[Sammelthread] ASUS ROG Rampage VI Apex (Intel X299; LGA2066)
THE EXTREME OC BOARD FOR ENTHUSIASTS
indexInhaltsverzeichnis
1.01. das ASUS ROG Rampage VI Apex
1.11.1 Mainboard-Bilder
1.21.2 BIOS-Bilder
1.31.3 Spezifikationen
CPUIntel® Socket 2066 Core™ X-Series Processors
Supports Intel® Virtual RAID on CPU (VROC)
* The Intel® Turbo Boost Max Technology 3.0 support depends on the CPU types
* Refer to ASUS Deutschland
for CPU support list
ChipsetIntel® X299
MemoryIntel® Core™ X-series Processors (6-core above)
4 x DIMM, Max. 64GB, DDR4 4133(O.C.)/4000(O.C.)/3866(O.C.)/3800(O.C.)/3600(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2600(O.C.)/2400/2133 MHz Non-ECC, Un-buffered Memory
Intel® Core™ X-series Processors (4-core)
2 x DIMM, Max. 32GB, DDR4 4500(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
Multi-GPU SupportSupports NVIDIA® 4-Way SLI™ Technology
Supports NVIDIA® 3-Way SLI™ Technology
Supports NVIDIA® 2-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX Technology
Expansion SlotsIntel® Core™ X-Series Processors Family
4 x PCIe 3.0 x16 (x16, x16/x16, x16/x8/x8, x16/x8/x8/x8 or x8/x8/x8/x8 mode with 40-LANE CPU; x16, x16/x8 or x8/x8/x8 mode with 28-LANE CPU)
Intel® X299 Chipset
1 x PCIe 3.0 x4
StorageIntel® Core™ X-Series Processors Family :
1 x ROG DIMM.2 Module support(CPU_DIMM.2)*1,
2 x M.2 Socket 3*1, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
Intel® X299 Chipset :
1 x M.2 Socket 3*2, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
1 x M.2 Socket 3*2, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 4 mode)
1 x ROG DIMM.2 Module support(PCH_DIMM.2)*2
4 x SATA 6Gb/s port(s)
ASMedia® ASM1061 controller :
2 x SATA 6Gb/s port(s),
Supports Intel® Smart Response Technology
Intel® Optane™ Memory Ready
LANIntel® I219V
Anti-surge LANGuard
Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY)
Wireless Data NetworkWi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports MU-MIMO
BluetoothBluetooth V4.2
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback
USB PortsIntel® X299 Chipset :
6 x USB 3.1 Gen 1 port(s) (4 at mid-board)
5 x USB 2.0 port(s) (3 at mid-board)
ASMedia® USB 3.1 Gen 2 controller :
1 x USB 3.1 Gen 2 front panel connector port(s)
2 x USB 3.1 Gen 2 port(s)
ASMedia® USB 3.1 Gen 1 controller :
4 x USB 3.1 Gen 1 port(s)
ROG Exclusive FeaturesClear CMOS button
ROG RAMCache II
ROG CPU-Z
ROG CloneDrive
MemOK! Button
Slow Mode
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- IR3555 PoweIRstage®
- MicroFine Alloy Chokes
- 10K Black Metallic Capacitors
Mem TweakIt
ROG Extreme OC kit :
- PCIe x16 Lane Switch
Double Power :
- Dual 8 -pin CPU
ProbeIt
UEFI BIOS features :
- O.C. Profile
- Tweakers' Paradise
- ROG SSD Secure Erase
Extreme Tweaker
USB BIOS Flashback
Special FeaturesOC Design - ASUS PRO Clock II Technology
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
ASUS 5X Protection III :
- ASUS SafeSlot Core: Fortified PCIe Slot prevents damage
- ASUS LANGuard: Protects against LAN surges, lightning strikes and static-electricity discharges!
- ASUS Overvoltage Protection: World-class circuit-protecting power design
- ASUS DIGI+ VRM: 8 Phase digital power design
Gamer's Guardian:
- DRAM Overcurrent Protection
- DIGI+ VRM
- SafeSlot
SafeDIMM slot
AURA :
- Aura Lighting Effects Synchronization with compatible ASUS ROG devices
ASUS Exclusive Features :
- AI Suite 3
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 4
ASUS EZ DIY :
- ASUS MyLogo
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED, HDD LED)
- ASUS Q-Connector
Gaming Aesthetics :
- 3D printing friendly
- AURA-RGB Lighting
Operating System SupportWindows® 10
Back I/O Ports1 x PS/2 keyboard (purple)
1 x PS/2 mouse (green)
1 x LAN (RJ45) port(s)
1 x USB 3.1 Gen 2 ()
2 x USB 3.1 Gen 2 (red)Type-A + USB Type-CTM
6 x USB 3.1 Gen 1
2 x USB 2.0
1 x Optical S/PDIF out
1 x Clear CMOS button(s)
1 x USB BIOS Flashback Button(s)
1 x ASUS 2x2 Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.2 module
5 x Gold-plated audio jacks
Internal I/O Ports1 x Q_Code
1 x AAFP connector
2 x Aura RGB Strip Headers
2 x USB 3.1 Gen 1 connector(s) support(s) additional 4 USB 3.1 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 1 USB 2.0 port(s)
0 x TPM header
6 x SATA 6Gb/s connector(s)
1 x VROC_HW_Key
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
2 x 8-pin EATX 12 V Power connector
1 x 24-pin EATX Power connector(s)
2 x 8-pin ATX 12V Power connector(s)
1 x MemOK! button(s)
1 x Slow Mode switch(es)
9 x ProbeIt Measurement Points
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x BIOS Switch button(s)
1 x USB BIOS Flashback button(s)
1 x LN2 Mode jumper(s)
1 x ROG extension (ROG_EXT) header(s)
1 x Safe Boot button
1 x ReTry button
2 x T_Sensor Connector
1 x 3D Mount screw port(s)
1 x W_IN header
1 x W_OUT header
1 x W_FLOW header
2 x DIMM.2 Slot supports 2 M.2 drives (2242-22110)
5 x 4-pin Full Speed Fan connectors
1 x PCIe x16 Lane Switch
2 x RSVD Switch
Accessories User's manual
Accessory Guide
I/O Shield
4 x SATA 6Gb/s cable(s)
4 x M.2 screws
1 x Supporting DVD
1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
1 x R6A MOS Fan bracket pack
2 x ROG DIMM.2 Fan Stand Pack (s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI HB BRIDGE(2-WAY-L)
1 x ROG big sticker
1 x Q-Connector
1 x 10 in 1 ROG Cable Label(s)
1 x ROG coaster(s)
BIOS2 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.0, ACPI 6.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information.
Form FactorExtended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm ) X-SHAPED PCB
1.91.9 BIOS-Versionen
offizielle BIOS-Versionen:
inoffizielle BIOS-Versionen: (Benutzung auf eigene Gefahr!!!)
1.101.10 Reviews, News und Videos
Internationale Links: (evtl. werden Übersetzer benötigt)
2.02. Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
2.12.1 CPU-Kühler
  • Kühler Noctua NH-D15: passt, aber bei hohen Rams müssen die Lüfter außermittig montiert werden. Bei Einsatz DIMM.2-Card im PCH-Slot ergibt sich dadurch ein höherer Aufbau von 1,5 - 2 cm. Der NH-D15 ist recht breit. Bei einer GraKa wie EVGA GTX 1080 SC2 im ersten Slot liegt der Kühlkörper stramm auf der GraKa auf! <- Danke an lofterdings
2.22.2 RAM-Kompatibilitätsliste
3.03. Hilfreiche Links, Tipps und FAQ
3.13.1 Quelle Hardwareluxx
Hardwareluxx-Links
3.23.2 Quelle Internet (international)
3.33.3 FAQ
Häufig gestellte Fragen:
  • Gibt es einen Monoblock für das R6A?
    • Ja, EKWB hat diesen bereits vorgestellt: Quelle
  • Ich kann im BIOS die VCCIN-Spannung nicht finden.
    • Wenn SVID im Bios aktiviert ist, kommt es vor, dass der Punkt VCCIN im Bios nicht mehr sichtbar ist. Dazu einfach SVID auf AUTO stellen oder deaktivieren.
  • Man fährt das System normal im Windows herunter und startet dann später den Rechner wieder mit dem Einschaltknopf.
    Der Rechner startet kurz für eine Sekunde, geht dann wieder aus und startet dann erst normal.
    • Video dazu: ASUS ROG Rampage VI Double Post - YouTube
      Wenn man im Bios in den APM-Einstellungen die Funktion ErP-Ready auf Enable (S4+S5) oder Enable (S5) stellt, startet das System nach einem Kaltstart quasi zwei Mal.
      Laut elmor (Asus) kann man das wohl nicht so einfach fixen:
      Confirmed over here that this is caused by setting ErP Ready = Enable (S4+S5) or Enable (S5). It's not something that can be "fixed", just how it's implemented. It does the initial boot in order to set correct boot voltage values before continuing, same behavior as when going from a full power off.
      Also ErP Ready deaktivieren. Ist natürlich blöd, weil dann die USB-Ports auch im ausgeschalteten Zustand Strom bekommen und die LEDs auf dem Board an sind. Aber die LEDs kann man deaktivieren.
  • Vollständiger CMOS-Reset (ASUS-Empfehlung)
    • 1. PC ausschalten
      2. vom Strom trennen
      3. Beim letzten PCIe Slot befindet sich die Bios-Batterie. Diese herausnehmen und falsch herum einsetzen.
      4. 10 bis 15 Minuten warten
      5. Batterie wieder richtig rum einsetzen
      6. Einschalten
      Wichtig: während Schritt 3 bis 5 darf der PC nicht an das Stromnetz anschlossen werden!
      Laut ASUS Informationen löscht dies wohl den Cache von vorherigen BIOS Versionen und löst auch gleichzeitig einen vollständigen Reset vom aktuellen BIOS aus.
Danke für das Erstellen des Sammelthreads. Ich habe ihn gerade auch schon in den Übersichten verlinkt :wink:
Nice. Ich hab gerade beim Auspacken erst gemerkt, dass das Ding gar keine klassischen M.2 Slots mehr hat, sondern nur die DIMM.2. Auch nicht schlimm, bin gespannt wie das aussehen wird.
Ohne verbaute RAM-Module sieht das zwar etwas merkwürdig aus:
Aber sobald der RAM daneben steckt, fallen die DIMM.2 kaum noch auf.
Vorteile sind z.B.
• leichterer Austausch der SSDs
• die SSDs liegen im Lüftungsbereich der Front-Lüfter, falls vorhanden.
- - - Updated - - -
Danke für das schnelle verlinken :bigok:
Naja zumindest rechts pustet der Frontlüfter drauf, dafür werden die Ram Module und VRM Kühler aber blockiert.
Links profitieren die SSds vom Luftabzug des Hecklüfters.
Find die M2 Halterung trotzdem hässlich :d da finde ich eine Lösung wie beim Rampage um Welten besser
Ich finds auch nicht häßlich, sieht irgendwie freaky / schön technisch aus. Ich würd nur mal gern ein pic vom Apex sehen mit einer 960 Pro und RAMs drin.
Wem das nicht gefällt der kann ja eine Asus Hyper card verbauen.
Here you go (ist links am IO)
Danke dir.
Leuchtet das Apex so an den Aussparungen oder hast da was gemoddet?
Find ich auch, wusste ich gar nicht.
Gingen im OC wirklich nicht gut, wie du mir damals per PN geschrieben hattest. Hab jetzt die originalen mit dem Roten Kopf und den würde ich gerne schwarz lackieren.
Welches Kit ist es bei dir geworden und was machen die "nur" an OC mit?
Hab auch gerade ein Kit am Wickel und teste gerade 4000 16-16-16 1T auf dem kleinen Apex.
Hab das B-Die Kit 3600C17Q-32GTZ bei 16-16-16-32 1T.
F4-3600C17Q-32GTZR nehme ich an?
Ist doch ein ganz anständiges Kit. Sollten problemlos DDR4-4000/4133 mit machen bei entsprechender Spannung.
Da gibt es einen kleinen "Bug", bzw. notwendiges Feature beim Apex und auch beim Extreme...
Wenn man im Bios in den APM-Einstellungen die Funktion ErP-Ready auf Enable (S4+S5) oder Enable (S5) stellt, startet das System nach einem Kaltstart quasi zwei Mal:
Startet dann später den Rechner wieder mit dem Powerknopf
Der Rechner startet kurz für eine Sekunde, geht dann wieder aus und startet dann normal.
Laut elmor kann man das wohl nicht so einfach fixen:
Also ErP Ready deaktivieren. Ist natürlich blöd, weil dann die USB-Ports Strom bekommen und die LEDs auf dem Board an sind. Aber die LEDs kann man deaktivieren.
Hier mal ein Video wie sich das System dann verhält:
Ich baue das mal oben in die FAQ ein.
Ja genau ist das. Leider muss es aber dringend lackiert werden.
4000 machen die wohl alle, aber nicht alle mit den schärferen Timings. Das timing von oben wollten nicht alle machen, die ich hier hatte
Noch als Ergänzung zu Elmors Aussage: Das ist kein Bug, sondern ein notwendiges Verhalten. Beim ersten Start werden die Custom Einstellungen der Embedded Controller (TPU/iROG) auf dem Board geladen und beim zweiten Start bootet das Board dann mit den im BIOS gesetzten Werten. Das ist übrigens auch bei so ziemlich allen anderen Modellen mit zusätzlichen Embedded Controllern für OC Einstellungen so, vor allem wenn der Rechner komplett vom Strom getrennt wird. Grundsätzlich sollte der kurze Doppelstart aber kein Problem sein.
Ich würde DDR4-3600 16-16-16 jetzt nicht als sonderlich scharf bezeichnen, sonfern du nicht bestimmte Subtimings meinst. Bei denen kann es PCB bedingt Unterschiede zu den Non-RGB Modellen geben. Ist aber kein Deal Breaker für 24/7, sondern nur wenn man das Kit primär zum benchen verwendet.
Ich finde diesen Doppelstart aber nicht so prickelnd für meine Pumpen ;)
Mein MSI X299 hatte diese Verhalten komischerweise nicht. Gut, das hatte auch keinen OC-Controller. :fresse:
Dann deaktiviere ich lieber ErP.
Hallo zusammen,
hat jemand von euch schon Erfahrung mit RAM Vollausbau (also 4x16GB Riegel) bei diesem Board gesammelt? Sind da irgendwelche unerwarteten Probleme / Nachteile / Einschränkungen bekannt? Die QVL umfasst ja kein einziges 64GB Kit...
Gruß,
blindfish
Oh, da hats bei mir aufgehört, bevor ich alle QVL Listen Namen gelesen hatte.. Danke :)
Ähnliche Themen
