Zu dem Win7 Bug könnte es hier einen Fix geben, offenbar weiß es Intel selber nicht ob sie es gefixt haben oder nicht:
https://communities.intel.com/message/213766#213766
Hinweis:
Thread zum Treiber -> https://communities.intel.com/message/213680#213680
Diego_Intel 21.11.2013 09:55
Hello all, could you please test the drivers posted here?
x64: Download Center -> https://downloadcenter.intel.com/De...05&keyword=3345&DownloadType=Drivers&lang=eng
x32: Download Center -> https://downloadcenter.intel.com/De...06&keyword=3345&DownloadType=Drivers&lang=eng
These drivers are compatible with win7, win8 and win8.1 using 3rd and 4th generation Intel® HD Graphics controllers.
Hinweis:
If you are having trouble with installing the driver, it can be for various reasons. Most commonly, it is because your system currently has a driver that was installed by your OEM, and those drivers present various error messages to the effect of "this driver is not suitable for your computer because your OEM said so!". If that is the case, you should follow the Manual Driver Installation instructions to install your driver (this is prefaced by downloading the .ZIP version of the driver from the links above).
