[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Welche Temperatur ließt du aus?
CPUTIN oder Package?
Ich hab Bios 3.20 und bei mir ist CPUTIN = Bios CPU Temp (ich hab die Temperatur auf dem LCD am mainboard, daher kann ich das gut vergleichen)
HWMonitor ist nicht HWInfo :)
Aber ich check morgen früh mit HwInfo - dann sach ich dir was es ist.
Da hab ich mich verlesen :)
Danke, ich teste dann auch Mal HW Monitor.
Bei mir sieht es so aus (meine Version von HWinfo scheint aber neuer)
Der Wert "CPU" gibt genau das gleiche aus wie das Display auf dem Mainboard - der Wert "CPU (Tclt/Tdie)" scheint das Package zu sein.
Hallo allerseits,
ich wollte mich nochmals melden zwecks RAM Kompatibilität.
Ich hatte Probleme mit dem Corsair LPX. Zu meiner Schande muss ich gestehen, dass ich einen Knick in meiner Optik hatte und ich nicht die Version V5.39 sondern V5.30 habe...
Diese lief auf dem Board (K4) mit 2400 MHz stabil und ab 2666 MHz in unregelmäßigen Abständen mit bootloops.
Da die RAM Preise in letzter Zeit so günstig sind, habe ich mir die Trident Z(F4-3200C16D-16GTZB) gegönnt.
Diese stehen auf der offiziellen QVL von Asrock.
Diese schienen auf Anhieb mit 2933 MHz zu funktionieren, setzten sich nach ein paar Reboots wieder auf 2133 Mhz zurück, auch einige Einstellungsversuche gaben keine Stabilität.
Asus Prime x370 bestellt.
Der Corair LPX läuft mit 2933 Mhz sehr gut, der Trident Z mit 3066 MHz mega stabil, mit 3200 MHz einige bootloops, aber ohne unterschiedliche Einstellungen auszuprobieren. Keine Ahnung ob das stabil laufen wird.
Beim Asus außerdem ohne Bios Update schon gut stabil.
Unterm Strich muss ich sagen, dass das kein so gutes Licht auf Asrock wirft, ist die Stabilität mit dem Gaming X besser?
Das ist bekannt. Du musst nur beide Boards mit dem gleichen AGESA Code vergleichen. Alte BIOSe mit älterem AGESA Code liefen mit einigen Speichertypen nämlich besser. Und da gerade bei AMD im höheren Frequenzbereich es immer wackelig war/ist, sollte man genau auf die Güte der Speicher und welche Chips dort verbaut sind achten. Die meisten Boards in der Klasse werden nur so 2933 MHz richtig stabil sein, und ich rede nicht vom nur Windows booten, sondern stressstabil ;)
Kann ich nach dem Umstieg absolut bestätigten.
Auf dem K4 liefen meine Riegel maximal mit 2933MHz, auf dem K6 (Z370) dann mit 3466MHz mit Luft nach oben.
Da ist noch Raum für Verbesserungen, auch was die angepassten Timings und das Training seitens des Boards angeht.
Ja, in meinen Augen halt nicht seitens der Riegel.
1. (ich kann nur für das Gaming X sprechen) Liefen meine 3200 Wunderbar (B-Dies) - mit dem neusten AGESA
2. Liefen auf zwei B350 Asus Boards die riegel nicht nach specs (2800 statt 3200 - Corsair mit HynX)
3. Hat auch die CPU was mitzureden. Hab auf dem selben Board, mit dem selben RAM und zwei verschieden R7-1700er unterschiedliche RAM OC Ergebnisse erzielt.
Was interessiert mich der AGESA Code? Versetze dich doch mal in einen normalen PC Käufer.
Ich habe beim X370 K4 alle UEFI Versionen, sobald diese Released wurden, upgedated. Mit dem Corsair LPX. Keine einzige brachte Besserung. Max 2400MHz stabil.
Der Trident Z lief mit 3.40 auf default Settings mit 2933MHz instabil. Und selbst mit einigen Anpassungen habe ich es nicht hin bekommen.
ASUS Prime X370 Auslieferung UEFI 0805(AGESA 1006a):
Corsair LPX bootet ohne Probleme mit 2933MHz.
Der Trident Z läuft stabil mit 3066MHz, auch nach UEFI Update auf 3402(AGESA 1071).
Ich erkenne absolut keinen Zusammenhang zum AGESA. Ich erkenne auch keinen Zusammenhang zur CPU, es ist dieselbe.
Die einzige Möglichkeit ist nur noch dass das Board einfach nen Knall hat.
Dass das K4 nicht gut lief ist hinlängst bekannt. Das Gaming X soll deutlich besser sein.
RAM auf AM4 hat offensichtlich auch etwas mit den CPUs zu tun. Ich kann mir gut vorstellen, dass die neuen Ryzen da besser sind und auf einmal auf den standard Boards bis 3200 gut gehen und auf den dicken, ähnlich wie Intel, bis 4000 MHz laufen können. Der IMC scheint einfach nicht belastbar zu sein. Wenn AMD das fixt/verbessert und die Leistung weiter am RAM Takt hängt (LL-Chache Latenz >2MB Zugriff auf RAM Niveau) werde ich ganz sicher nochmal upgraden im Sommer.
Sorry für bissl Offtopic
Beim Corsair Vengeance LPX gibt es mehrere Revisionen und jene läuft bei unterschiedlichen AGESA Codes anders. Ein richtiger Händler hätte dir Speicher empfohlen, die für AMD geeignet sind.
Deine Module sind speziell für Intel konzipiert... Kann auf AMD laufen, muss aber nicht ;)
Vengeance® LPX Speicherkit 16 GB (2x8 GB) DDR4 DRAM 3200 MHz C16 – Schwarz (CMK16GX4M2B3200C16)
Corsair LPX speziell für AMD...
Vengeance® LPX 16GB (2 x 8GB) DDR4 DRAM 3200MHz C16 Memory Kit - Black (CMK16GX4M2Z3200C16)
Wenn das nicht so wäre, warum baut Corsair mit unterschiedlichen Typen ?
Und der AGESA Code im BIOS ist gerade wenn du Boards vergleichst sehr wichtig. Vergleiche dann bitte Boards mit gleichen AGESA Code in den BIOSen. Die ganze Speicherverwaltung läuft nämlich über den AMD AGESA Code ;)
He JZ,
alles was ich in dem Post mitteilen wollte war, dass auf dem Asrock X370 K4 beide RAMs nie richtig gut gelaufen sind, während auf dem ASUS X370 Prime auf Anhieb beide geschmeidig gut laufen(entgegen meinen Erwartungen).
Beachte: Asrock - UEFI V3.00 AGESA 1.0.0.6a -> Corsair bootet auf max 2666MHz
ASUS - UEFI 0805 AGESA 1.0.0.6a -> Corsair bootet auf 2933MHz
Gleicher RAM, gleiche CPU, alles gleich.
Und das selbe Verhalten(auch mit dem Trident Z)bei jeweils den letzten UEFI Versionen. Das hat sicher nichts mehr mit AGESAs zu tun. Oder hast du da Tests mit anderen Ergebnissen gemacht?
so das große update is raus 4.5 mit bridgerelease 3.5 zum vorher installieren.
erster eindruck: GflaresX booten jetzt auch bei 3333mhz, Nachteil: meine 3200 mhz sind nicht mehr stabil, wahrscheinlich darum weil man die DRAM voltage nicht erhöhen kann. -> BUG ; Änderung im Bios wird nicht übernommen
Servus, ich hab mir nun auch das Gaming X bestellt, glaube einen extra Thread gibt es ja nicht?
Da mein MSI x370 Gaming pro Carbon gefühlt die absolute zicke ist, will ich's mal hier versuchen..
Also das neue BIOS (v4.5) für das X370 Gaming K4 bringt mal richtig viel. Zum einen scheint es jetzt umfangreichere Optionen, aber auch deutlich mehr Ryzen-spezifische Einstellungen zu geben. So lässt sich z.B. das Prefetching für den L1- und den L2-Cache ein- bzw. abschalten und weitere Spielereien.
Zudem scheint man sich nochmal mit der RAM-Problematik befasst zu haben. Meine Vengeance LPX-Module lassen sich jetzt tatsächlich auch mit 2933 MHz starten! Das war mir vorher partout nicht gelungen. Ich muss allerdings dazu sagen, dass ich das Ganze auch noch nicht wirklich unter Last getestet habe, aber auch ein Start ist für mich schon ein Erfolg, da vorher (stabil) bei 2400 MHz meist das Ende erreicht war.
Mich hat das neue BIOS für das Gaming K4 bisher leider nicht weiter voranbracht. Weder die 3200er FlareX noch die 3600er TridentZ hab ich damit mit einem höherem Takt stabil zum laufen bekommen. Bleibt also der Stand von 3066 Mhz für die FlareX und 2933 für die TridentZ.
Werd da sicherlich in der nächsten Zeit noch weiter testen, aber bin aktuell eher skeptisch mit diesem BIOS und meiner Konfiguration (CPU, Board und RAM) höhere Taktungen zu erreichen.
Schau ich heute Abend mal rein. Danke.
Genau so wie du es beschrieben hast, hab ichs auch versucht. So einfach funktionierts bei mir leider nicht und das bei keinem der beiden Kits (beide Samsung B-Die).
Den FlareX bekommt ich nur (für meine Zwecke) stabil auf 3066, wenn ich folgendes einstelle:
DRAM Voltage 1.365, Soc Voltage 1.05, BGSwap Disabled, CR 1, GearDown enabled, ProcODT 53 Ohm und alle Timings selber eintragen (ausgehend von den eigentlich im XMP-Profil hinterlegten Timings, welches ich bei ASRock Settings nicht aktiviert hab). Weichen natürlich bei ein paar Timings von dem vom Board errechneten Werten ab, aber da ist nichts Wildes dabei. Ändert letztlich auch nix, wenn ich die ausgehend von den XMP-Werten vom Board errechneten Werte eintrage.
Die QVL-Liste auf der ASRock-Seite des Gaming K4 führt bisher ja nur ein Kit auf, dass 3200 schaffen soll. Also entweder geht da im Moment einfach nicht mehr oder ich hab einfach in der Silicon-Lottery verloren.
Jop, das Video ist sehr hilfreich. Ich habe vermutlich auch das gleiche Kit (Corsair Vengeance LPX). Das Problem ist nur, dass leider nicht jeder Boot mit dem Gaming K4 klappt. Gibt es da denn jetzt eigentlich gesicherte Informationen inwieweit sich das Gaming X und das Gaming K4 wirklich unterscheiden? Ich hab da schon sehr merkwürdige Sachen gelesen, angefangen von: "Es gibt keine Änderungen" über "Eine Komponente wurde ersetzt" (PWM Controller für die Spannungsversorgung) bis "Die Spannungsversorgung wurde komplett neu designed"
Experimentiere gerade herum mit der internen Pumpen-Steuerung des Boards, da meine DDC 3.25 auf 12V unerträglich laut ist.
Problem ist: Wenn man eine eigene Kennlinie definiert, kann man die minimale CPU-Temperatur nicht unter 30°C stellen. Wenn diese unterschritten wird, schaltet das Board die Spannungszufuhr an diesem Port komplett ab, d.h. meine Pumpe geht ständig an und aus, da bei mir im Idle die CPU-Temperatur unter 30°C sinkt.
Mit "Monitor Tctrl" kann ich jedoch die Pumpe dauerhaft laufen lassen - kann mir jemand verraten, was das für eine Temperatur ist, die da als Referenz herangezogen wird?
TCTRL ist die Temperatur, welche für XFR herangezogen wird - also reale CPU-Temperatur +20°C als Offset, um immer auf der sicheren Seite für die mini-Taktsteigerung bei XFR zu sein. Wenn Du dann deine Kurve mit dem Wissen, das die für die Pumpenleistung benutzte Messung immer 20°C zu viel anzeigt neu anpasst, geht das ohne Probleme.
also mit dem 4.5 bios wurden meine DRAM Voltages ned übernommen, sodass ich meine GFlaresX nicht stabil auf 3200 bringen konnte. ins Windows kam ich sogar mit 3333mhz, also denke ich, da wäre mehr möglich wenn die Spannung speichern würde.
Allgemein kam mir das 4.5er Bios stabiler vor.
bin dann aber doch wieder zurück auf 3.4. Komischerweise ist jetzt mein Ram nicht mehr stabil beim zocken auf 3200.
Ausserdem hatte ich bei meinem 1600x den Segfault bug, OC über 3850 war damit nicht möglich und nen höheren Vcore brauchte er auch. + Idle Freezes hin und wieder -> ab zum RMA
Austauch Cpu um welten besser, zieht weniger saft - 4ghz mit 1.4 möglich alles nice
