to be honest.
all x370 are in this or that way crappy.
So you will find many user reviews for every board.
If you don't like to handle with 1000 limits, bugs and fixes, then go better straight to Intel...
If you can handle that and you are here for performance, then go for the ryzen.
When you buy Ryzen, then you have to choose the less worst option under only crappy boards.
it's crazy
but it's worth.
If you ask me, the x370 Prime is still bad, too... but.. it's the best under the all-crappy-boards...
about the capacitor case, I find nothing.
I am not saying, that you are lying, but google is really quite clear with only 39 results:
Asus Prime X370-Pro - Google-Suche
it's crazy
but it's worth.
In many
They wont offer the same settings as some x370 but they will do the job. the thing with the ports is semi-true. the CH6 with its 14(!) USB ports is epic in my opinion
and with the 4 i get from the headers for my case its 20 that i can use.
