[Sammelthread] ASUS ROG Maximus VIII Series (Z170)
--- ASUS ROG Mainboards ---
Spezifikationen
ASUS Maximus VIII
Model (Abk.)Extreme (M8E)Formula (M8F)Hero (M8H)Ranger (M8R)Gene (M8G)Impact (M8I)
Bild?
PreisvergleichLinkLinkLinkLinkLinkLink
Formfaktor"E-ATX"
(305x272)
ATX
(305x244)
ATX
(305x244)
ATX
(305x244)
µATX
(244x244)
ITX
(170x170)
Erweiterungs-
steckplätze
(PCIe = 3.0)
3x PCIe x16 (16/0/0, 8/8/0, 8/4/4)
1x PCIe x16 (x4)
2x PCIe x1
3x PCIe x16 (16/0, 8/8)
1x PCIe x16 (x4)
3x PCIe x1
2x PCIe x16 (16/0, 8/8)
1x PCIe x16 (x4)
3x PCIe x1
1x PCIe x16 (x4)
3x PCIe x1
1x PCIe x4
1x PCIe x16
Storage1x M.2 (SATA & PCIe x4)
1 x U.2 (32Gbit/s)
6x SATA 6Gb/s (Z170)
2x SATA 6Gb/s ()
2x SATA Express
1 x U.2 (32Gbit/s)
1 x M.2 (SATA & PCIe)
6x SATA 6Gb/s
2x SATA 6Gb/s (ASM1061)
2 x SATA Express
2x SATA Express
1x M.2 (SATA & PCIe)
6x SATA 6Gb/s
2x SATA Express
6x SATA 6Gb/s
2x SATA Express
1x U.2 (32Gb/s)
4x SATA 6Gb/S
NetworkingIntel I219V
3×3 802.11ac Wi-Fi
Bluetooth 4.0 (BCM9436*)
Intel I219V
2x2 802.11ac Wi-Fi
Bluetooth V4.1 (Atheros)
Intel I219VIntel I219VIntel I219VIntel I219V
2×2 802.11ac Wi-Fi
Bluetooth 4.1 (Atheros)
USB (ext/int)2x USB 3.1 (2x Typ A, ASM1142)
2x USB 3.1 (Typ A+C*², Intel)
8x USB 3.0 (4+4)
6x USB 2.0 (0+6)
8x USB 3.0 (4+4)
2x USB 3.0 (ASMedia)
4x USB 2.0 (0+6)
2x USB 3.1 (Typ A+C, ASM1142)
6x USB 3.0 (2+4)
8x USB 2.0 (4+4)
6x USB 3.0 (2+4)
8x USB 2.0 (4+4)
8x USB 3.0 (6+2)
4x USB 2.0 (4+4)
2x USB 3.1 (Typ A+C, Intel)
6x USB 3.0 (4+2)
AudioSupremeFX 2015 (Realtek)
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P DAC
TI RC4580 OP Amp
ROG SupremeFX Impact III
ESS ES9023P DAC
TI RC4580 OP Amp
GrafikausgängeHDMI 1.4b
DisplayPort 1.2
Thunderbolt 3 (am Typ C)
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
Sonstiges1) Spannungsmesspunkte
2) Heatpipekühler
3) Multi-BIOS
4) OC Panel II
1) ROG Armor
2) Waku-Anschlüsse
3) ROG Aura RGB Lighting
1) TB-Header1) TB-Header1) Spannungsmesspunkte
2) Heatpipekühler
1) M.2 durch Wi-Fi belegt
DownloadsSupportSupportSupportSupportSupportSupport
HandbuchE10739.pdfE11081.pdfE10343.pdfE10485.pdfE10484.pdfE10809.pdf
Special Features
BIOS
Bilder (vom M8G)
Alternativ in der Galerie zum Hardwareluxx Test ab Bild 18: bios-1 » Fotostrecken
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL:
1) ASUS Maximus VIII Extreme - 100915.pdf
2) ASUS Maximus VIII Hero - 081815.pdf
3) ASUS Maximus VIII Ranger - 20150805.pdf
4) ASUS Maximus VIII Gene - 081815.pdf
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Kann man von einer Samsung SM951 AHCI M.2 SSD booten?
  • A: Ja, das ist möglich - bestätigt durch Maverickpx200 ab BIOS 0603 (im UEFI Modus).
  • Q: Gibt es einen Trick gegen sporadische Bootprobleme mit für den Speicher typischen Debug Codes wie 41/44/55?
  • A: Im UEFI die Einstellung Maximus Tweak auf Mode 1 stellen. Dadurch wird Kompatibilität mit problematischen Kits verbessert.
  • Q: Sobald ich das XMP meines Speichers aktiviere habe ich Bildaussetzer am HDMI-Ausgang. Was kann ich dagegen tun?
  • A: Bei meinem System mit M8G war die Lösung VCCIO und VCCSA für den jeweiligen Speichertakt manuell auszuloten. Die AUTO Werte waren vermutlich deutlich zu hoch.
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Wer eine UEFI Installation hat, kann mal folgendes versuchen:
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
    Start in unter 10 Sekunden, je nach Datenträger & Peripherie eventuell auch knapp darüber.
5) M8G Wallpaper (by emissary42)
6) Sondermodelle
HARDWARELUXX News Sondermodelle: ASUS ROG Maximus VIII Hero Alpha und ROG Maximus VIII Extreme/Assembly
SondermodelleProduktfotoPreisvergleichSupportUnterschiede (zum Standardmodell)
ASUS ROG Maximus VIII Extreme AssemblyLinkDownloadsPlasma Copper Color Scheme
+ 10Gbit PCIe x4 LAN Adapter
+ SupremeFX Hi-Fi Frontpanel
- OC Panel II
ASUS ROG Maximus VIII Hero AlphaLinkDownloads+ 2x U.2 (32Gbit/s)
+ ROG Aura RGB Controller (2x LED-Header)
Press Release: ASUS Republic of Gamers Announces Maximus VIII Extreme/Assembly and Matrix GTX 980 Ti
7) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
Das Asus Maximus VIII Hero 3201 Bios ist geflasht:fresse2: MAXIMUS-VIII-HERO-ASUS-3201
läuft soweit wieder mit allen alten Einstellungen bleibt also drauf, nur der Speicher z. Z. 3866MHz will erst mal wieder nicht auf 3905MHz das ist dann wohl eine interne Boardregelung.:d Jep langsam wieder rantasten.
Noch ohne Changelog oder halt wie immer, ist das wieder eher ein Kaby Bios.
Auf wieviel mhz oc ihr die NB ? wie in den Videos 4500 oder alles was geht? Was soll man damit für Vorteile erzielen?
Auf wieviel mhz oc ihr die NB ?Was soll man damit für Vorteile erzielen?
4100MHz mehr verträgt das System nicht, was für einen Sinn es überhaupt macht keine Ahnung, fest steht wen ich den BCLK erhöhe steigt die NB im Verhältnis.:fresse2:
Jemand Erfahrungen mit den neuen BIOS und Kaby Lake?
welche Erfahrung brauchst du denn? Und welches Board ist gemeint?
Ich hab auf dem Hero 8 auch das 3102 bios, heute dann doch mal komplett win 10 neu gemacht und nur die richtigen Treiber installiert, das alles auf der neuen 960pro....
Was soll ich sagen schon geil :d
Läuft endlich so wie ich mir das vorgestellt hab, 3D Mark 103000punkte der 2001 er und keines Drops mehr.
CPU läuft auf 4800mhz Speicher bei 3733mhz aber noch 2 T weiß nicht was man da noch ändern sollte damit 1T geht, vielleicht hat jemand da Erfahrung Tipps, mauhaudi hats auf Asus noch geschafft? Oder war das doch das OCM?
Mich interessiert speziell das Impact. Bevor ich mir die Mühe mache und 3 Stunden am basteln bin bis ich einen 7700k eingebaut habe wüsste ich gern ob die hohen Multis mittlerweile stabil laufen ;)
Die Multis laufen mit dem BIOS, 48 geht bei mir 50 hab ich noch nicht ganz stabil, aber das liegt eher an mir oder dem Prozessor. Also könntest du bequem wechseln.
Berichte mal nach dem Umbauen mit deiner Super 7700K CPU:fresse2: ob das dann wieder so ungefähr hinhaut.:d
Hab leider keine "Super CPU" mehr so zwei Mal Durschnitt und einmal oberes Quartil. Bericht vermutlich kommende Woche ;)
Ich habe mal hier in dem Angebots Thread einen Intel Core i7 7700K Kaby Lake @ 5GHz 1.264v geschossen:fresse2: With new BIOS (3201) its possible and booting from it for 5G. wohlgemerkt auf einem Ranger:d sollte dann auf dem Hero auch so sein.
Auf welchem Board wurde die CPU getestet? Beim (M)OCF kann man pauschal mal fast 100mV draufrechnen auf die ASUS Boards.
Ich finde auf Anhieb nix im Beitrag also sorry wenns dazu schon eine Antwort gibt: Mein Hero 8 bootet bei jedem Systemstart ins Bios, erst nach Exit-> ohne Änderungen speichern bootet es wieder normal. woran könnte das liegen?
Was sagt denn der Post-Code?
Mal CMOS Reset und alles neu einstellen. Vielleicht hat sich irgendwo ein Fehler eingeschlichen.
Autsch ich weiß auf einem ASRock Z170 OC:fresse2:
Board und CPU gehen schon mal und Prime stabil braucht es ja nicht so zu sein sowas wie 5,1GHz bei 1,3V würde auch reichen zum Testen nehme ich dann ein Spiel wie BF1 wens da geht gehts.
So auf die schnelle mehr als 5GHz weniger als 1.3V, Ram bei Board max erreicht, Danke.:fresse2:
Naja wenn es nicht Prime Stable ist wird es auch nicht BF1 Stable sein:-) Ich hab Prime 20 Std im Custom durchrattern lassen und jeweils noch 8 Stunden in den heiklen FFTs. Hatte mehrere Abstürze als BF1 rausgekommen war, zuvor bei keinem Game Probleme. Zuerst dachte ich es ist das Graka-OC oder die Graka-Treiber. Nach einer vcore Erhöhung von läppischen 0,005V ist es nun stabil:-) Also ja, BF1 ist auf jedenfall ein guter Hinweis ob das OC stabil ist, nebst natürlich anderen Tools mit welchen man testet:-)
Vorallem ist BF1 deswegen ein guter Test, weil die Temperatur der CPU durch das warme Gehäuse bei LuKü und das wärmere Wasser bei WaKü eben nochmal stärker belastet wird.
Bei Prime wird ja nur die CPU belastet und die Temperaturen sind daher deutlich geringer als wenn noch die Graka Abwärme dazukommt.
Kommt noch dazu. Bei meinem kleinen mATX Gehäuse macht das Tempmässig einiges aus im Gegensatz zu früher wo ich noch Wakü und ein grosses Gehäuse hatte. Sprich wenn die Grafikkarte noch zu 100% arbeitet dann geht die Post anders ab als nur mit Prime95 alleine und die Lüfter der Graka dann aus.
Ist denke ich auch der Hauptgrund.
weniger Sticks sind immer besser und einfacher stabil zu bekommen.
Wobei man sagen muss, dass es auf den M8 Modellen dank T-Topologie mit 4 Modulen einfacher ist als auf z.B. den ASRock Modellen.
Im Grenzbereich sind zwei Single Sided Module aber am leichtesten zu handeln.
Ja mag sein, aber mit Vollbestückung schaffen es nur die wenigsten Boards 3600+ Mhz auf dem Ram zu fahren.
Ist mit 2 modulen deutlich einfacher.
Seit Kabylake bzw. Z270 ists aber egal ob RAM single oder Double sided ist.
Mein neues M8H lief jetzt 2 Wochen über ohne Probleme im Rechner und seit letzter Woche kommt es immer wieder zu Freezes bzw. zu (bisher 2 im Blend Test) Fehlern in Prime. Hatte jemand schon mal ein ähnliches Problem und kann mir helfen? Memtest zeigt keine Fehler und das Intel Tool für CPU Überprüfung auch nicht.
Habe schon verschiedene Sachen probiert, aber es hat nichts geholfen... BIOS ist das aktuelle 3101, weil ich dachte es beseitigt vlt. die Freezes es wurde bisher nichts übertaktet.
OS: Windows 10 Pro
MB: Asus Maximus VIII Hero BIOS 3101
CPU: i7 6700K non OC
GPU r9 390 nitro
RAM: 16 GB Balistix Sport LT DDR4-2400
SSD: 120 & 250GB Samsung 850 Evo und eine M.2 SSD von Samsung
HDD: WD Green 3 TB
NT: 500 Watt be quiet! Straight Power 10-CM
Das will ich auch wissen ... mein z270 ist bestellt.
