indexInhaltsverzeichnis
1.01. das ASUS ROG Rampage VI Apex
1.11.1 Mainboard-Bilder
1.21.2 BIOS-Bilder
1.31.3 Spezifikationen
| CPU | Intel® Socket 2066 Core™ X-Series Processors Supports Intel® Virtual RAID on CPU (VROC) * The Intel® Turbo Boost Max Technology 3.0 support depends on the CPU types * Refer to ASUS Deutschland for CPU support list |
| Chipset | Intel® X299 |
| Memory | Intel® Core™ X-series Processors (6-core above) 4 x DIMM, Max. 64GB, DDR4 4133(O.C.)/4000(O.C.)/3866(O.C.)/3800(O.C.)/3600(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2600(O.C.)/2400/2133 MHz Non-ECC, Un-buffered Memory Intel® Core™ X-series Processors (4-core) 2 x DIMM, Max. 32GB, DDR4 4500(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory |
| Multi-GPU Support | Supports NVIDIA® 4-Way SLI™ Technology Supports NVIDIA® 3-Way SLI™ Technology Supports NVIDIA® 2-Way SLI™ Technology Supports AMD 4-Way CrossFireX Technology Supports AMD 3-Way CrossFireX™ Technology Supports AMD 2-Way CrossFireX Technology |
| Expansion Slots | Intel® Core™ X-Series Processors Family 4 x PCIe 3.0 x16 (x16, x16/x16, x16/x8/x8, x16/x8/x8/x8 or x8/x8/x8/x8 mode with 40-LANE CPU; x16, x16/x8 or x8/x8/x8 mode with 28-LANE CPU) Intel® X299 Chipset 1 x PCIe 3.0 x4 |
| Storage | Intel® Core™ X-Series Processors Family : 1 x ROG DIMM.2 Module support(CPU_DIMM.2)*1, 2 x M.2 Socket 3*1, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode) Intel® X299 Chipset : 1 x M.2 Socket 3*2, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode) 1 x M.2 Socket 3*2, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 4 mode) 1 x ROG DIMM.2 Module support(PCH_DIMM.2)*2 4 x SATA 6Gb/s port(s) ASMedia® ASM1061 controller : 2 x SATA 6Gb/s port(s), Supports Intel® Smart Response Technology Intel® Optane™ Memory Ready |
| LAN | Intel® I219V Anti-surge LANGuard Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY) |
| Wireless Data Network | Wi-Fi 802.11 a/b/g/n/ac Supports dual band frequency 2.4/5 GHz Supports MU-MIMO |
| Bluetooth | Bluetooth V4.2 |
| Audio | ROG SupremeFX 8-Channel High Definition Audio CODEC S1220A - Impedance sense for front and rear headphone outputs - Supports : Jack-detection - SupremeFX Shielding Technology - Supports up to 32-Bit/192kHz playback |
| USB Ports | Intel® X299 Chipset : 6 x USB 3.1 Gen 1 port(s) (4 at mid-board) Intel® X299 Chipset : 5 x USB 2.0 port(s) (3 at mid-board) ASMedia® USB 3.1 Gen 2 controller : 1 x USB 3.1 Gen 2 front panel connector port(s) ASMedia® USB 3.1 Gen 2 controller : 2 x USB 3.1 Gen 2 port(s) ASMedia® USB 3.1 Gen 1 controller : 4 x USB 3.1 Gen 1 port(s) |
| ROG Exclusive Features | Clear CMOS button ROG RAMCache II ROG CPU-Z ROG CloneDrive MemOK! Button Slow Mode Overwolf ReTry Button Safe Boot Button Start Button Reset Button LN2 Mode ROG Aura - Aura Lighting Control - Aura RGB Strip Headers Extreme Engine Digi+ : - IR3555 PoweIRstage® - MicroFine Alloy Chokes - 10K Black Metallic Capacitors Mem TweakIt ROG Extreme OC kit : - PCIe x16 Lane Switch Double Power : - Dual 8 -pin CPU ProbeIt UEFI BIOS features : - O.C. Profile - Tweakers' Paradise - ROG SSD Secure Erase Extreme Tweaker USB BIOS Flashback |
| Special Features | OC Design - ASUS PRO Clock II Technology 5-Way Optimization by Dual Intelligent Processors 5 - Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages. ASUS 5X Protection III : - ASUS SafeSlot Core: Fortified PCIe Slot prevents damage - ASUS LANGuard: Protects against LAN surges, lightning strikes and static-electricity discharges! - ASUS Overvoltage Protection: World-class circuit-protecting power design - ASUS DIGI+ VRM: 8 Phase digital power design Gamer's Guardian: - DRAM Overcurrent Protection - 10K Black Metallic Capacitors - DIGI+ VRM - SafeSlot SafeDIMM slot AURA : - Aura Lighting Control - Aura RGB Strip Headers - Aura Lighting Effects Synchronization with compatible ASUS ROG devices ASUS Exclusive Features : - AI Suite 3 ASUS Quiet Thermal Solution : - ASUS Fan Xpert 4 ASUS EZ DIY : - ASUS MyLogo ASUS Q-Design : - ASUS Q-Shield - ASUS Q-Code - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED, HDD LED) - ASUS Q-Connector Gaming Aesthetics : - 3D printing friendly - AURA-RGB Lighting |
| Operating System Support | Windows® 10 |
| Back I/O Ports | 1 x PS/2 keyboard (purple) 1 x PS/2 mouse (green) 1 x LAN (RJ45) port(s) 1 x USB 3.1 Gen 2 () 2 x USB 3.1 Gen 2 (red)Type-A + USB Type-CTM 6 x USB 3.1 Gen 1 2 x USB 2.0 1 x Optical S/PDIF out 1 x Clear CMOS button(s) 1 x USB BIOS Flashback Button(s) 1 x ASUS 2x2 Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.2 module 5 x Gold-plated audio jacks |
| Internal I/O Ports | 1 x Q_Code 1 x AAFP connector 2 x Aura RGB Strip Headers 2 x USB 3.1 Gen 1 connector(s) support(s) additional 4 USB 3.1 Gen 1 port(s) 1 x USB 2.0 connector(s) support(s) additional 1 USB 2.0 port(s) 0 x TPM header 6 x SATA 6Gb/s connector(s) 1 x VROC_HW_Key 1 x CPU Fan connector(s) 1 x CPU OPT Fan connector(s) 1 x AIO_PUMP connector 1 x W_PUMP+ connector 2 x 8-pin EATX 12 V Power connector 1 x 24-pin EATX Power connector(s) 2 x 8-pin ATX 12V Power connector(s) 1 x MemOK! button(s) 1 x Slow Mode switch(es) 9 x ProbeIt Measurement Points 1 x EZ Plug connector(s) (4-pin Molex power connector) 1 x Power-on button(s) 1 x Reset button(s) 1 x BIOS Switch button(s) 1 x Clear CMOS button(s) 1 x USB BIOS Flashback button(s) 1 x LN2 Mode jumper(s) 1 x ROG extension (ROG_EXT) header(s) 1 x Safe Boot button 1 x ReTry button 2 x T_Sensor Connector 1 x 3D Mount screw port(s) 1 x W_IN header 1 x W_OUT header 1 x W_FLOW header 1 x USB 3.1 Gen 2 front panel connector 2 x DIMM.2 Slot supports 2 M.2 drives (2242-22110) 5 x 4-pin Full Speed Fan connectors 1 x PCIe x16 Lane Switch 2 x RSVD Switch |
| Accessories | User's manual Accessory Guide I/O Shield 4 x SATA 6Gb/s cable(s) 4 x M.2 screws 1 x Supporting DVD 1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant) 1 x R6A MOS Fan bracket pack 2 x ROG DIMM.2 Fan Stand Pack (s) 1 x 3-Way SLI bridge(s) 1 x 4-Way SLI bridge(s) 1 x SLI HB BRIDGE(2-WAY-L) 1 x ROG big sticker 1 x Q-Connector 1 x 10 in 1 ROG Cable Label(s) 1 x ROG coaster(s) |
| BIOS | 2 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.0, ACPI 6.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information. |
| Form Factor | Extended ATX Form Factor 12 inch x 10.7 inch ( 30.5 cm x 27.2 cm ) X-SHAPED PCB |
1.91.9 BIOS-Versionen
offizielle BIOS-Versionen:
- ROG RAMPAGE VI APEX BIOS 0227
- First Release BIOS
- ROG RAMPAGE VI APEX BIOS 0601
- Improve system stability
- ROG RAMPAGE VI APEX BIOS 0702 (Diese Version wurde vom offiziellen ASUS-Server entfernt)
- 1.Upgrade M.2 compatibility
2.Updated EC firmware
3.Upgrade DRAM compatibility and performance.
4.Update SKL-X CPU MicroCode
- ROG RAMPAGE VI APEX BIOS 0802
- 1.Fixed SanDisk M.2 device issue.
2.Fixed PLEXTOR device issue.
3.Update Intel X-series CPU (6-core and above) microcode.
4.Improved DRAM / system compatibility.
5.Improved secure erase function.
6.Improved Q-Fan function.
7.Improved system performance.
8.Improve PCH PCIe SSD Performance.
- ROG RAMPAGE VI APEX BIOS 1003
- Patches the ITBM (Intel Turbo Boost Max) device not found error.
- ROG RAMPAGE VI APEX BIOS 1004
- 1.Fixed some keyboards issue
2.Updated IRSTe to v5.2.0.1029
3.Improved Q-Fan function
4.Improved Intel VROC tech
5.Improved system stability
inoffizielle BIOS-Versionen: (Benutzung auf eigene Gefahr!!!)
- ROG RAMPAGE VI APEX BIOS 0026
- Latest BIOS, based on official 0802. Supports Windows XP with Kaby Lake-X. No throttling due to Vccin.
- ROG RAMPAGE VI APEX BIOS 0030
- Updated LN2 profiles for LCC and HCC CPUs. Added Vccin Tracker option under Tweaker's paradise, enabled means "phantom throttling" is on.
- ROG RAMPAGE VI APEX BIOS 0038
- Supports Windows XP with Kaby Lake-X. No throttling due to Vccin.
1.101.10 Reviews, News und Videos
Internationale Links: (evtl. werden Übersetzer benötigt)
- hardwareinside.de: Asus ROG Rampage VI APEX das perfekte X299 Mainboard im Test
- youtube.com (der8auer): ASUS Rampage VI Apex im VRM Test
- proclockers.com: ASUS ROG Rampage VI Apex Intel X299 Motherboard Review
- overclock3d.net: ASUS ROG Rampage VI Apex Review
- Tech Testers: ASUS ROG Rampage VI Apex Review
- Greentech: ASUS ROG Rampage VI Apex Review
- XFastest: ASUS ROG Rampage VI Apex Review
- Lanoc Reviews: ASUS ROG Rampage VI Apex
2.02. Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
2.12.1 CPU-Kühler
- Kühler Noctua NH-D15: passt, aber bei hohen Rams müssen die Lüfter außermittig montiert werden. Bei Einsatz DIMM.2-Card im PCH-Slot ergibt sich dadurch ein höherer Aufbau von 1,5 - 2 cm. Der NH-D15 ist recht breit. Bei einer GraKa wie EVGA GTX 1080 SC2 im ersten Slot liegt der Kühlkörper stramm auf der GraKa auf! <- Danke an lofterdings
2.22.2 RAM-Kompatibilitätsliste
- G.Skill Trident Z RGB DIMM Kit 64GB, DDR4-3600, CL17-19-19-39 (F4-3600C17Q-64GTZR) -> Beitrag von SirOli
- G.Skill Trident Z DIMM Dual-Kit 32GB DDR4-3200 CL15-15-15-35 (F4-3200C15D-32GTZ) läuft problemlos. <- Danke an lofterdings
3.03. Hilfreiche Links, Tipps und FAQ
3.13.1 Quelle Hardwareluxx
Hardwareluxx-Links
- LGA 2066 X299 VRM Liste
- [Sammelthread] Intel Skylake-X & Kaby Lake-X OC Laberthread (LGA2066)
- [Guide] Intel Skylake-X (Sockel 2066) OC Guide
3.23.2 Quelle Internet (international)
- Overclockers.com.au Forum: ASUS ROG RAMPAGE VI APEX OVERCLOCKING THREAD
- HWBOT Forum: ROG Rampage VI Apex
- ROG Rampage VI Apex Overclocking Guide
- Aktuelle Treiber bei Station-Drivers
3.33.3 FAQ
Häufig gestellte Fragen:
- Gibt es einen Monoblock für das R6A?
- Ja, EKWB hat diesen bereits vorgestellt: Quelle
- Ich kann im BIOS die VCCIN-Spannung nicht finden.
- Wenn SVID im Bios aktiviert ist, kommt es vor, dass der Punkt VCCIN im Bios nicht mehr sichtbar ist. Dazu einfach SVID auf AUTO stellen oder deaktivieren.
- Man fährt das System normal im Windows herunter und startet dann später den Rechner wieder mit dem Einschaltknopf.
Der Rechner startet kurz für eine Sekunde, geht dann wieder aus und startet dann erst normal.- Video dazu: ASUS ROG Rampage VI Double Post - YouTube
Wenn man im Bios in den APM-Einstellungen die Funktion ErP-Ready auf Enable (S4+S5) oder Enable (S5) stellt, startet das System nach einem Kaltstart quasi zwei Mal.
Laut elmor (Asus) kann man das wohl nicht so einfach fixen:
Confirmed over here that this is caused by setting ErP Ready = Enable (S4+S5) or Enable (S5). It's not something that can be "fixed", just how it's implemented. It does the initial boot in order to set correct boot voltage values before continuing, same behavior as when going from a full power off.
Also ErP Ready deaktivieren. Ist natürlich blöd, weil dann die USB-Ports auch im ausgeschalteten Zustand Strom bekommen und die LEDs auf dem Board an sind. Aber die LEDs kann man deaktivieren.
- Vollständiger CMOS-Reset (ASUS-Empfehlung)
- 1. PC ausschalten
2. vom Strom trennen
3. Beim letzten PCIe Slot befindet sich die Bios-Batterie. Diese herausnehmen und falsch herum einsetzen.
4. 10 bis 15 Minuten warten
5. Batterie wieder richtig rum einsetzen
6. Einschalten
Wichtig: während Schritt 3 bis 5 darf der PC nicht an das Stromnetz anschlossen werden!
Laut ASUS Informationen löscht dies wohl den Cache von vorherigen BIOS Versionen und löst auch gleichzeitig einen vollständigen Reset vom aktuellen BIOS aus.
- 1. PC ausschalten
da finde ich eine Lösung wie beim Rampage um Welten besser
