehr stabil war, - neustarts kein Problem , herunterfahren un neustarten auch.
Bis ich einmal ins BIOS bin zum Profil abspeichern und bin mit safe+exit raus, - danach kein Starten mehr. Auch laden des zuvor funktionierenden
Profils brachte kein Erfolg, - sprich das was vorher sehr stabil funktionierte, startet nicht mehr, und das nur weil ich einmal ins BIOS bin...
Das Board verstehe ich nicht...
Ja, sehr stabil, jederzeit reproduzierbar, auch bei den 3666 jetzt. Die 7-3-0 gingen auch.
Aber bei 5-xxxx war nichts zu machen
Ich schreibe gerade @3733 - nach vielmaligen Startversuchen und immer kleien Änderungen
-es ist nichts ausgelotet, ich muss zuerst eine Basis finden, welche ich dann jederzeit laden und starten kann.
Traue mich jetzt gar nicht ins BIOS....
Wenn ein zuvor stabiles Setting nicht mehr startet, dann einfach mal mit einem Zwischenritt booten. Hat bei mir immer funktioniert. Spricht das Setting laden, RAM Takt auf zb. 3466 reduzieren, booten und auf den ursprünglichen Takt anheben.
