[Sammelthread] ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
ROG Strix X570-E Gaming
ROG Strix X570-E Gaming Wifi II
ROG Strix X570-F Gaming
ROG Strix X570-I Gaming
BIOS/UEFI Versionen
Reviews & VRM
Häufig gestellte Fragen
BIOS Mods
ChangelogDownload
Flashing and using on your own risk!
  • Added VDDP Voltage
    Might be helpful for CPU overclocking
  • Added ASPM Support (Should be visible by default since v4802)
    PCIe Energy Saving
  • Added Erp Ready (Strix-E only)
    Energy Saving
  • Unlocked AMD PBS
    Hidden options unlocked
  • Added PCH Temerature
    Shows the PCH Temperature in the Bios
  • Added PCH Fan Control
    Gives you control over the PCH Fan
  • Advanced (Pump) Fan Settings
    Min and Middle Duty Cycle can be changed to 0%
  • Added Advanced Boot Settings
    Might be helpful for faster boot
Strix X570-E Gaming
Download Folder
Download Folder
Strix X570-F Gaming
Download Folder
Strix X570-I Gaming
EOL
CPUAMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
ChipsetX570
Memory3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
GraphicIntegrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots3rd Gen AMD Ryzen™ Processors
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
BluetoothBluetooth® 5.0
AudioSupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
AccessoriesUser's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form FactorATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
Bios Version 0807
AiTweaker
Advanced
Monitor
Boot
Tool
Kompatibilitätsliste
Memory QVL Ryzen 3000/4000/5000
Chipsatz Modding
Alternativer Chipsatz Kühler von KCX
ROG Strix X570-E Gaming WIFI II
Produktseite | Handbuch (EN) | Support-Downloads | Preisvergleich
CPUAMD Ryzen™ 5000 Series/ 5000 G-Series/ 4000 G-Series/ 3000 Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors
ChipsetX570
MemoryAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic1 x HDMI 2.0
1 x DisplayPort
Expansion SlotsAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
StorageSupports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFiWi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
BluetoothBluetooth® v5.2
AudioRealtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB PortsAMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special FeaturesExtreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O PortsFan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
AccessoriesCables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
Full Specs:
ChipsetX570
AMD X570 chipset
2 x PCIe 4.0 x1
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Anti-surge LANGuard
Audio Feature :
- Sonic Radar III
USB Ports3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
1 x Supporting DVD
Chipsatz Modding
Wasserkühler von Neo111430
ChipsetX570
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
LANIntel® I211-AT
Anti-surge LANGuard
WiFiSupports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
Form FactorMini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Sound setzt aus oder knistert
    Immer wieder USB Disconnects
    Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
  • USB Disconnects
    Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
    UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
    Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
  • USB Flashback funktioniert nicht
    Bitte folgende Punkte ausprobieren:
    - Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
    - Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
    - Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
  • BIOS/UEFI Downgrade
    Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
  • Ist der Chipsatz Lüfter regelbar?
    Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
  • Chipsatz Temperatur zu hoch?
    Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
    Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
  • Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
    Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
  • Rechner bootet nicht, wenn eine Soundkarte verbaut ist
    Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
So hab mal mit AIDA ne halbe Stunde alles gestresst und ne Runde CoD BO4 ohne FPS Limit gezockt.
(Raumtemperatur 23,5°C - unterm Dach)
Chipset Temp maximal 82,6°C mit Standard Profil Gehäuse-Lüftung (480rpm) nach jetzt einer Stunde Stress.
Mit maximaler Lüftung (Full Speed Profil - 2415rpm) kann ich ihn auf 65,3°C drücken. Die Lautstärke ist dann aber natürlich nicht ertragbar und macht erst recht keinen Sinn.
Allerdings zeigt es, dass eine gute Gehäusebelüftung einiges ausmachen kann bei der Chipset Temperatur.
Im Idle mit Standard Profil (240rpm) schwankt er zwischen 74,3° und 74,5°C
Im Idle mit Turbo Lüftung (750rpm) schwankt er zwischen 71,3° und 71,5°C
Beim zocken (CoD BO4 ohne Limit) mit Turbo Lüftung (1250rpm) wird er 78,8°C
Ich denke, ich werde mich am MSI Silence Mode orientieren und mal so einstellen.
- - - Updated - - -
Hier noch ein Pic vom PC (hab eine ultra schlechte Kamera - Gigaset 370 plus) damit ihr euch was unter der Gehäuselüftung vorstellen könnt...
3x 120mm Case + 2x 120mm AiO
Des Weiteren noch ein HWInfo Screen der Test Session.
- - - Updated - - -
Added Temperature Source (Monitor)
- VRM, PCH, DIMM
Auch richtig edel von dir :cool:
Wieso kommt sowas nicht von Asus :stupid: ... ?
Danke nochmal für den Mod :love:
Bedenkt bitte, dass eventuell einige der freigeschalteten Optionen nicht funktionieren werden. Mem Fail Count zb funktioniert nicht. Hab ich eben feststellen müssen. Ob die Lüfter mit Quelle als VRM oder DIMM funktionieren ist auch ungewiss. PCH hatte ich getestet und dies hat funktioniert.
Ansonsten recht interessanter Test. Mit einem größeren passiven Kühler und guter Gehäuse Belüftung, könnte das auch ganz gut funktionieren. Einige X370 Chips hatten ja auch um die 70 Grad im Idle.
Alles klar weiß Bescheid. Habs auch noch nicht getestet.
Das denke ich auch. Evtl bringt auch bessere Leitpaste noch ein Grad!?
Mit dem PCH Setting Lower 75°C und Min. Duty 31% hab ich es nicht geschafft ihn über 77°C zu bekommen. Im Idle ist er aus, da die Gehäuselüftung ihn unter 75° hält. Beim Zocken geht er dann an und liegt zwischen 240rpm und 560 hat aber auch 1000rpm Peaks.
So stelle ich mir das vor... beim surfen, office etc. ist er aus und beim Zocken geht er ganz leicht an. Vorher war er immer an und min bei 1800... beim Zocken ging er in Richtung 3000. Klar war er dafür nie über 65°C aber denke, dass muss nicht.
Irgenwann wenn ich Bastellaune habe, bestelle ich mir evtl. so einen Enzotech CNB-S1 oder was anderes!? Ggf. lasse ich mir vom Freund ne Haltung oder so drucken. https://www.aquatuning.de/wasserkuehlung/mb-kuehler/mb-spezialkuehler/7039/enzotech-cnb-s1-northbridge-kuehler - Müsste den Lochabstand mal in der Diagonalen messen.
Dann die gute Thermal Grizzly WLP und mal schauen wo man landet. Durch die Kühlstäbe kann die Gehäuselüftung doch 10x besser die Wärme abführen. Jetzt rauscht die Luft doch quasi nur dran vorbei.
Allerdings kann man bei so hohen Kühlern die GPU nur noch mit Riser Kabel betreiben, da der Block sonst im Weg ist...
- - - Updated - - -
Zalman ZM-NB47J oder ZM-NBF47 sieht auch so aus als könnten die helfen...
Ich habe das Modbios drauf, es wurden ja nur die Stellrädchen verändert. Er macht jetzt 100 Punkte CB20 selben Settings mehr wie gestern, warum auch immer. Vielleicht weil ich von 7010 auf 1005 bin und Ihr von 807, ist aber eigentlich unwahrscheinlich. Die 100 Punkte mehr macht er bei den selben Taktraten 3.997GHz (Bios auf Auto) bei CB. Egal, mehr Leistung nehmen wir gern mit ;). Ich mach mich jetzt mal an die Lüftersteuerung.
PBO war wohl der Grund für die 100 Punkte. War gestern auch aktiv, wollte wohl aber nicht so richtig. Ohne PBO komme ich wieder auf den Wert von gestern.
Zum Bios, bitte noch mehr Stellrädchen :). Es gefällt mir schon sehr gut und macht jetzt auch den Eindruck es wäre das Bios eines Premiumproduktes. Ich freu mich auf jeden Fall noch auf das was kommt.
Der würde mir sogar gefallen aber den bekommt man so gut wie nirgendwo mehr.
Hast schon alle Optionen in der AMD CBS Datei ausprobiert? Dann kannst doch sicherlich sagen, welche funktionieren und welche nicht :d?
Noch! Nicht.
Kommt mir das nur so vor oder sehe ich doppelt. Vieles kann man über den AI Tweaker oder unter CPU Otionen ja es schon einstellen. OK wenn es um Masse an Stellrädchen ging, ja sind vorhanden. Alle durchtesten wird etwas Zeit in Anspruch nehmen ;).
Könnt ihr Screenshots machen? Meine Dateien lassen sich nicht öffnen. Ich kann die Datei noch nicht mal hier hochladen. Auch Google erkennt das Bild nicht. 190814154332.BMP - Google Drive
Scheinbar sind die drei Timings normalerweise nicht da!?
Trcpage - bei mir aktiv - fehlt sonst? - steht auto auf 0
tRFC2 - bei mir aktiv - fehlt sonst? - steht auto auf 192
tRFC4 - bei mir aktiv - fehlt sonst? - steht auto auf 132
EDIT: Gab es früher wohl nicht... wurde mir vergessen zu sagen :bigok:
So Freunde der Nacht, ich hab mal die Waküblöcke montiert. Der Kupfer bräuchte noch etwas kürzere Schrauben. Hab jetzt mit WLP statt Pad montiert. Muss man einfach mit Gefühl anziehen dann bricht auch nix am Chip ab.
Lochabstände: 25mm in der Breite, 44mm in der Höhe.
Alles mit Langlöcher sollte passen. Problem ist eher dann die Höhe Grafikkartekühler/Chipsatzkühler weil Asus den Chip schon ziemlich nah auf Höhe des ersten 16x PCIe Slot angebracht hat.
Leider warte ich noch auf die RX 5700XT daher aktuell eine passive Dualslot. Das passt dann nicht mit den Anschlüssen vom Chipsatzblock. Wenn ich nen Wakü-Block dranhalte sollte es aber denk ich genau ausgehen. Mehr dann am WE.
# x570 chipset waterblock Strix-F
# x570 watercooling chipset Strix-F
Da sich jetzt schon einige hier eingefunden haben, könnte man mal eine RAM Liste erstellen.
DDR4 3766 CL16-19-16-38-CR1 scheint zu laufen. Bis 1500% im Karhu ist er schon gewesen. Teste jetzt aber ausführlich...
Crucial Ballistix Sport LT grau DIMM Kit 32GB, DDR4-3000, CL15-16-16 (BLS2C16G4D30AESB/BLS2K16G4D30AESB)
Micron 8Gbit E-Die
KCX
- - - Updated - - -
So Freunde der Nacht, ich hab mal die Waküblöcke montiert.F
Top Mod ! Bin ja auf die Temps gespannt. :cool: Mit CoD BO4 hab ich bisher die höchsten Temps messen können.
Bei einigen der ersten Asus AM4 Boards war die Backplate in der Tat verklebt aber das haben sie schnell wieder geändert. Für eine saubere Kühlerinstallation würde ich das Board aber eh immer ausbauen. Einen Kühlerwechsel macht man in der Regel ja auch nicht so oft.
Ansonsten gibt es genug Möglichkeiten es auch so zu installieren. Entweder klemmt man etwas unter die Backplate (Der Beipackzettel von den AMD CPUs passt zb gut darunter :d) oder man ist schlau und schraubt zb. erst einmal nur die untere Halterung ab und montiert sofort die neue. Somit ist die Backplate immer von einer Seite geklemmt und es kann nichts abfliegen :).
Hm, warum sollte ich das Board dafür ausbauen? Erst die eine Halterung und dann die andere einbauen ist natürlich eine gute Idee, funktioniert aber nur, wenn man von einer Halterung auf die nächste wechselt. Das geht aber leider nicht, wenn man erst einmal einen Wraith installieren möchte. :( Und der lässt sich nur schwer drauf schrauben. Heute habe ich meinen Noctua montiert, unglaublich, wieviel einfacher es geht. Tolles Teil.
Auch witzig, wie das Board bei Cinebench Single-Core (auf eine CPU eingeschränkt...) einfach die Lüfter ausschaltet. Ist nicht nötig, das kann der auch passiv kühlen. :d
Habe einen 3600 drauf und komme einfach nicht auf mehr als 3,9 GHz All-Core oder 4,07 Single bei einem der guten CCXe. Mehr als 90 W TDP will das System einfach nicht geben, obwohl ich PBO (glaube ich) aktiviert habe und in Sachen Temperatur noch ordentlich Reserven vorhanden sind (der Wraith hat die 95 geknackt und dann gedrosselt...).Sollte da mehr drin sein? Mache ich etwas falsch?
Ich fahre grad Crucial Ballistix Sport LT, 32 GB Kit DDR4-3200 CL16 mit CL16-19-24-58-CR1. Das hat mir der DRAM Calculator ausgespuckt. Davor hatte er das Profil falsch ausgelesen, das Ergebnis waren etwas schärfere Timings die leider nicht stabil waren. :(
Es kommen Triple 140er+Triple 120er+ Single 120er Radiatoren ins System. Schätze über 45°C wirds Wasser nie kommen ^^
Wer übrigens den PCH Lüfter absteckt sollte: am besten diese ROG Plastikabdeckung runternehmen. Die paar Finnen wo der Kühlkörper hat sind sonst verdeckt und eigentlich total auf aktiven Lufstrom ausgelegt. Auch könnte man einen weiteren passiven Kühler einfach auf den vorhanden mit Wärmeleitpad machen (Lüfter muss natürlich runter) um ihn so deutlich zu steigern. So z.B. :
Das ist auch mein Notfallplan wenn der Wasserkühler am Ende doch nicht mit der Graka will. Hab auch noch Heatpipes da um die Performance nochmal zu steigern.
Danke, ist eingetragen.
Wenn du später ein finales Setting hast, kannst du auch gerne einen Screen dazu posten.
Teilweise sogar dreifach. AMD hat teilweise doppelt die Einstellungen in das CBS und AMD Overclocking Menü eingefügt und Asus hat zusätzlich einige Settings in den AiTweaker eingefügt :d
Hat jemand Erfahrung mit der Bootdauer mittels NVMe SSD auf dem Strix-E?
Hintergrund ist, dass ich plane, eine Samsung 970 Evo Plus M.2 SSD zum Board zu holen, als Systemplatte für Windows und Programme.
Jetzt hab ich aber gelesen, dass der PCIe erst nach den SATA Controllern initialisiert würde, was zur Folge hat, das die Bootzeit mit einer SATA3 SSD schneller sei, als mit der NVMe im M.2.
Ist da was dran? Wie verhält sich das Strix-E?
Gesendet von meinem SM-G930F mit Tapatalk
Das StriX-E bootet sehr schnell mit einer 970er, ich habe die Konfig. Mir sogar zu schnell da dieses Fastboot Windows wie auch im EFI nur Proleme macht (mit Allen Boards!). Ich habe beide Optionen deaktiviert da ich mit Zusatzhardware arbeite und einen sauberen Windowsstart brauche, ist trotzdem noch zu schnell. Mir ist lieber das meine Maschine Leistung bring wenns benötigt wird als das sie in unter 10 Sekunden im Desktop ist.
Ich finde keine Option wo man die TDP der CPU auch in den negativen Bereich deckel kann. Kann auch sein ich habe etwas übersehen, könnt ihr mir da weiterhelfen?
sry doppelpost
Hey, Laufen die Asus X570 eigentlich zuverlässig mit aktueller AGESA?
Schicke mein C6H zurück und nehme doch ein Board mit X570 Chipsatz.
Das Strix-F soll ja nicht der Hit sein also Strix-E (mit Cashback 289€)
Wichtig wäre mir noch ob die Board direkt hochfahren (auch wenn sie direct vom Strom getrennt waren) oder irgendwie neustarten
Meine Grafikkarte im zweiten Slot zu haben wäre doch ohne Nachteile oder? Die 2080TI reizt ja keine 3.0 16x aus und daher auch keine 4.0 8x oder?
die 2080TI kann keine 4.0 x8 da sie nur 3.0 unterstützt.
Was genau meinst du mit negativen Bereich der TDP?
Freunde der Nacht,
es geht sich knapp aber am Ende ohne Probleme aus :bigok:
Ich hab jetzt den EK Vector Nickel verbaut. Sollte aber quasi jeder Wasserblock gehen da ja meist Single-Slot. Den ganz flachen Heatkiller Chipsatz Kühler braucht man also gar nicht.
Definiere zuverlässig.. und was ist am CH6 nicht zuverlässig? :)
Mir geht dieses ganze Beta gedöns auf den Nerv....jedes Update bringt neue Probleme. Das System läuft zwar stabil aber solche Dinge die 4 mal starten. Oder das alle Treiber nach dem Biosupdate zurück gesetzt nerven mich schon etwas. Spiele wie ESO wollen so immer neu Authentifiziert werden.
Letzteres Beta BIOS hatte wohl nen Lüfterbug bei dem ab und an und sporadisch nen Lüfter aussteigt.
Meine Hoffnung ist das X570 besser aufgestellt ist ansonsten bleibt mir nur Intel :heul:
100% = 105W ich will halt auf 95W runter. Angeblich sollen die Ryzen damit besser können als wenn ich einen negativen Offset setze. Bis jetzt nur Optionen gefunden um über 100% zu kommen. Will halt die Effizienz ein wenig steigern wenn möglich.
Mal probiert über mit den PTT, TDC und EDC Werte zu spielen? Passende Werte müsste man durch ausprobieren ermitteln. Im CBS gibt es aber auch noch Einstellungen dazu: cTDP und Package Power Limit aber die hab ich vergessen im Mod freizuschalten... :wall:
Hey war trotzdem gute Arbeit ;). Da es bei den GA Platinen schon funktioniert wird es ASUS vielleicht noch implementieren.
Ich habe die 3000er auch noch nicht komplett verstanden, jeden Tag eine neue Erkenntnis. Gut finde ich das Silliconlottery und Caseking ihre Methoden für pretested CPUs offenlegen, so kann ich meine CPU besser einschätzen. Ich liege zumindest im oberen Mittelfeld mit meinem 3900X.
Wenn man den 3900X nicht an der absoluten Kotzgrenze fährt mit allen OC Spielchen die es so gibt kann man in Sachen Effizienz so viel rausholen, ist der Wahnsinn und macht richtig Spaß.
Ich hab da nicht groß rumprobiert, aber ich kann die TDP problemlos per PPT limitieren. Beim 3600 komme ich auf ein Minimum von 45 Watt (44 eingestellt), Core Voltage liegt meist bei 0.938 V (Volllast).
Mein Problem ist, dass ich bei 88, 89 Watt eine Grenze habe. Auch wenn ich die TDP auf 200 Watt einstelle. Mit dem 3600 will er nicht über 89 Watt. :( Anandtech hat mal erwähnt, dass der bis 88 Watt geht. Leider bin ich entweder zu blind oder die haben nicht gesagt, bei welchen Settings. Ob es das Maximum mit PBO ist.
Womit lest ihr eigentlich eure Werte ab? In HWInfo64 finde ich nix zum Chipsatzlüfter, zur VRM-Temperatur, ...
