Intel Next Unit of Computing / NUC
Die haswell nucs konnten auch 4k...und bisher sieht es nicht so aus dass Intel bei den broadwell U-Prozessoren 4k@60Hz bringt
FYI/News/Rumors
Heise News: CES: Intel führt fünfte Generation der Core-i-Prozessoren ein
..die integrierte Grafik hat ordentlich zugelegt. Die Ausbaustufe GT2 – bei den neuen Broadwell-CPUs HD 5500 genannt – hat 24 Shader-Prozessoren statt vormals 20 (HD 4400); bei der größten Variante GT3 alias HD 6000 oder Iris 6100 sind es 48 statt bisher 40 (HD 5000, Iris 5100). Intel verspricht dadurch eine rund 20 Prozent höhere 3D-Leistung. Zudem hat auch die Video-Einheit hinzugelernt, die nun HEVC, VP8 und VP9 unterstützt...
legitreviews.com: Intel NUC 2.0 Officially Announced At CES 2015 w/ 5th Gen Core Broadwell Processors
legitreviews.com schrieb:
If you are a fan of Intel’s NUC – Next Unit of Computing – chances are you’ve been waiting for the NUC 2.0 to be released. The NUC 2.0 hasn’t changed that much visually from the original versions, but internally they feature the latest Core i3, Core i5 and Core i7 Broadwell processors along with some Braswell processors. Along with the new processors come some rather significant new features. For example, Intel has moved away from the mSATA storage interface and went with the latest and greatest M.2 interface. They also ditched all the external HighSpeed USB 2.0 ports and went with external SuperSpeed USB 3.0 headers on the front and back of the devices with a pair of internal USB 2.0 ports for those that need even more USB support. Some models also feature a pair of mini-DisplayPort v1.2 headers, which means these little boxes support triple display setups and are capable of 4K video output. Intel will also have a NUC system coming out in Q2’15 that is powered by an Intel Core i7 processor for the very first time (NUC5i7RYH)! The Intel NUC 2.0 might be great as a home theater PC, but these could easily replace your traditional desktop PC as they are very powerful little systems.
Intel will also be offering various lids that can be purchased for the NUC 2.0 models. They had a prototype Hauppauge TV tuner on one model...
...and then another with a removeable lid that had built-in NFC. Intel is working with a number of companies to come up with innovative removable lids as that is one of the new features of the Broadwell based NUC’s.
Irgendwo habe ich gelesen, dass das Platinenlayout sich nicht oder nur sehr wenig geändert hat und daher die alten passiven Gehäuse noch passen. Leider finde ich die Quelle nicht mehr :-(
Kann mir jemand im Besitz eines Haswell-NUC mit dem eingebauten Infrarot Empfänger vielleicht einen Gefallen tun?
Müsste nur mal kurz in der Eingabeaufforderung folgenden Befehl eingeben und nachschauen, ob in der Auflistung dort ein Gerät mit der Bezeichnung "ehome" oder "ir6" auftaucht:
Code:
powercfg -devicequery wake_from_any
Müsste ungefähr so aussehen:
Wann werden die neuen i5 NUCs hier erhältlich sein? Gibt es da schon Informationen?
Reichen für windows 7 + XBMC 2 GB Ram ? Gekauft wird :Zotac ZBOX CI320 nano (ZBOX-CI320NANO-BE)
Vielen Dank und viele Grüße
Gustav
2GB RAM für Win 7 sind etwas knapp.
Im Windows-Leerlauf alleine werden knapp 700-800MB benötigt.
Dazu dann noch (je nachdem wieviel man im BIOS dafür eingestellt hat) das, was die iGPU sich abzwackt und man hat schnell nur noch wenige hundert MB übrig.
Wenn ausser XBMC nichts anderes läuft, könnten 2GB gerade so noch reichen.
Firefox mit mehreren offenen Tabs gönnt sich übrigens auch gern schonmal 200-500MB oder sogar noch mehr RAM.
Gibts die Dinger eigentlich auch mit DualNIC/TripleNIC? Wuerde mir gerne nen Router auf NUC Basis bauen :)
Was willst denn damit machen? Vllt reicht ja auch der banana pi router ...
Na ein bisschen Basteltrieb befriedigen und nen ordentlichen Router aufbauen. Mit ordentlichen NICs, nativer verschluesselung auf CPU-Hardware-Ebene damit das Ding auch bei nen Paar Routing-Eintraegen nich die Graetsche macht. Achja, er soll auch n VPN Gateway sein. War jetz einfach mal so gefragt ob's die Kiste auch mit mehreren NICs gibt. Aber anscheinend ja leider nicht :/
Grueße
Niemand mit einem Haswell-NUC hier?
Code:
Kommt denke ich auf die CPU an, bei einem Baytrail ist es denke ich nicht verkehrt 2 Riegel zu haben.
ah, verdammt ist das Ding laut (Intel NUC DN2820FYK)
lauter als so ziemlich jeder Kühler den ich jemals hatte (Mugen, Apfelfoehn, Noctua, Big Shurriken), und da hilft die empfohlene 20% Einstellung auch nicht. Warum baut man nicht einfach einen 90mm lüfter rein? Warum muss man diese kleinen scheissdinger nehmen? Sonst isser perfekt ja.
Wird wieder verkauft
Apropos Nuc2820, kann mir jemand sagen wie man dort das Bios resettet? An die Batterie kommt man ja nicht so einfach heran...hm.
Es sollte ein BIOS Jumper zugänglich sein. Von Pin 1+2 auf 2+3 stecken und NUC starten, dann kommst du direkt ins BIOS. Da kannst du dann die Default Settings restoren und anschließend den Jumper wieder zurück auf 1+2 stecken.
Also direkt Bios resetten geht so nicht? Ich bekomme ja kein Bild und laut deinem Plan müsste er ja erstmal mit den vorhandenen Settings ins Bios gehen können. Hm.
Findest du? Ich hab den auch, den hör ich aber nichtmal wenn ich nahe dran gehe. Und ich BIOS hab ich nix umgestellt oder so.
Vielleicht hat deiner ja auch einen Defekt.
Wie gesagt, steck den Jumper um, dann geht er in eine Art Recoverymode, wo du dann den Reset machen kannst.
